04-23-2019, 19:06 | #1 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | A kind of UART cable working with Octoplus It is sold as 2019 Newest Octoplus FRP USB UART 2 in 1 Cable( micro+type c ). Thanks. |
04-23-2019, 19:46 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
https://gsmserver.com/octoplus-micro...530k-resistor/ To use it, the rj45 part for box and the usb 2 part must be connected to the phone jack, watch the video and see how it works using frp reset using the uart cable method Reset Frp method ufs memory via uart cable: https://www.youtube.com/watch?v=eA8ClrrQYs8 Reset Frp method emmc memory via cable uart: https://www.youtube.com/watch?v=-b4NWQZEwVA Now that to reset the FRP only with the UFS memory method via UART cable only works on Android 6.0.1 and Android 7, to reset FRP on Android 8 you need to install the combination then reset the FRP with the UFS cable UART memory method , otherwise it will not reset without a combination if the phone has Android 8 installed Last edited by amleto90; 04-23-2019 at 19:51. | |
The Following User Says Thank You to amleto90 For This Useful Post: |
04-24-2019, 02:13 | #4 (permalink) | |
I put the link and see how the uart cable is made, you can't use a uart cable if you don't have the rj45 socket for the box Look cable uart rj45 c3300k- 530k resistor https://gsmserver.com/octoplus-micro...530k-resistor/ | |
