Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-23-2017, 10:33   #1 (permalink)
Member: 2494453
Thanks Meter: 200
Post How to Fix Bad iPhone 8 and iOS 11 Battery Life
Some iPhone 8 users are noticing rapid battery loss in situations where the battery shouldn’t be taking a significant hit. In some cases this may be related to a bad battery. In most cases though, it’s an app gone rogue or simply bad habits from the person behind the wheel.
This guide will take you through some potential fixes and some tips that will help if and when you start noticing weird drain on your iPhone 8 or iPhone 8 Plus.
Restart Your iPhone 8
Sometimes all it takes is a simple restart. If you start to notice odd battery drain on your iPhone 8 or iPhone 8 Plus, hold down the power button and power the device down.
Use Low Power Mode
In order to enable Low Power Mode head into your iPhone 8’s Settings > Battery > Low Power Mode > and toggle it On whenever you want to save a few battery percentage points and don’t want to turn Airplane Mode on.
You can also put a shortcut to Low Power Mode into Control Center. How to customize your Control Center on iOS 11?
Check Your Apps
Go into your Settings > Battery and take a look at the Battery Usage tool. The tool shows you the apps doing the most damage to your iPhone 8 or iPhone 8 Plus’ battery life.
More useful tips for iPhone 8 battery:
Check original post on 3uTools
The Following User Says Thank You to Supermarios For This Useful Post:
Old 11-15-2017, 04:49   #2 (permalink)
Crazy Poster
Member: 2713523
Thanks Meter: 15
Battery issue is very difficult, maybe need you disassembly it and fix it. Some tools you needed, you can try Vip Fix Shop Team.
Old 11-15-2017, 09:58   #3 (permalink)
Member: 2494453
Thanks Meter: 200
umm this is a tutorial actually
Old 11-21-2017, 09:51   #4 (permalink)
Member: 2494453
Thanks Meter: 200
you could find more useful tips from 3u website
Originally Posted by hoangphat_gsm View Post
Thank you verry good
You are welcome, you could find more useful tips from 3u website:www.3u.com
Old 12-16-2017, 05:10   #5 (permalink)
Crazy Poster
Member: 2713523
Thanks Meter: 15
If you need the mobile phone battery repair tools, you can choose Vip FIx Shop Team.
Page generated in 0.12742 seconds with 8 queries
