01-26-2018, 05:34 | #1 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2678754 Status: Offline Thanks Meter: 0 | iBus requires MFC Dongle? Im trying to restore some of my watches (normally I just used the other tool through iTunes). I installed the MFC software but I it gives a lot of bugs. I had some libusb0 dll error that I fixed and now it loads up and then randomly says something about the server not being able to be initiated. Do I need a MFC Dongle to use the iBus? Also, we need to use a rubber band to hold it together? |
01-26-2018, 06:48 | #4 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | MFC Dongle is the first in the world that support Apple Watch under windows. And iBUS not requires MFC Dongle if you have original firmware. MFC Software is not free which requires MFC Dongle when you use. |
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post: |
01-27-2018, 08:42 | #7 (permalink) |
Member: 2678754 Status: Offline Thanks Meter: 0 | One other question for anyone reading this. Just want to have it planned out when I get the dongle. So in order to use the iBus with MFC Dongle, is there a guide or youtube video? It seems a bit tricky but Im not sure because I saw a lot of wiring included with "MFC Dongle" I think once I get it, it might not be too bad to figure out but just in case. |
01-27-2018, 08:53 | #8 (permalink) | |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
For example : https://www.youtube.com/watch?v=pusilGfac10 | |
02-08-2018, 07:16 | #9 (permalink) | |
Member: 2678754 Status: Offline Thanks Meter: 0 | Quote: MFC software just says "server init failed" | |
02-08-2018, 07:30 | #10 (permalink) |
Member: 2678754 Status: Offline Thanks Meter: 0 | I found out how to split the two devices from the dongle. I connected the red wire from P0 and GND. I plugged it into the computer and it is recognized. MFC tells me the serial is 0x0000000. When I go to the maintenance tab and click "read SN" it doesn't read it. |
