06-03-2018, 11:32 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Location: viet nam
Member: 1067406 Status: Offline Thanks Meter: 5 | series 3 flash error before realce sreen ,help me [info] [info] Starting ... [info] Using LOCAL IPSW D:\APPLE WATCH\S3 42mm\watchOS 4.3 Series 3 GPS+Cellular - 42mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Identified device as Apple Watch S3, n111bap, Watch3,2 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.3 [data] Product Build: 15T212 Major: 15 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 1804028132819110 [info] Getting ApNonce in dfu mode... [data] A05D8903EB701C720A2192680A33A64CA31C000C00551B3FE6 ADA56A2D31CC51 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 11FFFB9486900EFB10FF54968D2A21F68F83C380 [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/watchOS 4.3 Series 3 GPS+Cellular - 42mm/048-01716-096.dmg' [info] Extracting iBSS.n111b.RELEASE.im4p... [info] Sending iBSS (711055 bytes)... [info] Noce: a0 5d 89 03 eb 70 1c 72 0a 21 92 68 0a 33 a6 4c a3 1c 00 0c 00 55 1b 3f e6 ad a5 6a 2d 31 cc 51 [info] Extracting iBEC.n111b.RELEASE.im4p... [info] Sending iBEC (711055 bytes)... [info] device serial number is FHLVRT5UJ6GF [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-4076.50.126 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Sending AppleLogo (8651 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 048-01761-096.dmg... [info] Sending RestoreRamDisk (83305676 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n111bap.im4p... [info] Sending RestoreDeviceTree (108703 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Sending RestoreKernelCache (13929264 bytes)... [info] Restoring device... [info] Waiting for device... [info] Apple device arrival ... searching USBMux for device after 100ms [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 782882d97ccbb966c09b178d123f49638e5a02e3 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 30 [info] ChipID: 32772 [info] UniqueChipID: 1804028132819110 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49156) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n111b.RELEASE.im4p... [info] Extracting applelogo@132~watch.im4p... [info] Extracting dali-ui.n111b.release.im4p... [info] Extracting DeviceTree.n111bap.im4p... [info] Extracting recoverymode@132~watch.im4p... [info] Extracting iBoot.n111b.RELEASE.im4p... [info] Extracting sep-firmware.n111b.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 073DA4A0 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Sending KernelCache... [info] Extracting kernelcache.release.watch3... [done] sending KernelCache [info] Installing kernelcache (27) [warn] No path for component DeviceTree in TSS, will fetch from build identity [info] Extracting DeviceTree.n111bap.im4p... [info] Sending DeviceTree ... [info] Done[info] Certifying Savage (61) [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 03E283E8 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 03E28430 got proxy message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 03E28370 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 03E28490 got proxy message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7B718 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7B688 got proxy message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7B670 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7B7A8 got proxy message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7B6A0 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7B628 got proxy message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7B718 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7B7C0 got proxy message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7B670 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7B5F8 got proxy message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 073AD8E0 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 073AD868 got proxy message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 073AD8E0 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 073AD8C8 got proxy message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 073AD808 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 073AD838 got proxy message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7F180 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7F288 got proxy message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7F180 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7F240 got proxy message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7F2A0 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 05F7F168 got proxy message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 03E284D8 got plist message [warn] FDR 08A59038 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 03E28418 got proxy message [info] Flashing firmware (18) [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Unhandled status message (56). Saving to UnhandledStatusMessage.plist [info] Unhandled status message [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [erro] Unable to restore device [info] Failed [info] Apple device disconnected! |
06-03-2018, 15:34 | #3 (permalink) | |
Freak Poster Join Date: Dec 2017 Location: ()
Member: 2794635 Status: Offline Thanks Meter: 43 | Quote:
