Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus FRP Tool
Old 06-24-2019, 23:29   #1 (permalink)
Member: 2913862
Smile FRP not working with dongle/software [Solved]
I am new to this, I have read what I can, but nothing helps Got the FRP unlocker dongle and installed software bought activation key and I am trying to unlock FRP but I keep getting this error ( my model says it is supported )
Platform: SAMSUNG
Selected model: SM-T280
Selected port: COM15
To put SM-T280 into Download Mode, You have to perform the following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" + "Home" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Searching for a phone. Please wait...
Phone found.
Initializing..
Resetting FRP lock..not supported
Resetting EE lock..not supported
Resetting Samsung Account lock..not supported
Operation was failed!
Performed by 1.7.5.0 Software version.
Any help would be appreciated
Old 06-25-2019, 01:09   #2 (permalink)
Member: 2913862
Update. I tried different model tablets. Sm-t377w and it said FRP sucess unlock but still locked.... ???!?!?!1
Old 06-25-2019, 05:35   #3 (permalink)
Member: 169896
Thanks Meter: 217
Platform: SAMSUNG
Phone found.
Initializing..
Either choose T813 and select via frp via download mode or downgrade to lollipop 5.1 and use again T820 and do frp reset. It will be done
Sent from my SM-G965W using Tapatalk
Old 06-25-2019, 08:10   #4 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 23,826
Hello.
Problem with reset of FRP lock can occur if phone has one of the latest firmwares. Samsung disabled ability to remove FRP lock in latest firmwares.
There are few methods, of how to reset FPR on phones with latest firmwares:
I.
Try to write SBoot file of older firmware.
Repeat "Reset FRP/Reactivation/EE" operation.
II.
Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check partitions except "boot.img").
Perform "Reset FRP" operation in Software.
III.
Write Full Combination Firmware.
Go to "Developer Options" in phone Settings.
Check "Enable OEM unlock" option.
Make Factory Data Reset.
Reflash the phone with full stock (orignal) firmware.
Note: "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares).
Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk!
If neither of these methods helps, or necessary files are missing, You can use Factory Reset FRP Service.
Old 07-12-2019, 19:30   #5 (permalink)
Member: 2913862
Hello, sorry I was very busy and hadn't time to check this until now.. Still no luck.
I have tablets, and they have been wiped already or reformatted. So I am at setup screen
Old 07-12-2019, 21:22   #6 (permalink)
Member: 2913862
Platform: SAMSUNG
Phone found.
Initializing..
Performed by 1.7.6.0 Software version.
Not trying to sound like a dink, but I payed money for this and it hasn't performed in any way.....
Old 07-12-2019, 21:34   #7 (permalink)
Member: 2913862
Platform: __GENERAL RESET FRP METHODS
Selected model: ADB
Searching for a phone (waiting for ADB device)...
Phone found.
Reading info...
Phone model:
SW version:
Android version:
Old 07-13-2019, 08:41   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
As You can see from the Software log this method isn't supported for your phone's firmware version.
As we told You, before, try to use one of these methods:
To Enable ADB and Reset FRP lock you can try to do the following:
I.
1. Write "boot.img" partition from appropriate Combination firmware.
2. Perform "Reset FRP ADB (Combination)" operation in the software
II.
1. Write full combination firmware.
2. Enable ADB from settings
3. Write stock firmware without "recovery.img", "cache.img", and "userdata" partitions.
III.
1. Write full Combination firmware.
2. Go to "Developer Options" in the phone’s Settings.
3. Check "Enable OEM unlock" option.
4. Perform Factory Data Reset.
5. Re-flash the phone with full stock (original) firmware.
Note: "boot.img" from combination firmware can be not compatible with current phone's firmware. In that case phone will stuck on logo, or will be rebooting after writing of such boot. To restore the phone to its initial condition you need to re-flash it with different full stock (original) firmware (or try to write only boot of such firmware).
Note: You can write "boot.img" combination firmware or to downgrade phone's firmware version only on your own risk!
PS: If you cannot find combination firmware for your model inside ęSAMSUNG/COMBINATION" folder in Support Area, this means we don’t have this files at the moment.
Old Yesterday, 00:34   #9 (permalink)
Member: 2913862
Got it working... THANKS
Page generated in 0.13646 seconds with 7 queries
