12-05-2018, 01:28 | #1 (permalink) |
Freak Poster Join Date: Jul 2012
Member: 1787478 Status: Offline Thanks Meter: 22 | LG G6+ in Qualcomm...9008 mode after remove FRP [Answered] I've bricked two LG G6+ H872 after reset frp operation the problem happens cause I get problem with Qualcomm 9008 driver, it detected as Qbulk driver, then octoplus frp showed incoplete operation, so phones are blocked in qualcomm mode now and I install the right drivers now Can you help me please ? Last edited by Octopus box; 12-05-2018 at 05:45. |
12-05-2018, 05:46 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hi. Quote:
12-05-2018, 12:24 | #3 (permalink) |
Member: 1787478 Status: Offline Thanks Meter: 22 | I see now that I've choosed bad model , it was h870 and I've tried with h872 04/12/2018 19:46:19 > Checking data...04/12/2018 19:46:20 > OK 04/12/2018 19:46:20 > Platform: LG Qualcomm 04/12/2018 19:46:20 > Selected port: COM1107 04/12/2018 19:46:20 > Selected model: H872 04/12/2018 19:46:20 > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). 04/12/2018 19:46:20 > Reading info... 04/12/2018 19:46:22 > Model ID: LG-H870DSUH87020a 04/12/2018 19:46:22 > IMEI: 359653-08-040567-6 04/12/2018 19:46:22 > Android version: 8.0.0 04/12/2018 19:46:22 > Battery level: 63% 04/12/2018 19:46:22 > SW Version: 04/12/2018 19:46:22 > H87020a 04/12/2018 19:46:22 > Mode: Emergency 04/12/2018 19:46:22 > Initializing flash...04/12/2018 19:46:24 > OK 04/12/2018 19:46:25 > Platform: msm8996 04/12/2018 19:46:25 > SW version: 04/12/2018 19:46:25 > LGH870DSUAT-00-V20e-HKG-XX-SEP-21-2018+0 04/12/2018 19:46:25 > Android version: 8.0.0 04/12/2018 19:46:25 > LAF Version: 1.1 04/12/2018 19:46:25 > Product ID: HD60S170811000580 04/12/2018 19:46:25 > IMEI: 359653-08-040567-6 04/12/2018 19:46:25 > Target operator: GLOBAL 04/12/2018 19:46:25 > Hardware: rev_12 04/12/2018 19:46:25 > Reading partitions...04/12/2018 19:46:32 > OK 04/12/2018 19:46:32 > Reading BOOT... 04/12/2018 19:46:33 > ID: 0005F0E100310000 04/12/2018 19:46:33 > Operation is not safe and exist risk to damage the device! Do You want to continue?04/12/2018 19:46:53 > OK 04/12/2018 19:46:53 > Backup saved to "H872_359653080405676_04-12-2018_19-46-53.oct" 04/12/2018 19:46:53 > Switching to Qualcomm 9008 mode... 04/12/2018 19:48:20 > Found port COM397 04/12/2018 19:48:20 > Connecting...04/12/2018 19:48:20 > Failed! |
12-05-2018, 12:28 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To repair your device and do "Reset FRP" do the following: 1. Install the latest Software version (https://octoplusbox.com/en/download/software/). 2. Select LG H872 in the list of Software. 3. Select backup file "H872_359653080405676_04-12-2018_19-46-53.oct" into the Firmware slot in Software. 4. Press "Reset FRP via TP (Qualcomm Mode)" button in Software, install Qualcomm HSHUSB driver and write backup file. 5. Post here the result. Then perform "Reset FRP" operation again. |
11-22-2019, 08:56 | #5 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Middle-Earth
Member: 190274 Status: Offline Thanks Meter: 47 | I have two of the same phones that i got from a customer. He says he used frp reset operation on octoplus and had the same issue. Backup is not available because he formatted his pc. Is there any solution in this case? |
11-22-2019, 09:12 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If your device still in 9008 Mode, then You can try to repair your device with Medusa Pro Software via Factory Repair operation |
