05-08-2020, 11:41 | #1 (permalink) | |
Registered User Join Date: Sep 2009 Location: Philippines
Member: 1129019 Status: Offline Sonork: first aider Thanks Meter: 19 | Nokia TA-1075 cant flash [Solved] Quote:
when writing firmware,it takes about second then finish but nothing happens.PLS HELP thank YOU | |
05-08-2020, 11:52 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Where did You get that firmware? Please, check maybe that firmware is available at our Support Area, download it and try to write it |
05-08-2020, 12:15 | #3 (permalink) | |
Member: 1129019 Status: Offline Sonork: first aider Thanks Meter: 19 | Quote:
here is the picture https://ibb.co/CJVzqmf | |
05-08-2020, 13:39 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please, send us *.log and *.logx files, we gonna research where can be the problem and inform You about possible solutions here |
05-08-2020, 14:06 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to restart Software after repeat Write Firmware operation again, we've tested on ourr device and everything works fine |
05-09-2020, 00:27 | #7 (permalink) | ||
https://www.youtube.com/watch?v=EB-I...ture=********* | ||
05-09-2020, 04:57 | #8 (permalink) | ||
Member: 1129019 Status: Offline Sonork: first aider Thanks Meter: 19 | hi sir,there are only 2 file available in support , i finish download all 2 file with out errors, here it is https://ibb.co/kJ4b7t6 there here are the logs for version CO2-038E-0-00WW-B02,phone retarting after flashed Quote:
05-10-2020, 09:21 | #9 (permalink) |
Member: 1129019 Status: Offline Sonork: first aider Thanks Meter: 19 | hello sir is there anyone here in support that can help me about your firmware in support ? because firmware in your wupport wont write (version CO2-3190-0-00WW-B05) i downloaded other files from google ,same version but different file .maybe can you help me convert this file so that i cant flash it in your software?thanks https://ibb.co/L9bYy5k |
05-12-2020, 09:19 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | We've re-uplaod CO2-3190-000WW-B05 firmware into the Support, please re-download it, after repeat operation again |
05-13-2020, 07:45 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please, try to download firmware via browser, press Go to Support Area button in Software |
05-14-2020, 00:29 | #14 (permalink) | |
thank you sir.i successfully download the files and also success in flashing but ,problem still occurs .i think i will return now this phone to the owner thank you very much for your help and reply | |
