01-31-2018, 17:41 | #1 (permalink) |
Crazy Poster Join Date: Feb 2007
Member: 451774 Status: Offline Thanks Meter: 4 | Alcatel OT-5010D Reset FRP question [Solved] Platform: ALCATEL Selected model: OT-5010D Please, power phone OFF and connect USB cable. Searching for a phone. Please wait... Found phone on COM158 Detecting Chip Version... HW Chip: MT6580: 6580.0000 HW Version: 8A00.CA00.0000.0000 Connecting... Brom Version: 05 BootLoader Version: FE Searching Download Agent... Selected DA: MTK_AllInOne_DA_v3.3001.2017-09-06.13:15_388644, n.11 Sending Download Agent... DA sent successfully Initializing DA... Synchronizing with DA... NAND Flash: not installed eMMC Flash: .15010046.3732324D.4200F640.F44CB351 eMMC Flash: Samsung: F722MB DA ver: 4.2.9C Initializing Memory Flash.. Initializing Memory Flash failed! Operation was failed! Performed by 1.1.1 Software version. thank you for solution Last edited by Octopus box; 02-01-2018 at 14:33. |
02-01-2018, 07:06 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hi. You have connected the device with hold "Vol-" button. To connect the device You shouldn't press and hold "Vol-" button, just do as this is written in Software instruction: Quote:
02-01-2018, 13:17 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | What device appear in Windows Device Manager, when You connect powered off phone to PC? Also try to power on phone connect it to PC via USB cable and then power off the phone without unplugging cable, and check, what device appear in Device Manager. Write here the result. Also, You can contact us to Skype, we will check remotely. Our contacts You can find in our profile. |
02-01-2018, 14:30 | #5 (permalink) |
Member: 451774 Status: Offline Thanks Meter: 4 | hi, my problem is solved, i only try in another usb port ( usb port directly in motherboard ) and work in first time. thank you for all |
The Following User Says Thank You to kgste For This Useful Post: |
