09-27-2017, 19:56 | #1 (permalink) |
Super Moderator Join Date: Dec 1999 Location: In EveryOne's Heart
Member: 824 Status: Online Thanks Meter: 25,138 | About Face ID advanced technology Learn how Face ID helps protect your information on your iPhone X. Much of our digital lives are stored on iPhone and it's important to protect that information. In the same way that Touch ID revolutionized authentication using a fingerprint, Face ID revolutionizes authentication using facial recognition. Face ID provides intuitive and secure authentication enabled by the state-of-the-art TrueDepth camera system with advanced technologies to accurately map the geometry of your face. With a simple glance, Face ID securely unlocks your iPhone X. You can use it to authorize purchases from the iTunes Store, App Store, iBooks Store, and payments with Apple Pay. Developers can also allow you to use Face ID to sign into their apps. Apps that already support Touch ID will automatically support Face ID. Advanced technologies The technology that enables Face ID is some of the most advanced hardware and software that we’ve ever created. The TrueDepth camera captures accurate face data by projecting and analyzing over 30,000 invisible dots to create a depth map of your face and also captures an infrared image of your face. A portion of the A11 Bionic chip's neural engine — protected within the Secure Enclave — transforms the depth map and infrared image into a mathematical representation and compares that representation to the enrolled facial data. Face ID automatically adapts to changes in your appearance, such as wearing cosmetic ****** or growing facial hair. If there is a more significant change in your appearance, like shaving a full beard, Face ID confirms your identity by using your passcode before it updates your face data. Face ID is designed to work with hats, scarves, glasses, contact lenses, and many ********es. Furthermore, it's designed to work indoors, ********, and even in total darkness. To start using Face ID, you need to first enroll your face. You may do this during the initial set up process, or at a later time by going to Settings > Face ID & Passcode. To unlock your iPhone X using Face ID, simply glance at it. Face ID requires that the TrueDepth camera sees your face, whether your iPhone X is lying on a surface or you're holding it in a natural position. The TrueDepth camera has a similar range of view as when you take a photo or make a FaceTime call with the front camera. Face ID works best when the device is arm’s length or less from your face (25-50 cm away from your face). The TrueDepth camera is intelligently activated; for example, by raising to wake your iPhone X, tapping to wake your screen, or from an incoming notification that wakes the screen. Each time you unlock your iPhone X, the TrueDepth camera recognizes you by capturing accurate depth data and an infrared image. This information is matched against the stored mathematical representation to authenticate. Security safeguards Security is important to all of us to protect information on our devices. We have done some important things to safeguard your information, the same way we did with Touch ID. Face ID uses the TrueDepth camera and machine learning for a secure authentication solution. Face ID data - including mathematical representations of your face - is encrypted and protected with a key available only to the Secure Enclave. The probability that a random person in the population could look at your iPhone X and unlock it using Face ID is approximately 1 in 1,000,000 (versus 1 in 50,000 for Touch ID). As an additional protection, Face ID allows only five unsuccessful match attempts before a passcode is required. The statistical probability is different for twins and siblings that look like you and among children under the age of 13, because their distinct facial features may not have fully developed. If you're concerned about this, we recommend using a passcode to authenticate. Face ID matches against depth information, which isn’t found in print or 2D digital photographs. It's designed to protect against spoofing by masks or other techniques through the use of sophisticated anti-spoofing neural networks. Face ID is even attention-aware. It recognizes if your eyes are open and looking towards the device. This makes it more difficult for someone to unlock your iPhone without your knowledge (such as when you are sleeping). To use Face ID, you must set up a passcode on your iPhone. You must enter your passcode for additional security validation when:
Privacy Privacy is incredibly important to Apple. Face ID data - including mathematical representations of your face - is encrypted and protected by the Secure Enclave. This data will be refined and updated as you use Face ID to improve your experience, including when you successfully authenticate. Face ID will also update this data when it detects a close match but a passcode is subsequently entered to unlock the device. Face ID data doesn’t leave your device and is never backed up to iCloud or anywhere else. Only in the case that you wish to provide Face ID diagnostic data to AppleCare for support will this information be transferred from your device. And even in this case, data isn’t automatically sent to Apple; you can first review and approve the diagnostic data before it’s sent. If you choose to enroll in Face ID, you can control how it's used or disable it at any time. For example, if you don’t want to use Face ID to unlock your iPhone, open Settings > Face ID & Passcode > Use Face ID, and disable iPhone Unlock. To disable Face ID, open Settings > Face ID & Passcode, and tap Reset Face ID. Doing so will delete Face ID data, including mathematical representations of your face, from your device. If you choose to erase or reset your device using Find My iPhone or erasing all content and settings, all Face ID data will be deleted. Even if you don’t enroll in Face ID, the TrueDepth camera intelligently activates to support attention aware features, like dimming the display if you aren't looking at your iPhone or lowering the volume of alerts if you're looking at your device. For example, when using Safari, your device will check to determine if you're looking at your device and turns the screen off if you aren’t. If you don’t want to use these features, you can open Settings > General > Accessibility, and disable Attention Aware Features. Within supported apps, you can enable Face ID for authentication. Apps are only notified as to whether the authentication is successful. Apps can’t access Face ID data associated with the enrolled face. Safety iPhone and the TrueDepth camera system have been thoroughly tested and meet international safety standards. The TrueDepth camera system is safe to use under normal usage conditions. The system will not cause any harm to eyes or skin, due to its low output. It's important to know that the infrared emitters could be damaged during repair or disassembly, so your iPhone should always be serviced by Apple or an authorized service provider. The TrueDepth camera system incorporates tamper-detection features. If tampering is detected, the system may be disabled for safety reasons. When viewed through certain types of cameras, you may notice light output from the TrueDepth camera. This is expected as some cameras may detect infrared light. Some may also notice a faint light output from the TrueDepth camera when viewed in a very dark room. This is expected in extremely dark settings. Accessibility Accessibility is an integral part of Apple products. Users with physical limitations can select “Accessibility Options” during enrollment that doesn't require the full range of head motion to capture different angles and is still secure to use but requires more consistency in how you look at iPhone X. Face ID also has an accessibility feature to support individuals who are blind or have low vision. If you don't want Face ID to require that you look with your eyes open at iPhone X, you can open Settings > General > Accessibility, and disable Require Attention for Face ID. This is automatically disabled if you enable VoiceOver during initial set up.
__________________ Just Follow the Rules and Be Polite Saying "thank you" can be hard. But it's so important. Last edited by mihut; 10-01-2017 at 13:19. |
The Following 32 Users Say Thank You to mihut For This Useful Post: |
10-26-2017, 10:26 | #2 (permalink) |
Crazy Poster Join Date: May 2017 Location: shenzhen
Member: 2713523 Status: Offline Thanks Meter: 15 | Don' t worry the unlock performance, Face ID can keep pace with the natural changes of your face, because the Face ID augments its stored mathematical representation over time. These Face ID data allow Face ID to keep up with dramatic changes in your facial hair or ****** use, while minimizing false acceptance. It follows, we will introduce the detail of iPhone on the highlights from Apple' s document. How to scan your face? It has 30,000 infrared dots form a depth map of the face along a 2D infrared image. The data is used to create a sequence of 2D images and depth maps which are digitally signed and sent to the Secure Enclave. The system will rescan your face and update the information every time it considers it necessary to do so without prompting the user, likely when certain facial changes are determined as worthy of a data upgrade. And the system works in all lighting conditions, regardless of whether you’re ******** or indoors. Is It a Fast Scan? Apple says Face ID will help you use a more complex password on the iPhone X without having to worry about typing too often. “Face ID doesn' t replace your passcode, but provides easy access to iPhone X within thoughtful boundaries and time constraints,” Apple says, which implies that Face ID functionality should be at least as fast as Touch ID. Is Encryption Safe? The answer is yes, Face ID will encrypt your iphone, just like Touch ID and regular passwords. When Can't Open The Face ID? Here are all the cases where a Face ID unlock will not work: ♦ The device has just been turned on or restarted. ♦ The device hasn’t been unlocked for more than 48 hours. ♦ The passcode hasn’t been used to unlock the device in the last 156 hours, and Face ID has not unlocked the device in the last 4 hours. ♦ The device has received a remote lock command. ♦ After five unsuccessful attempts to match a face. Is It Works in Apps? Face ID will work everywhere like the Touch ID. You will be able to unlock your device and portions of apps, and you can use it to authenticate secure transactions. Is It Works in Apple Pay? It reported that Apple Pay works with Face ID. When you pay in stores, you must authenticate by double-clicking the power button before placing the phone near the payment reader. Then you can confirm the preferred payment method before you make the payment. So if you want to change card, you must Face ID once again. Face ID can be used to approve store purchases in iTunes Store, App Store, and iBook Store as well. Is It be opened at any time? If you want to use someone picture to open the iPhone X, the answer is no, because 2D images won' t work. Face ID significantly more secure than Touch ID (1 in 50,000). But the false will match grows at twins and children. On the other hand, when someone takes the phone away from you and points it to your face, there will unlock. But you can set the second failsafe that requires you to look at your phone in order to unlock it, which means your significant other can' t point the phone at your face while you' re asleep to read all your chats. It must check your eyes for attention to unlock, though you can choose to disable the feature to fast open the phone. More infoemation about phone repair tools and guides , you can choose Vip Fix Shop Team. |
The Following User Says Thank You to zhudy For This Useful Post: |
06-04-2018, 10:25 | #3 (permalink) |
Freak Poster Join Date: May 2018
Member: 2833946 Status: Offline Thanks Meter: 108 | Can iPhone x face ID still work after repair, you can see this article https://repairurphone.wordpress.com/...-after-repair/ |
The Following User Says Thank You to AmieeWhite For This Useful Post: |
09-08-2018, 07:50 | #4 (permalink) |
Freak Poster Join Date: Aug 2018 Location: China
Member: 2861866 Status: Offline Thanks Meter: 71 | Great share! there have one blog as good as your article, with about How To Fix iPhone X Face ID Not Working, wish it will help someone who in need. The blog source: https://blog.rewatechnology.com/fix-...d-not-working/ |
The Following User Says Thank You to Amanda0820 For This Useful Post: |
10-02-2018, 12:56 | #7 (permalink) | |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Quote:
The feature of Facial ID was first introduced on Iphone X and up. Facial ID will never work with iPhone 7 Plus, not even the 8, the face ID technology depends on both software and hardware. Apple iPhone 7 Plus don't have required hardware like infrared camera, proximity sensor, flood illuminator and dot projector. These hardware only available in iPhone X. Which means Face ID will never work on iPhone 7. | |
The Following User Says Thank You to lyes_albert For This Useful Post: |
09-10-2020, 05:06 | #13 (permalink) |
Freak Poster Join Date: Jun 2017 Location: USA
Member: 2730637 Status: Offline Thanks Meter: 101 | According to REWA LAB in their latest video, for face id problems related to the dot projector, we can fix the problem by transferring the encryption chip in the picture below. Has anyone tried this? |
09-21-2020, 04:21 | #14 (permalink) |
Member: 2730637 Status: Offline Thanks Meter: 101 | As we all know, iPhone X and later models can easily come with Face ID failure after being dropped or water damaged. However, it should also be noted that improper operation during daily repair might also bring damage to Face ID relevant components and therefore result in Face ID failure. |
