10-07-2019, 08:51 | #1 (permalink) |
No Life Poster Join Date: Nov 2016 Location: iran tehran 021
Member: 2643931 Status: Offline Sonork: ****** Thanks Meter: 225 | redmi note 7 unlockbootloader error [Answered] Platform: XIAOMI Selected model: REDMI NOTE 7 Checking resource files... Please, select one of the options for "Unlock Bootloader" operation or press Ok to continue... WARNING: If Your device froze after "Unlock Bootloader" operation was completed, then You can try to reflash it with stock firmware. Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. No diagnostic ports found! Operation was failed! Performed by 1.8.0.0 Software version. Platform: XIAOMI Selected model: REDMI NOTE 7 Checking resource files... Please, select one of the options for "Unlock Bootloader" operation or press Ok to continue... WARNING: If Your device froze after "Unlock Bootloader" operation was completed, then You can try to reflash it with stock firmware. Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. Found phone on COM859 Mode: Qualcomm 9008 Connecting... Backup saved as XIAOMI_REDMI NOTE 7_07-10-2019_15-46-43.dump file Operation was failed! Performed by 1.8.0.0 Software version. Platform: XIAOMI Selected model: REDMI NOTE 7 Checking resource files... Please, select one of the options for "Unlock Bootloader" operation or press Ok to continue... WARNING: If Your device froze after "Unlock Bootloader" operation was completed, then You can try to reflash it with stock firmware. Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. Found phone on COM859 Mode: Qualcomm 9008 Connecting... Backup saved as XIAOMI_REDMI NOTE 7_07-10-2019_15-47-11.dump file Operation was failed! Performed by 1.8.0.0 Software version. Platform: XIAOMI Selected model: REDMI NOTE 7 Checking resource files... Please, select one of the options for "Unlock Bootloader" operation or press Ok to continue... WARNING: If Your device froze after "Unlock Bootloader" operation was completed, then You can try to reflash it with stock firmware. Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. Found phone on COM859 Mode: Qualcomm 9008 Connecting... Reading info... QC HW ID: 000950E100720000 QC CPU: UnckNow QC SW VER: 00000001 Searching loader... Sending loaders... Could not write loader! Backup saved as XIAOMI_REDMI NOTE 7_07-10-2019_15-48-42.dump file Performed by 1.8.0.0 Software version. Platform: XIAOMI Selected model: REDMI NOTE 7 Checking resource files... Please, select one of the options for "Unlock Bootloader" operation or press Ok to continue... WARNING: If Your device froze after "Unlock Bootloader" operation was completed, then You can try to reflash it with stock firmware. Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. Found phone on COM859 Mode: Qualcomm 9008 Connecting... Reading info... QC HW ID: 000950E100720000 QC CPU: UnckNow QC SW VER: 00000001 Searching loader... Sending loaders... Could not write loader! Backup saved as XIAOMI_REDMI NOTE 7_07-10-2019_15-49-39.dump file Performed by 1.8.0.0 Software version. |
10-07-2019, 12:35 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Unfortunately, Redmi note 7 Pro isn't supported, we are working on solution, stay tuned for future updates |
