09-22-2018, 08:15 | #31 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
You need to use Combinatin firmware, please press "Help" button in Software and read carefully Software manual on how to activate ABD in the device and then perform "Reset FRP (ADB)" operation. | |
09-22-2018, 10:29 | #33 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @mobile mk Hello. Please select in Device vendor: General Reset FRP Method, and in Device model: MTK General and perform Read info operation, then post here full Software log of Read info operation. |
09-22-2018, 10:34 | #34 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @sizou Hello. Please try to select in Device model section: OPPO F7 and perfrom Reset FRP operation, post here results. |
09-22-2018, 10:45 | #35 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @murlica_123 Please select in Device vendor: General Reset FRP Method, and in Device model: Qualcomm EDL Autodetect and perform Read Info operation, post here results. Also Mi Account operation in test mode, this operation may be not working correctly. |
09-22-2018, 15:15 | #36 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | Redmi S2 FRP Reset Done!! Code: Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. Searching for a phone. Please wait... Found phone on COM21 Mode: Qualcomm 9008 Connecting... Reading info... QC HW ID: 000460E100000000 QC CPU: Snapdragon 625 MSM8953 Searching loader... Sending loaders... Loader send successfuly. Reconnecting... Checking request.. Reading partition... Reading info... Brand: xiaomi Model: Redmi S2 Device: ysl Android version: 8.1.0 Display ID: OPM1.171019.011 Searching for signatures... Resetting FRP lock.. FRP lock is successfully reseted! Rebooting phone Backup saved as XIAOMI_REDMI S2_22-09-2018_18-10-20.dump file Performed by 1.4.2.0 Software version. |
The Following User Says Thank You to WAJID PNR For This Useful Post: |
09-25-2018, 15:08 | #37 (permalink) | |
Insane Poster Join Date: Oct 2010
Member: 1414572 Status: Offline Thanks Meter: 19 | Oukitel K10000 Pro Quote:
09-25-2018, 15:24 | #38 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please select "Oukitel K10000 Pro" in the list of Software and perform "Reset FRP" operation, no need to use general method. |
09-25-2018, 19:07 | #39 (permalink) | ||
Member: 1414572 Status: Offline Thanks Meter: 19 | Quote:
09-25-2018, 19:57 | #41 (permalink) | |
made using these files from the firmware.. (With the volume held down + Last edited by yurii-62; 09-25-2018 at 20:06. | |
The Following User Says Thank You to yurii-62 For This Useful Post: |
09-26-2018, 08:17 | #44 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hi. If You still have these devices in hands, try to do the following: 1. Select "_General Methods" -> "QUALCOMM autodetect". 2. Power off the device, press and hold "Vol+" and "Vol-" and connect USB cable (or put into "Qualcomm..9008" Mode via other method). 3. Perform "Read info" ("Reset FRP") operation and post here full Software log. |
