02-06-2018, 20:48 | #16 (permalink) | |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
Code: [info] Request URL set to https://17.111.103.65/TSS/controller?action=2 [info] Sending TSS request attempt 2... [info] response successfully received [info] tts>Received SHSH blobs [info] Extracting filesystem [info] Extracting filesystem [info] Extracting 058-86830-108.dmg to iDeviceTools/MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm/058-86830-108.dmg.extract from D:\MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm.ipsw ... [info] Entering recovery mode... Code: [info] Found FUD component 'RTP' [info] Extracting rtpfw.im4p... [info] Extracting Firmware/rtpfw.im4p to memory from D:\MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm.ipsw ... [info] Writing data to RTP [info] Sending FUD data now... [done] Done sending FUD data [info] Updating SE Firmware (59) [info] Updating SE Firmware (59) [info] Fixing up /var (17) [info] Fixing up /var (17) [info] FDR 070A28D8 timeout waiting for command [info] FDR 070A28D8 waiting for message... [info] Creating system key bag (50) [info] Creating system key bag (50) [info] No data to read [info] Modifying persistent boot-args (25) [info] Modifying persistent boot-args (25) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Unmounting filesystems (29) [info] Restore Finished [info] Restore Finished [info] Cleaning up... [done] Done [info] Removing USB\VID_05AC&PID_12AF\6C404C9F9108E41D31896D292CB02643B6F5EA39 [info] Apple device disconnected! | |
02-07-2018, 06:39 | #18 (permalink) |
Freak Poster Join Date: Jul 2009 Location: viet nam
Member: 1067406 Status: Offline Thanks Meter: 5 | [info] [info] Starting ... [warn] Operation aborted by user! [info] Starting ... [info] Searching for iDevice ... [info] Found device in Recovery mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] changing mode ...[warn] operation not defined! [info] Finished ! [info] Starting ... [info] Searching for iDevice ... [info] Found device in Recovery mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] changing mode ...[warn] operation not defined! [info] Finished ! [info] Starting ... [info] Searching for iDevice ... [info] Found device in Recovery mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] changing mode ...[warn] operation not defined! [info] Finished ! [info] Starting ... [info] Using LOCAL IPSW D:\APPLE WATCH\S2 42mm\MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm.ip sw [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.2 [data] Product Build: 15S102 Major: 15 [info] device serial number is FH8SFANWHJLJ [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 1531268129465638 [info] Getting ApNonce in recovery mode... [data] 69A106EC2E7F88742414608A96B3364C578DB445129528FAED 70A9C8EEF323E1 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] B251959AA9229A4C90DFE1C3EE84CA0F141F04BD [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm/058-86830-108.dmg' [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Sending iBEC (714914 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.30.43 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Sending AppleLogo (8415 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 058-86768-108.dmg... [info] Sending RestoreRamDisk (39552480 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending RestoreDeviceTree (101445 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Sending RestoreKernelCache (12622502 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 866235a5ac415a776932aaa547c46659c32a34be has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 32770 [info] UniqueChipID: 1531268129465638 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49165) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n65.RELEASE.im4p... [info] Extracting applelogo@132~watch.im4p... [info] Extracting dali-ui.n75.release.im4p... [info] Extracting DeviceTree.n75ap.im4p... [info] Extracting recoverymode@132~watch.im4p... [info] Extracting iBoot.n65.RELEASE.im4p... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 0739F620 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 091406C0 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Sending KernelCache... [info] Extracting kernelcache.release.watch2... [done] sending KernelCache [info] Installing kernelcache (27) [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending DeviceTree ... [info] Done[info] Certifying Savage (61) [info] Flashing firmware (18) [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] About to send FUD data... [info] Found FUD component 'AOP' [info] Extracting aopfw-m8aop.im4p... [info] Found FUD component 'Multitouch' [info] Extracting N75_Multitouch.im4p... [info] Found FUD component 'RTP' [info] Extracting rtpfw.im4p... [info] Sending FUD data now... [done] Done sending FUD data [info] About to send FUD data... [info] Found FUD component 'AOP' [info] Extracting aopfw-m8aop.im4p... [info] Found FUD component 'Multitouch' [info] Extracting N75_Multitouch.im4p... [info] Found FUD component 'RTP' [info] Extracting rtpfw.im4p... [info] Sending FUD data now... [done] Done sending FUD data [info] About to send FUD data... [info] Found FUD component 'AOP' [info] Extracting aopfw-m8aop.im4p... [info] Found FUD component 'Multitouch' [info] Extracting N75_Multitouch.im4p... [info] Found FUD component 'RTP' [info] Extracting rtpfw.im4p... [info] Sending FUD data now... [done] Done sending FUD data [info] About to send FUD data... [info] Found FUD component 'AOP' [info] Extracting aopfw-m8aop.im4p... [info] Found FUD component 'Multitouch' [info] Extracting N75_Multitouch.im4p... [info] Found FUD component 'RTP' [info] Extracting rtpfw.im4p... [info] Sending FUD data now... [done] Done sending FUD data [info] Verification Error [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [erro] Unable to restore device [info] Failed [info] Apple device disconnected! ERROR |
02-07-2018, 09:18 | #19 (permalink) |
Member: 1067406 Status: Offline Thanks Meter: 5 | [info] [info] Starting ... [info] Using LOCAL IPSW D:\APPLE WATCH\S2 42mm\MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm.ip sw [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch S2, n75ap, Watch2,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.2 [data] Product Build: 15S102 Major: 15 [info] device serial number is FH7SQDENHHYL [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 2630427229136166 [info] Getting ApNonce in recovery mode... [data] 0C0F591CF8232B1C6A67673F0D1D62479BF78AE2373D059010 E83EEC6E91E866 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 063E4F54508A07757A0A474BA4BB07C4C83A0B21 [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,4_4.2_15S102_n75ap_Restore_42mm/058-86830-108.dmg' [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Sending iBEC (714914 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.30.43 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Sending AppleLogo (8415 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 058-86768-108.dmg... [info] Sending RestoreRamDisk (39552480 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending RestoreDeviceTree (101445 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Sending RestoreKernelCache (12622502 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device e26db37df52937c181f715f264d1c891ec4fb00f has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 32770 [info] UniqueChipID: 2630427229136166 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49165) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n65.RELEASE.im4p... [info] Extracting applelogo@132~watch.im4p... [info] Extracting dali-ui.n75.release.im4p... [info] Extracting DeviceTree.n75ap.im4p... [info] Extracting recoverymode@132~watch.im4p... [info] Extracting iBoot.n65.RELEASE.im4p... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 0904B4A8 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Sending KernelCache... [info] Extracting kernelcache.release.watch2... [done] sending KernelCache [info] Installing kernelcache (27) [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending DeviceTree ... [info] Done[info] Certifying Savage (61) [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 070A1DF0 got plist message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 070A1DC0 got proxy message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 070A1DA8 got plist message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 070A1D00 got proxy message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 070A1D78 got plist message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 070A1CA0 got proxy message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 070A1D78 got plist message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 070A1DA8 got proxy message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 070A1E50 got plist message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 070A1D18 got proxy message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 06074138 got plist message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 06074240 got proxy message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 06074168 got plist message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 06074270 got proxy message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 070B2FF8 got plist message [warn] FDR 0607A3F8 got sync message [info] Connecting to FDR client at port 49165 [warn] FDR 070B3010 got proxy message [info] Flashing firmware (18) [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Unhandled status message (56). Saving to UnhandledStatusMessage.plist [info] Unhandled status message [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [erro] Unable to restore device [info] Failed [info] Apple device disconnected! |
03-06-2018, 15:24 | #21 (permalink) | |
https://www.mfcbox.com/Watch-ipsw-firmware-download/ | |
