01-22-2019, 15:45 | #1 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2060417 Status: Offline Thanks Meter: 0 | iPhone 8 Power button not working Got this phone in the shop today, charging flex was replaced elsewhere. Now power button isn't working, tried known working power flex, nothing. Tried with iPower Pro, not working. Phone is turning on and working when connected to charger. Any clues ? Many thanks |
09-21-2020, 09:12 | #2 (permalink) |
Crazy Poster Join Date: Jul 2020 Location: China Age: 25
Member: 2964041 Status: Offline Thanks Meter: 3 | There are often 7 ways to solve your problem of iPhone 8 power button not working. Way 1: Hard restart your iPhone. Force restarting your phone will refresh the apps and software, cancelling any iOS errors. • Hold the 'Home' button and the 'Power' button concurrently, pressing them gently; • Then release both buttons once the Apple logo appears; • Let the iPhone boot up then test the 'Power' button once more. Way 2: Clean the Sides of the Button. Dust may also accumulate on your phone, including the 'Power' button region. Way 3: Turn on Assistive Touch. • Click on the 'Setting' option on the home screen; • Then go to 'Accessibility' and choose the 'Assistive Touch' option; • Next, enable it by toggling the switch to 'ON' status; • The 'Assistive Touch' button will then appear on your screen. You can now move it freely to any part of the screen as you hold, drag, or press it for any function. Way 4: Use Double-tap to Wake up iPhone. Way 5: Fix iPhone Power Button Not Working Efficiently and without data loss -- using professional iOS system recovery applications such as TunesKit iOS System Recovery. Step 1: Connect iPhone with computer and open the program, choose Standard mode and click next. Step 2: Check Download button and click the Download button. Step 3: Tap on the Repair button. Way 6: Reset Your iPhone. (data loss) |
The Following 2 Users Say Thank You to jys2020 For This Useful Post: |
06-09-2021, 00:49 | #3 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: singapore Age: 55
Member: 173565 Status: Offline Thanks Meter: 71 | Quote:
06-28-2021, 18:16 | #4 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | yow guys try to short pin number 8 to ground on connector j4300 thats where power button flex connection is going if you got power then replace new power flex or jump power switch on that point |
