02-08-2018, 21:25 | #1 (permalink) |
Crazy Poster Join Date: Oct 2015
Member: 2466640 Status: Offline Thanks Meter: 18 | iBus plus MFC? They are tagged "MFC only" so I downloaded the MFC software and watched the youtube video watch?v=pusilGfac10 to see how to use it. At 4:45 I'm supposed to click on "iMFC" and get a display of the watch info. But all it says is "[info] Loading history ..." The watch info never comes up and so I can't get past this part. |
02-15-2018, 00:00 | #5 (permalink) |
Member: 2466640 Status: Offline Thanks Meter: 18 | I already have iBus S1 and S2. If I also buy MFC Dongle, will that be enough to reflash firmware on Apple Watches using the files currently in the Download section? Will I have to buy MFC "credits" too? |
02-15-2018, 02:56 | #6 (permalink) |
Freak Poster Join Date: Dec 2017 Location: ()
Member: 2794635 Status: Offline Thanks Meter: 43 | No credits are required to restore watch. And yes, those files in the downloads section will work for restoring with MFC Dongle and iBUS. |
The Following User Says Thank You to hackedbyj4 For This Useful Post: |
02-16-2018, 08:15 | #8 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | the pages already wrote related rules,you can read https://www.mfcbox.com/Watch-ipsw-firmware-download |
03-05-2018, 23:42 | #9 (permalink) |
Member: 2466640 Status: Offline Thanks Meter: 18 | Today I received the MFC Dongle kit and successfully restored a S0 Watch. Got a stack of S2 to do tomorrow. Only complaint is that the MFC software messes with my caps lock & I have to be careful or else I end up YELLING IN EMAILS :-) |
03-06-2018, 10:42 | #10 (permalink) | |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
BR., | |
03-06-2018, 17:52 | #11 (permalink) |
Member: 2466640 Status: Offline Thanks Meter: 18 | S2 38mm Watch. Replaced the Display assembly and it won't pair with any phone. Phone says "Activation error". I'm fairly certain the Watch is activation locked but I need to reflash to fix the Display compatibility to be sure. However the reflash fails. (Forum software won't let me post the log here because it thinks contains links, so change "+" to "." below) Code: (...) [info] Extracting DeviceTree+n74ap+im4p... [info] Sending DeviceTree ... [info] Done[info] Certifying Savage (61) [info] Flashing firmware (18) [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Unhandled status message (56). Saving to UnhandledStatusMessage+plist [info] Unhandled status message [sett] Log is available in ErrorLog+plist [erro] Unable to successfully restore device [erro] Unable to restore device [info] Failed [info] Apple device disconnected! Is this because of the activation lock? |
03-06-2018, 19:19 | #12 (permalink) | |
03-06-2018, 23:23 | #13 (permalink) |
Member: 2466640 Status: Offline Thanks Meter: 18 | That plist is 77k long but it looks like the relevant part is right at the end (again, replace "+" with "."): Code: Update[Stockholm] error - The operation couldn\U2019t be completed. (RamrodErrorDomain error 1007 - update_stockholm: NfRestore Failed. NfResult: 5) [20:30:46.0982-GMT]{4>8} CHECKPOINT FAILURE:(FAILURE:-1) FIRMWARE:[0x1304] update_stockholm [0]D(update_stockholm: NfRestore Failed. NfResult: 5)[1]LD(Error 0x0009 at NFRestoreNfc:1136: 33000000000000 Tx000004f10000006eefRx-AbortRx-AbortRx-Abort) restore-step-results = {0x11071304:{0:-1;1:-1;2:-1}} restore-step-codes = {0x11071304:{2:1007};0x11041304:{0:1007;1:1007}} restore-step-domains = {0x11071304:{2:"RamrodErrorDomain"};0x11041304:{0:"RamrodErrorDomain";1:"RamrodErrorDomain"}} restore-step-error = {0x11071304:"[0]D(update_stockholm: NfRestore Failed. NfResult: 5)[1]LD(Error 0x0009 at NFRestoreNfc:1136: 33000000000000 Tx000004f10000006eefRx-AbortRx-AbortRx-Abort)"} restore-step-uptime = 559 restore-step-user-progress = 84 0: RamrodErrorDomain/3ef: update_stockholm: NfRestore Failed. NfResult: 5 1: com+apple+nfstack/9 [20:30:47.0022-GMT]{4>8} CHECKPOINT FAILURE:(FAILURE:56) RESTORED:[0x0635] update_device_firmware [0]D(failed to update device firmware)[1]D(ramrod firmware update failed)[2]D(update_stockholm: NfRestore Failed. NfResult: 5)[3]LD(Error 0x0009 at NFRestoreNfc:1136: 33000000000000 Tx000004f10000006eefRx-AbortRx-AbortRx-Abort) restore-step-results = {0x11070635:{0:56};0x11071304:{0:-1;1:-1;2:-1}} restore-step-codes = {0x11070635:{0:56};0x11071304:{2:1007};0x11041304:{0:1007;1:1007}} restore-step-domains = {0x11070635:{0:"AMRestoreErrorDomain"};0x11071304:{2:"RamrodErrorDomain"}} restore-step-error = {0x11070635:"[0]D(failed to update device firmware)[1]D(ramrod firmware update failed)[2]D(update_stockholm: NfRestore Failed. NfResult: 5)[3]LD(Error 0x0009 at NFRestoreNfc:1136: 33000000000000 Tx000004f10000006eefRx-AbortRx-AbortRx-Abort)"} restore-step-uptime = 560 restore-step-user-progress = 84 [20:30:47.0047-GMT]{4>8} CHECKPOINT BEGIN: RESTORED:[0x0647] cleanup_check_result restore-step-ids = {0x11030635:58;0x11031304:62;0x11030647:63} restore-step-names = {0x11030635:update_device_firmware;0x11031304:update_stockholm;0x11030647:cleanup_check_result} restore-step-uptime = 560 restore-step-user-progress = 84 [20:30:47.0065-GMT]{4>8} CHECKPOINT END: RESTORED:[0x0647] cleanup_check_result restore-step-ids = {0x11030635:58;0x11031304:62} restore-step-names = {0x11030635:update_device_firmware;0x11031304:update_stockholm} restore-step-uptime = 560 restore-step-user-progress = 84 [20:30:47.0082-GMT]{4>8} CHECKPOINT BEGIN: RESTORED:[0x0648] cleanup_send_final_status restore-step-ids = {0x11030635:58;0x11031304:62;0x11030648:64} restore-step-names = {0x11030635:update_device_firmware;0x11031304:update_stockholm;0x11030648:cleanup_send_final_status} restore-step-uptime = 560 restore-step-user-progress = 84 |
03-07-2018, 09:55 | #14 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | better send full file to [email protected], that hard to read a part of this . |
