04-15-2020, 10:24 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Ports***** UK Age: 44
Member: 126675 Status: Offline Thanks Meter: 13 | Google Pixel XL FRP problem [Answered] Code: Welcome to Octoplus FRP Tool v.1.8.7.0 Platform: GOOGLE Selected model: PIXEL XL Put the phone into Sideload Mode: 1. Remove SD and SIM cards from the phone; 2. Power phone OFF; 3. Press and hold "Vol-" and "Power" buttons; 4. Wait until the phone enter in FastBoot / Bootloader Mode; 5. Select Recovery Mode; 6. Press "Power" button and shortly press "Vol+"; 7. Select "Apply update from ADB". Searching for a phone (waiting for ADB / Fastboot device)... Phone found. Device serial number: HT7590200383 Selected firmware file: Google_Pixel_XL_Reset_FRP.oct Writing firmware... Operation was failed! Performed by 1.8.7.0 Software version. Code: Factory Reset... Go to "Vision Settings" -> "Talk Back" and enable it; On "TalkBack tutorial" window draw "L" gesture for showing "Global Context Menu"; Select "TalkBack Settings"; Scroll down with 2 fingers, find and disable "Explore by touch"; Scroll down further (with 2 fingers) and go to "Help & feedback"; Select "About Switch Access for Android"; Start playing "Switch Access for Android" video and click "Share" at the right side of video; Hit 3 horizontal dots ("…") and YouTube will open; Minimize video (slide it down), then click on 3 vertical dots at the right upper screen corner (or on account image) and go to "Terms & privacy policy"; Press "ACCEPT & CONTINUE", then "NO THANKS" and now you are in Chrome browser; Type in url line "goo.gl/k7NVE1" then update permissions (Chrome needs storage access to download files) -> "CONTINUE" -> ("Allow Chrome to access photos, media, and files on your device?") -> "ALLOW". As a result, "FRP Bypass" App will be downloaded; Fast press "OPEN" to open the downloaded APK; Press "SETTINGS" in "Chrome…" window and enable option "Allow from this source", go back and press "INSTALL", and then press "OPEN". Now You are in "FRP Bypass" window; Press "Google Account Manager APK Install" and select (press) "FOR VERSION 5.0" (if necessary, modify Permissions); After APP will be installed, press "ByPass FRP" -> "BROWSER SIGN IN" -> "3 vertical dots" -> "Browser sign-in" -> "OK"; Enter your Google Account (mail and password) and sing in, then wait about 30 seconds, APK will dispalay an error (Google Play services has stopped). Don’t press "Open app again"; Press and hold "Power ON" button and restart the phone; Go to "Users & accounts" in phone’s menu and remove account; Go to "System" -> "Reset options" and perform "Erase all data" (factory reset). |
