07-08-2017, 10:57 | #1 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2732945 Status: Offline Thanks Meter: 1 | iBus S1 watch 0, help please (Boot Loop issue) having problems here. i cannot get my watch to connect to my mac and work with iTunes, and cannot get into DFU. I have checked my cable, changed usb ports, even used another program called REiBoot to connect my phone and iPad to it to check the cable connection with the mac. iTunes picks up my iPhone and iPad instantly when connected. Watch is stuck in a Boot Loop, I have no access to any settings. Managed to get it unpaired from my phone as it was totally unresponsive ( not used much). I am thinking now that my iBus is the problem. Anybody help ? What am i doing wrong? Ive tried several different ways to try get the watch into DFU, its just not working Thanks |
07-08-2017, 18:10 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
Check this video : | |
07-09-2017, 09:21 | #3 (permalink) |
Member: 2732945 Status: Offline Thanks Meter: 1 | Thanks for the reply. Yes Ive seen this video. MY problem is this ..... When I plug the USB cable into the iBus, iTunes does nothing. It does not recognise the watch. My watch is stuck in Boot Loop, it only shows the apple logo, it does not show the same screen as in your video !! I cannot get into DFU mode because the watch is not connecting to iTunes !!! any ideas ? |
07-09-2017, 10:25 | #4 (permalink) |
Member: 2732945 Status: Offline Thanks Meter: 1 | Restore Complete one of the pins was stuck in slightly, pulled out with tweezers and it made the connection. OK, Boot Loop Solution..... If your watch is stuck on the Apple Logo and won't start up..... connect the charger to maintain power Press and hold BOTH BUTTONS continuously UNTIL THE RED SCREEN IS SHOWN Have iTunes open already connect iBus to MAC with USB cable iTunes would only connect on my mac when the Red Screen was displayed !!! Hope this helps someone with the same problem. Thanks Guys |
The Following User Says Thank You to Bace88 For This Useful Post: |
07-09-2017, 14:19 | #5 (permalink) | |
Good to know the issue fixed. by the way , iBUS pin can changed if due some reason got broken etc. (as u said can using tweezer take the pin out.) Br., Denis | |
