10-26-2017, 18:21 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: USA N China
Member: 24066 Status: Offline Sonork: 100.9 Thanks Meter: 574 | New Version To unlock iphone with GFSIM Update GFSIM 1.Download apdu file from this post attachement. (Make sure to put downloader and apdu.txt file in same folder.) 2.Update using downloader Link https://ufile.io/pfdgu You need usb dongle updater for this. Put GFSIM along with Gsm Sim. When you Power on you will see on iphone "Activation Required" ? Dismiss it. 1. Go to emergency call and dial 2. *5005*7672*00# press Green call button. 3. Select General unlock 4. Select Operator from the list or manually input imsi if network not listed 5. It will unlock the phone. wait for 10-15 seconds to autorefresh it self. Some time it takes you to activation screen again, just wait it will refresh and show signal. This method work with all models Except Intel baseband phone. After Unlock If no signal than go to "Settings" "Phone" "Sim Applications" "Carrier select" "Reset settings" select operator again (or input imsi manualy if your operator not in list) Click "Accept" It will show Activation Required, Click "Dismiss" and wait for the signal. (Step 5 above) If still no signal. Reset "Reset Network settings" And start with Step 1. This version is BETA. Modification will be made upon feedbacks. Update 04-11-2017 Version GFSIM_v3_1_1102 Bug fixes where some users reported not showing unlock menu after input code *5005*7672*00# This post Attachment apdu.txt is already replaced with new version. Just download and replace if you downloaded before. Last edited by :::GsmFather:::; 11-04-2017 at 09:04. |
10-26-2017, 18:36 | #2 (permalink) |
Member: 24066 Status: Offline Sonork: 100.9 Thanks Meter: 574 | For update with Updater can refer to this post. http://forum.gsmhosting.com/vbb/f102...ained-2235577/ |
11-01-2017, 09:57 | #6 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | how to update using apdu.txt downloaded https://ufile.io/pfdgu update success now after *5005*7672*00# press Green call button. i got setting failed service centre address no address this step is not working (3. Select General unlock) after dialing *5005*7672*00# need help where to select apdu.txt in updater Last edited by sunny_luthras99; 11-01-2017 at 10:02. |
11-01-2017, 16:36 | #7 (permalink) | |
Member: 24066 Status: Offline Sonork: 100.9 Thanks Meter: 574 | Quote:
Put apdu.txt in same folder as downloader. Refer This video https://www.youtube.com/watch?v=zZcZBnEEYqc Give Below details if failed. Model: ios version : Network and country of Your Sim: Network and country of locked iphone: Error Message: | |
11-02-2017, 12:28 | #9 (permalink) |
Member: 1066865 Status: Offline Thanks Meter: 593 | Model: ip6plus 2pcs ios version : 11.0 , 11.0.1 Network and country of Your Sim:airtel india 128k sim (also tried vodafone , jio , idea) Network and country of locked iphone:fido canada other bell canada Error Message: after *5005*7672*00# press Green call button. i got this setting failed service centre address no address General unlock option dssnt appear |
11-12-2017, 16:24 | #11 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Europe
Member: 2075739 Status: Offline Sonork: 100.1640499 Thanks Meter: 237 | I got no network, no matter what settings tried. Also, seems that after that soft is flashed it cannot flash anything else - reader doesn't recognize the card any more. |
11-13-2017, 11:28 | #12 (permalink) | |
Insane Poster Join Date: Aug 2005 Location: Spain Age: 41
Member: 172407 Status: Offline Thanks Meter: 0 | Quote:
