02-05-2024, 16:46 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: surat
Member: 219420 Status: Offline Thanks Meter: 78 | flashing error s5 44mm [erro] We don't know firmware locations for device OS type! [info] Found device in DFU mode [info] Gettting dfu mode device ... [warn] Phone model not found, please send email to [email protected], Thank you! [info] Extracting BuildManifest from ipsw [data] Product Version: 9.6.3 [data] Product Build: 20U502 Major: 20 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] Checking for required components... [info] Using ECID 000f042c1aeb002e [info] Getting ApNonce in dfu mode... [data] 48886E152F418A792D219B931B0333F59A4B03DF0918E85603 9D1086ADADBE44 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 47F78B1C34C44311A44FF2AD21ED53B2F348B8D8 [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] Unable to find component node for Cryptex1,SystemOS [info] Using cached file 'iDeviceTools\MFC_Watch5,4_20U502_9.6.3_n146bap_GP S_Cellular_Restore_44mm\097-48904-003.dmg' [info] Found ECID 000f042c1aeb002e [info] Getting ApNonce in dfu mode... [data] 48886E152F418A792D219B931B0333F59A4B03DF0918E85603 9D1086ADADBE44 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 47F78B1C34C44311A44FF2AD21ED53B2F348B8D8 [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Personalizing IMG4 component iBSS... [info] Sending iBSS (1183031 bytes)... [info] Removed (Apple, Inc.,USB\VID_05AC&PID_1227\CPID:8006_CPRV:11_CPFM: 03_SCEP:01_BDID:16_ECID:000F042C1AEB002E_IBFL:3C_S RTG:[IBOOT-3988.0.0.2.12]) [warn] If device does not disconnect automatically you can try to disconnect and reconnect the cable! [info] Device ecid 000f042c1aeb002e disconnect detected! [info] Waiting for device arrival (timeout 20.000000 seconds) [info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV: 11_CPFM:03_SCEP:01_BDID:16_ECID:000F042C1AEB002E_I BFL:3C_SRNM:[FHLZG1DUMLF0]) [info] Found device in Recovery mode [info] cpid:0x8006, bdid:0x0016 [info] Noce: 48 88 6e 15 2f 41 8a 79 2d 21 9b 93 1b 03 33 f5 9a 4b 03 df 09 18 e8 56 03 9d 10 86 ad ad be 44 [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (1183031 bytes)... [info] Removed (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV: 11_CPFM:03_SCEP:01_BDID:16_ECID:000F042C1AEB002E_I BFL:3C_SRNM:[FHLZG1DUMLF0]) [info] Device ecid 000f042c1aeb002e disconnect detected! [info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV: 11_CPFM:03_SCEP:01_BDID:16_ECID:000F042C1AEB002E_I BFL:3C_SRNM:[FHLZG1DUMLF0]) [info] device serial number is FHLZG1DUMLF0 [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-8422.140.59 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (10966 bytes)... [warn] No path for component ACIBT in TSS, will fetch from build_identity [info] Personalizing IMG4 component ACIBT... [info] Sending ACIBT (1958115 bytes)... [warn] No path for component ACIWIFI in TSS, will fetch from build_identity [info] Personalizing IMG4 component ACIWIFI... [info] Sending ACIWIFI (1937295 bytes)... [warn] No path for component ANE in TSS, will fetch from build_identity [info] Personalizing IMG4 component ANE... [info] Sending ANE (1771159 bytes)... [warn] No path for component AOP in TSS, will fetch from build_identity [info] Personalizing IMG4 component AOP... [info] Sending AOP (1608871 bytes)... [warn] No path for component GFX in TSS, will fetch from build_identity [info] Personalizing IMG4 component GFX... [info] Sending GFX (881535 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (17608 bytes)... [warn] No path for component SCE in TSS, will fetch from build_identity [info] Personalizing IMG4 component SCE... [info] Sending SCE (20157 bytes)... [warn] No path for component SIO in TSS, will fetch from build_identity [info] Personalizing IMG4 component SIO... [info] Sending SIO (1160603 bytes)... [warn] No path for component WCHFirmwareUpdater in TSS, will fetch from build_identity [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Sending WCHFirmwareUpdater (33286 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (85990570 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (44762 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (3366288 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (14708216 bytes)... [info] Device ecid 000f042c1aeb002e disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 00008006-000F042C1AEB002E has successfully entered restore mode [info] Hardware Information: [info] BoardID: 22 [info] ChipID: 32774 [info] UniqueChipID: 4226712127340590 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Checkpoint 1621 complete with code 0 [info] Checkpoint 1540 complete with code 0 [info] Checkpoint 1679 complete with code 0 [info] About to send RootTicket... [info] Sending RootTicket now... [done] sending RootTicket [info] Checkpoint 1547 complete with code 0 [info] Waiting for NAND (28) [info] Checkpoint 1549 complete with code 0 [info] Updating NAND Firmware (58) [info] Checkpoint 1550 complete with code 0 [info] Checkpoint 1551 complete with code 0 [info] Checkpoint 1628 complete with code 0 [info] Checkpoint 1552 complete with code 0 [info] Checkpoint 1555 complete with code 0 [info] Checkpoint 1662 complete with code 0 [info] Sending NORData... [info] Found firmware path Firmware/all_flash [info] Getting firmware manifest from build identity [info] Personalizing IMG4 component LLB... [info] Personalizing IMG4 component AppleLogo... [info] Personalizing IMG4 component Dali... [info] Personalizing IMG4 component DeviceTree... [info] Personalizing IMG4 component RecoveryMode... [info] Personalizing IMG4 component WCHFirmwareUpdater... [info] Personalizing IMG4 component iBoot... [info] Personalizing IMG4 component RestoreSEP... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [done] Done sending NORData [info] Checkpoint 1545 complete with code 0 [info] Checkpoint 1683 complete with code 0 [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Checkpoint 1637 complete with code 0 [info] Checkpoint 1556 complete with code 0 [info] Checkpoint 1686 complete with code 0 [info] Checkpoint 1699 complete with code 0 [info] Checkpoint 1695 complete with code 0 [info] Checkpoint 1620 complete with code 0 [info] Checkpoint 1687 complete with code 0 [info] Checkpoint 1557 complete with code 0 [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [info] Checkpoint 1558 complete with code 0 [info] Checkpoint 1559 complete with code 0 [info] Checkpoint 1560 complete with code 0 [info] Checking for uncollected logs (44) [info] Checkpoint 1561 complete with code 0 [info] Checkpoint 1562 complete with code 0 [info] Checkpoint 1563 complete with code 0 [info] Checkpoint 1633 complete with code 0 [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Checkpoint 1565 complete with code 0 [info] Checkpoint 1614 complete with code 0 [info] Checkpoint 1567 complete with code 0 [info] Checkpoint 1674 complete with code 0 [info] Creating partition map (11) [info] Checkpoint 1569 complete with code 0 [info] Checkpoint 1632 complete with code 0 [info] Checkpoint 1570 complete with code 0 [info] Checkpoint 1629 complete with code 0 [info] Checkpoint 5645 complete with code 0 [info] Creating filesystem (12) [info] Checkpoint 1624 complete with code 0 [info] Checkpoint 1625 complete with code 0 [info] Checkpoint 1626 complete with code 0 [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [done] sending filesystem [info] Operation: Verifying restore (14) [info] Checkpoint 1627 complete with code 0 [info] Checkpoint 1664 complete with code 0 [info] Checkpoint 1653 complete with code 0 [info] Checkpoint 1676 complete with code 0 [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Checking filesystems (15) [info] Checking filesystems (15) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Mounting filesystems (16) [info] Mounting filesystems (16) [info] Mounting filesystems (16) [info] Checkpoint 1574 complete with code 0 [info] Checkpoint 1634 complete with code 0 [info] Checkpoint 1655 complete with code 0 [info] Checkpoint 1658 complete with code 0 [info] Checkpoint 1575 complete with code 0 [info] Checkpoint 1690 complete with code 0 [info] Checkpoint 1691 complete with code 0 [info] Checkpoint 1618 complete with code 0 [info] Checkpoint 1588 complete with code 0 [info] Checkpoint 1661 complete with code 0 [info] Operation: Unknown operation (80) [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Flashing firmware (18) [info] Checkpoint 4864 complete with code 0 [info] Operation: Unknown operation (80) [info] Sending IsEarlyAccessFirmware image list [info] Sending IsiBootEANFirmware image list [info] Sending IsiBootNonEssentialFirmware image list [info] Checkpoint 4882 complete with code 0 [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Personalizing IMG4 component ACIBT... [info] Sending IsFUDFirmware for ACIBT... [info] Personalizing IMG4 component ACIWIFI... [info] Sending IsFUDFirmware for ACIWIFI... [info] Personalizing IMG4 component ANE... [info] Sending IsFUDFirmware for ANE... [info] Personalizing IMG4 component AOP... [info] Sending IsFUDFirmware for AOP... [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Personalizing IMG4 component GFX... [info] Sending IsFUDFirmware for GFX... [info] Personalizing IMG4 component LeapHaptics... [info] Sending IsFUDFirmware for LeapHaptics... [info] Personalizing IMG4 component Multitouch... [info] Sending IsFUDFirmware for Multitouch... [info] Personalizing IMG4 component RTP... [info] Sending IsFUDFirmware for RTP... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Personalizing IMG4 component SCE... [info] Sending IsFUDFirmware for SCE... [info] Personalizing IMG4 component SIO... [info] Sending IsFUDFirmware for SIO... [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4874 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4865 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4866 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Operation: Requesting FUD data (36) [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4869 complete with code 0 [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4869 complete with code 0 [info] Found IsFUDFirmware component ACIBT [info] Found IsFUDFirmware component ACIWIFI [info] Found IsFUDFirmware component ANE [info] Found IsFUDFirmware component AOP [info] Found IsFUDFirmware component Ap,SystemVolumeCanonicalMetadata [info] Found IsFUDFirmware component GFX [info] Found IsFUDFirmware component LeapHaptics [info] Found IsFUDFirmware component Multitouch [info] Found IsFUDFirmware component RTP [info] Found IsFUDFirmware component RestoreTrustCache [info] Found IsFUDFirmware component SCE [info] Found IsFUDFirmware component SIO [info] Found IsFUDFirmware component StaticTrustCache [info] Found IsFUDFirmware component SystemVolume [info] Sending IsFUDFirmware image list [info] Personalizing IMG4 component Ap,SystemVolumeCanonicalMetadata... [info] Sending IsFUDFirmware for Ap,SystemVolumeCanonicalMetadata... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending IsFUDFirmware for RestoreTrustCache... [info] Personalizing IMG4 component SystemVolume... [info] Sending IsFUDFirmware for SystemVolume... [info] Checkpoint 4869 complete with code 18446744073709551615 [info] Checkpoint 1589 complete with code 18446744073709551615 [info] Checkpoint 1659 complete with code 18446744073709551615 [info] Checkpoint 1660 complete with code 0 [info] Checkpoint 5651 complete with code 0 [info] Checkpoint 1607 complete with code 0 [info] Status message: Verification Error [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [info] Checkpoint 1608 complete with code 0 [erro] Unable to restore device [done] Operation finished! [info] Removed (Apple, Inc.,USB\VID_05AC&PID_12AF\00008006-000F042C1AEB002E) [info] Arrival (Apple, Inc.,USB\VID_05AC&PID_1281\SDOM:01_CPID:8006_CPRV: 11_CPFM:03_SCEP:01_BDID:16_ECID:000F042C1AEB002E_I BFL:3D_SRNM:[FHLZG1DUMLF0]) |
