11-01-2017, 15:08 | #1 (permalink) |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,712 | iPhone 8 and X: How to force restart, enter recovery-mode, and enter DFU mode [Video] To force restart (hard reset) the iPhone 8, press and release the Volume Up button, press and release the Volume Down button, and press and hold the Side button until your device reboots, then release. All three button presses should be done in relatively quick succession. After holding the Side button for about ten seconds, the iPhone will force restart. How to get into recovery-mode on iPhone 8 Step 1: Connect your iPhone 8 to your Mac or PC with a Lightning to USB cable. Step 2: Press and release the Volume Up button, press and release the Volume Down button, and press and hold the Side button until your device reboots. Continue holding the Side button, even after you see the Apple logo appear. Step 3: Release the Side button once you see the Connect to iTunes logo appear on the iPhone’s display. Step 4: Launch iTunes, and you should see a message stating that “There is a problem with the iPhone that requires it to be updated or restored.” From there, you can choose to Update or Restore your iPhone’s software. How to get into DFU mode on iPhone 8 Step 1: Connect your iPhone to your Mac or PC with a Lightning to USB cable. Step 2: Press and release the Volume Up button, press and release the Volume Down button, and press and hold the Side button for 10 seconds until the screen turns black. Step 3: While still holding the Side button, press and hold the Volume Down button for 5 seconds, and then release the Side button while continuing to hold the Volume Down button for another 10 seconds. The screen should remain black. Step 4: Launch iTunes, and you should see a message stating that “iTunes has detected an iPhone in recovery mode. You must restore this iPhone before it can be used with iTunes. How to exit recovery-mode or DFU mode on iPhone 8 As long as there are no problems with your iPhone, exiting out of recovery-mode or DFU mode is simple. To exit out of recovery-mode, press and hold the Side button until the Connect to iTunes logo disappears. To exit out of DFU mode, press and release the Volume Up button, press and release the Volume Down button, and press and hold the Side button until you see the Apple logo appear on screen (You can also use this for exiting recovery-mode if you just prefer to remember a single method). Video Tutorial: Source:9to5mac
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim |
The Following 28 Users Say Thank You to ...:::SHAMIM:::... For This Useful Post: |
01-21-2018, 21:15 | #2 (permalink) |
Freak Poster Join Date: Jul 2003
Member: 33954 Status: Offline Thanks Meter: 10 | hi how to enter in dfu mode from disabled iphone 8 from recovery i try and phoe still remaining disabled any advice will be welcome |
The Following User Says Thank You to NEGRIA For This Useful Post: |
12-03-2019, 13:47 | #7 (permalink) | |
Junior Member Join Date: Dec 2012 Location: hcm
Member: 1847836 Status: Offline Thanks Meter: 2 | Quote:
The Following 2 Users Say Thank You to tiengdung90 For This Useful Post: |
09-29-2020, 04:25 | #8 (permalink) |
Junior Member Join Date: Feb 2020 Location: Hong Kong
Member: 2949081 Status: Offline Thanks Meter: 1 | Thanks for sharing. For getting an iPhone out of or into recovery mode, I know another quick and free solution, which is using Joyoshare UltFix iPhone system recovery. I have used such a tool to get my recovery mode iPhone X back to normal in one click without data loss. |
