05-11-2020, 15:28 | #1 (permalink) |
Banned Join Date: May 2006 Location: france
Member: 270730 Status: Offline Thanks Meter: 67 | frp a530f combinaison [Answered] Platform: SAMSUNG Selected model: SM-A530F Please put the phone into Download Mode and connect USB cable. To put SM-A530F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing Firmware Failed Performed by 1.8.9.0 Software version. Selected AP file: F:\flash\octopus\COMBINATION_OXM_FA71_A530FXXU2ARB 2_OXM_CL13050604_QB16878804_REV00_user_mid_noship. tar.md5 Platform: SAMSUNG Selected model: SM-A530F Please put the phone into Download Mode and connect USB cable. To put SM-A530F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing Firmware Failed Performed by 1.8.9.0 Software version. |
05-12-2020, 07:38 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Problem with reset of FRP lock can occur if phone has one of the latest firmwares. Samsung disabled ability to remove FRP lock in latest firmwares. There are few methods, of how to reset FPR on phones with latest firmwares: I. Try to use our Factory Reset FRP Service. For more detail information and prices, please check Credits consumption II. Try to write SBoot file of older firmware. Repeat "Reset FRP/Reactivation/EE" operation. III. Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check partitions except "boot.img"). Perform "Reset FRP" operation in Software. IV. Write Full Combination Firmware. Go to "Developer Options" in phone Settings. Check "Enable OEM unlock" option. Make Factory Data Reset. Reflash the phone with full stock (orignal) firmware. Note: "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! |
05-12-2020, 12:19 | #3 (permalink) |
Member: 270730 Status: Offline Thanks Meter: 67 | whats solution a105fn and a530f? Selected interface: UART Note: Type *#0*# on the phone and connect UART cable. Searching for device. Please wait... Found device on COM12 Reading info... Device model: SM-A105FN Device IMEI: 3540.................. MSL address: R58MC42ALF FRP/Reactivation: TRIGGERED Connecting to server.. Username: gsmbourges Authorization.. Checking smart card... Smart card successfully checked. Checking balance.. Your balance: 430 credits. Sending device information.. Checking operation... Checking data.. Reading FRP/Reactivation lock data.. Service is busy! Please try again later! Performed by 1.8.9.0 Software version. |
05-12-2020, 12:44 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
