06-24-2019, 23:29 | #1 (permalink) |
Junior Member Join Date: Jun 2019 Location: Winnipeg
Member: 2913862 Status: Offline Thanks Meter: 0 | FRP not working with dongle/software [Solved] Platform: SAMSUNG Selected model: SM-T280 Selected port: COM15 To put SM-T280 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..not supported Resetting EE lock..not supported Resetting Samsung Account lock..not supported Operation was failed! Performed by 1.7.5.0 Software version. Any help would be appreciated |
06-25-2019, 05:35 | #3 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Canada Age: 44
Member: 169896 Status: Offline Thanks Meter: 321 | Quote:
Sent from my SM-G965W using Tapatalk | |
06-25-2019, 08:10 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Hello. Problem with reset of FRP lock can occur if phone has one of the latest firmwares. Samsung disabled ability to remove FRP lock in latest firmwares. There are few methods, of how to reset FPR on phones with latest firmwares: I. Try to write SBoot file of older firmware. Repeat "Reset FRP/Reactivation/EE" operation. II. Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check partitions except "boot.img"). Perform "Reset FRP" operation in Software. III. Write Full Combination Firmware. Go to "Developer Options" in phone Settings. Check "Enable OEM unlock" option. Make Factory Data Reset. Reflash the phone with full stock (orignal) firmware. Note: "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! If neither of these methods helps, or necessary files are missing, You can use Factory Reset FRP Service. Last edited by Octopus box; 07-13-2019 at 08:39. |
07-12-2019, 19:30 | #5 (permalink) |
Member: 2913862 Status: Offline Thanks Meter: 0 | Hello, sorry I was very busy and hadn't time to check this until now.. Still no luck. I have tablets, and they have been wiped already or reformatted. So I am at setup screen |
07-12-2019, 21:22 | #6 (permalink) |
Member: 2913862 Status: Offline Thanks Meter: 0 | Platform: SAMSUNG Selected model: SM-T280 To put SM-T280 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..not supported Resetting EE lock..not supported Resetting Samsung Account lock..not supported Operation was failed! Performed by 1.7.6.0 Software version. Not trying to sound like a dink, but I payed money for this and it hasn't performed in any way..... |
07-12-2019, 21:34 | #7 (permalink) |
Member: 2913862 Status: Offline Thanks Meter: 0 | Platform: __GENERAL RESET FRP METHODS Selected model: ADB Searching for a phone (waiting for ADB device)... Phone found. Reading info... Phone model: SW version: Android version: Resetting FRP lock.. Operation was failed! Performed by 1.7.6.0 Software version. |
07-13-2019, 08:41 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Quote:
As we told You, before, try to use one of these methods: To Enable ADB and Reset FRP lock you can try to do the following: I. 1. Write "boot.img" partition from appropriate Combination firmware. 2. Perform "Reset FRP ADB (Combination)" operation in the software II. 1. Write full combination firmware. 2. Enable ADB from settings 3. Write stock firmware without "recovery.img", "cache.img", and "userdata" partitions. III. 1. Write full Combination firmware. 2. Go to "Developer Options" in the phone’s Settings. 3. Check "Enable OEM unlock" option. 4. Perform Factory Data Reset. 5. Re-flash the phone with full stock (original) firmware. Note: "boot.img" from combination firmware can be not compatible with current phone's firmware. In that case phone will stuck on logo, or will be rebooting after writing of such boot. To restore the phone to its initial condition you need to re-flash it with different full stock (original) firmware (or try to write only boot of such firmware). Note: You can write "boot.img" combination firmware or to downgrade phone's firmware version only on your own risk! PS: If you cannot find combination firmware for your model inside «SAMSUNG/COMBINATION" folder in Support Area, this means we don’t have this files at the moment. | |
