Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GF WebShop > GF SIM
Old 10-26-2017, 18:21   #1 (permalink)
:::GsmFather:::'s Avatar
Member: 24066
Sonork: 100.9
Thanks Meter: 574
New Version To unlock iphone with GFSIM
Here is new version v3.0 BETA
Update GFSIM
1.Download apdu file from this post attachement. (Make sure to put downloader and apdu.txt file in same folder.)
2.Update using downloader Link https://ufile.io/pfdgu
You need usb dongle updater for this.
Put GFSIM along with Gsm Sim.
When you Power on you will see on iphone
"Activation Required" ? Dismiss it.
1. Go to emergency call and dial
2. *5005*7672*00# press Green call button.
3. Select General unlock
4. Select Operator from the list or manually input imsi if network not listed
5. It will unlock the phone. wait for 10-15 seconds to autorefresh it self.
Some time it takes you to activation screen again, just wait it will refresh and show signal.
This method work with all models Except Intel baseband phone.
After Unlock
If no signal than go to "Settings" "Phone" "Sim Applications" "Carrier select" "Reset settings"
select operator again (or input imsi manualy if your operator not in list) Click "Accept"
It will show Activation Required, Click "Dismiss" and wait for the signal. (Step 5 above)
If still no signal. Reset "Reset Network settings" And start with Step 1.
This version is BETA. Modification will be made upon feedbacks.
Update 04-11-2017 Version GFSIM_v3_1_1102
Bug fixes where some users reported not showing unlock menu after input code *5005*7672*00#
This post Attachment apdu.txt is already replaced with new version. Just download and replace if you downloaded before.
The Following 2 Users Say Thank You to :::GsmFather::: For This Useful Post:
Old 10-26-2017, 18:36   #2 (permalink)
Member: 24066
Sonork: 100.9
Thanks Meter: 574
For update with Updater can refer to this post.
http://forum.gsmhosting.com/vbb/f102...ained-2235577/
Old 10-26-2017, 18:42   #3 (permalink)
Member: 105852
Thanks Meter: 2
can you sell updater/adapter please?
Old 10-27-2017, 09:19   #4 (permalink)
mobileman999's Avatar
Member: 380236
Thanks Meter: 21
Do we need to check it’s the intel baseband before doing or does it not harm it so will just fail to work ?
Sent from my iPhone using Tapatalk
Old 10-31-2017, 09:46   #5 (permalink)
Member: 2596108
Thanks Meter: 58
will your software update RSIM? as RSIM management seems to be screwing everyone
Old 11-01-2017, 09:57   #6 (permalink)
Member: 1066865
Thanks Meter: 593
how to update using apdu.txt
downloaded https://ufile.io/pfdgu
update success
now after *5005*7672*00# press Green call button.
i got
setting failed
service centre address
no address
this step is not working (3. Select General unlock) after dialing *5005*7672*00#
need help
where to select apdu.txt in updater
Old 11-01-2017, 16:36   #7 (permalink)
Member: 24066
Sonork: 100.9
Thanks Meter: 574
update success
i got
setting failed
no address
need help
Put apdu.txt in same folder as downloader.
Refer This video https://www.youtube.com/watch?v=zZcZBnEEYqc
Give Below details if failed.
Model:
ios version :
Network and country of Your Sim:
Network and country of locked iphone:
Error Message:
Old 11-01-2017, 16:37   #8 (permalink)
Member: 24066
Sonork: 100.9
Thanks Meter: 574
Cannot. We use Different IC.
Old 11-02-2017, 12:28   #9 (permalink)
Member: 1066865
Thanks Meter: 593
Model: ip6plus 2pcs
ios version : 11.0 , 11.0.1
Network and country of Your Sim:airtel india 128k sim (also tried vodafone , jio , idea)
Network and country of locked iphone:fido canada other bell canada
Error Message: after *5005*7672*00# press Green call button.
i got this
setting failed
no address
General unlock option dssnt appear
Old 11-11-2017, 00:38   #10 (permalink)
Member: 380236
Thanks Meter: 21
Any update on beta software will it go to final release next where no manual typing required ?
Old 11-12-2017, 16:24   #11 (permalink)
Member: 2075739
Sonork: 100.1640499
Thanks Meter: 237
I got no network, no matter what settings tried.
Also, seems that after that soft is flashed it cannot flash anything else - reader doesn't recognize the card any more.
Old 11-13-2017, 11:28   #12 (permalink)
Member: 172407
You have here a new version http://forum.gsmhosting.com/vbb/f102...fixes-2282698/
Old 11-20-2017, 12:32   #13 (permalink)
slim_j's Avatar
Member: 1029079
Thanks Meter: 61
why do i get open card reader failed
Old 11-20-2017, 13:12   #14 (permalink)
Member: 24066
Sonork: 100.9
Thanks Meter: 574
Update GFSIM explained. See this post. Follow exact steps.
Page generated in 0.28615 seconds with 10 queries
