09-12-2019, 20:59 | #1 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2761453 Status: Offline Thanks Meter: 1 | Removed Mi Acoount and blocked again when activated Wifi - Redmi 6 [Answered] How to do? You already used the credits. |
09-12-2019, 21:18 | #2 (permalink) | |
Member: 2761453 Status: Offline Thanks Meter: 1 | Quote:
Platform: XIAOMI Selected model: REDMI 6 Please, select one of the options for "Reset Mi Account" operation or press Ok to continue... Go to "Wi-Fi Settings" and forget connected Wi-Fi network or perform Wipe Data from recovery Put the phone in FastBoot Mode: 1. Press and hold "Vol-" and "Power" buttons. 2. Wait until the phone enter in FastBoot Mode. 3. Connect USB cable. Connecting to server... Checking smart card... Username: 9roi38k Authorizing... Checking balance... Your balance: 50 credits. Checking operation... Operation successfully checked. Sending device information... Get credits, needed for current operation... Your balance: 50 credits. Need: 15 credits. Press and hold "vol+" and press OK buton. Searching for a phone. Please wait... Found phone on COM20 Detecting Chip Version... HW Chip: MT6762: 0766.0000 HW Version: 8A00.CA00.0000.0000 Connecting... Brom Version: 05 BootLoader Version: FE Sending auth... Sending Auth Data... Target Config: 0x000000E7 Start Authentication... Connecting to server..OK Authorizing...OK Initializing..OK Calculating... Authentication done! Searching Download Agent... Selected DA: MTK_AllInOne_DA_v3.3001.2018/04/19.10:40_426269, n.0 Sending Download Agent... DA sent successfully Initializing DA... Synchronizing with DA... Mobile Status: SYNC Mobile Status: brom Sending BootLoader Info... Initializing Memory Flash.. Initialization successfully completed Sending loaders... Mobile Status: SYNC Reading Flash Info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 29820 Mb eMMC Flash: .90014A68.42386150.3E013166.E13C45C9 eMMC Flash: Hynix: hB8aP> Internal RAM size: 256 Kb External RAM size: 768 Mb Reading partition... Reading info... Brand: xiaomi Model: Redmi 6 Device: cereus Android version: 8.1.0 Display ID: O11019 Resetting Mi Account... On Your device detected FRP Lock! Reset it? If "Yes" operation will cost as Reset FRP + Reset Mi Account operations. Get credits, needed for current operation... Your balance: 50 credits. Need: 30 credits. Reading MI part... Formating MI section Resetting FRP lock.. Please power phone ON and enable "USB Debugging" then press "OK" button! Searching for a phone (waiting for ADB device)... Please, press "OK" button on the phone to allow USB debugging.. Phone found. Reading info... Phone model: Xiaomi Redmi 6 SW version: O11019 Date: Fri Aug 23 10:28:12 WIB 2019 Android version: 8.1.0 Baseband MOLY.LR12A.R2.MP.V24.32.P142 Disabling Mi Services... Mi Account is successfully reseted! Backup saved as xiaomi_Redmi 6_12-09-2019_16-40-45.dump file Performed by 1.7.8.4 Software version. | |
09-13-2019, 18:21 | #6 (permalink) |
Member: 2761453 Status: Offline Thanks Meter: 1 | The first time I unlocked it, I turned off Developer Mode, and when I turned on Wifi, it locked again. So I believe I can't disable Developer Mode, correct? But can I disable USB Debugging only? Because with it active, a message appears on the screen. |
09-14-2019, 08:33 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, repeat Reset Mi accout operation, we've add You one more attempt Last edited by Octopus box; 09-14-2019 at 10:09. |
