11-03-2018, 10:40 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Iwatch S3 38mm restore error Code: [info] [info] Starting ... [info] Using LOCAL IPSW F:\MFC\Iwatch S3\38\MFC_Watch3,1_15T567_4.3.1_n111sAP_GPS_Cellular_Restore_38mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Identified device as Apple Watch S3, n111sap, Watch3,1 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.3.1 [data] Product Build: 15T567 Major: 15 [data] Device supports Image4: true [info] Variant: Customer Upgrade Install (IPSW) [info] This restore will update your device without losing data. [info] Found ECID 41533273882790 [info] Getting ApNonce in dfu mode... [data] F305BDDFD8515A5B43223769908615455BC7052943BE7DB4BAC775401298BD5B [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] F398E2C2C6EDADE8E096BAECA96AF4DB6C83ADC9 [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,1_15T567_4.3.1_n111sAP_GPS_Cellular_Restore_38mm/048-11298-070.dmg' [info] Extracting iBSS.n111s.RELEASE.im4p... [info] Sending iBSS (727437 bytes)... [info] Noce: f3 05 bd df d8 51 5a 5b 43 22 37 69 90 86 15 45 5b c7 05 29 43 be 7d b4 ba c7 75 40 12 98 bd 5b [info] Extracting iBEC.n111s.RELEASE.im4p... [info] Sending iBEC (727437 bytes)... [info] device serial number is FH7W2T4QJ6DW [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.60.11 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.im4p... [info] Sending AppleLogo (8116 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 048-11370-070.dmg... [info] Sending RestoreRamDisk (84456139 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n111sap.im4p... [info] Sending RestoreDeviceTree (108701 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Sending RestoreKernelCache (13971371 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [data] UniqueDeviceID:d662a07935fe302902d71cedef0bdd166d0858c5 [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device d662a07935fe302902d71cedef0bdd166d0858c5 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 28 [info] ChipID: 32772 [info] UniqueChipID: 41533273882790 [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n111s.RELEASE.im4p... [info] Extracting applelogo@115~watch.im4p... [info] Extracting dali-ui.n111s.release.im4p... [info] Extracting DeviceTree.n111sap.im4p... [info] Extracting recoverymode@115~watch.im4p... [info] Extracting iBoot.n111s.RELEASE.im4p... [info] Extracting sep-firmware.n111s.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [erro] Unable to receive message from FDR 07156E00 (-4). 0/2 bytes [warn] Lockdown error: -8 [info] Apple device disconnected! |
