02-13-2018, 23:44 | #1 (permalink) |
Freak Poster Join Date: Jun 2004
Member: 68795 Status: Offline Thanks Meter: 0 | S3 Error Flashing I get right up to the point where it is finalising then I get unhandledstatus error in log ? Is there anything I could do to solve this thanks |
02-14-2018, 00:11 | #2 (permalink) |
Member: 68795 Status: Offline Thanks Meter: 0 | Error Log [info] [info] Starting ... [info] Using LOCAL IPSW C:\Users\Test\Downloads\MFC_Watch3,4_15S102_4.2_n1 21bAP_GPS_Restore_42mm.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.2 [data] Product Build: 15S102 Major: 15 [info] device serial number is FHLVK1P4J5X4 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 8857743133442214 [info] Getting ApNonce in recovery mode... [data] 18217C13379A100F214382C6CC66BEFF8E900F8F13E0CE56EC 32CE0AD0358E58 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] CDDFDD4E7C4FE514C0E3A47EFB381540D45A9056 [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_15S102_4.2_n121bAP_GPS_Restore_42mm/058-86622-108.dmg' [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Sending iBEC (706958 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.30.43 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Sending AppleLogo (8651 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 058-86768-108.dmg... [info] Sending RestoreRamDisk (39552716 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Sending RestoreDeviceTree (103469 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Sending RestoreKernelCache (13908400 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 968d7a3702e358882f86ea23de88b7f4bab63c53 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 8857743133442214 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49164) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Extracting applelogo@132~watch.im4p... [info] Extracting dali-ui.n121b.release.im4p... [info] Extracting DeviceTree.n121bap.im4p... [info] Extracting recoverymode@132~watch.im4p... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 09BA7FA0 got sync message [info] Connecting to FDR client at port 49164 [warn] FDR 0D7408F0 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Sending KernelCache... [info] Extracting kernelcache.release.watch3... [done] sending KernelCache [info] Installing kernelcache (27) [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n121bap.im4p... [info] Sending DeviceTree ... [info] Done[info] Certifying Savage (61) [info] Flashing firmware (18) [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Unhandled status message (56). Saving to UnhandledStatusMessage.plist [info] Unhandled status message [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [erro] Unable to restore device [info] Failed [info] Apple device disconnected! |
