07-20-2018, 11:52 | #1 (permalink) |
Registered User Join Date: Feb 2016
Member: 2530239 Status: Offline Thanks Meter: 14 | Samsung SM-G610S Reset FRP question [Solved] Platform: SAMSUNG Selected model: SM-G610S Searching for UART interface.. COM12 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Operation was canceled Performed by 1.3.4.0 Software version. Platform: SAMSUNG Selected model: SM-G610S Searching for UART interface.. COM12 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation... This version of "sBoot" is not supported, try to downgrade "sBoot"! Operation was failed! Performed by 1.3.4.0 Software version. Last edited by Octopus box; 07-21-2018 at 08:41. |
07-20-2018, 14:21 | #2 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please read attentively Software log and update news: Quote:
1. Write only Sboot (not full firmware) from Android 6.x firmware. 2. Perform "Reset FRP" operation. 3. Write Sboot from Android 7.x firmware. | ||
07-21-2018, 06:10 | #3 (permalink) |
Member: 2530239 Status: Offline Thanks Meter: 14 | Samsung SM-G610S Reset FRP successfully done problem solve thnk you so much octopus team Welcome to Octoplus Box Samsung software version 2.6.9 ----------------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G610S Operation: Reset FRP - UART EMMC Searching for UART interface.. Found more then one box connected to COM12 COM12 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Operation was canceled Performed by 2.6.9 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-G610S Operation: Reset FRP - UART EMMC Searching for UART interface.. Found more then one box connected to COM12 COM12 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation...OK Searching for UART interface.. Found more then one box connected to COM12 COM12 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (1/4 attempt)..success FRP / Reactivation lock is successfully reseted! Performed by 2.6.9 Software version. Last edited by Octopus box; 07-21-2018 at 08:41. |
The Following User Says Thank You to mobileman2013 For This Useful Post: |
