10-04-2018, 16:53 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Follow Me If U Can
Member: 304251 Status: Offline Thanks Meter: 789 | Samsung SM-N910C Reset FRP problem [Answered] Platform: SAMSUNG Selected model: SM-N910C Reset FRP/ Reactivation lock operation for SM-N910C will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-N910C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Advanced mode! Firmware write started. Writing Custom section... Custom section has been written successfully. Firmware writing successfully completed. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 1.4.4.0 Software version. Platform: SAMSUNG Selected model: SM-N910C Searching for a phone (waiting for ADB device)... Reading info... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Resetting FRP lock.. FRP lock is successfully reseted! Goto "Menu->Settings->Backup and reset" and make "Factory data reset" Performed by 1.4.4.0 Software version. Platform: SAMSUNG Selected model: SM-N910C Searching for a phone (waiting for ADB device)... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Operation was failed! Performed by 1.4.4.0 Software version. Platform: SAMSUNG Selected model: SM-N910C Reset FRP/ Reactivation lock operation for SM-N910C will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-N910C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Advanced mode! Firmware write started. Writing Custom section... Custom section has been written successfully. Firmware writing successfully completed. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 1.4.4.0 Software version. but still locked Last edited by Octopus box; 10-05-2018 at 07:50. |
10-05-2018, 07:50 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Perform "Reset FRP" operation and follow Software prompts: Quote:
10-05-2018, 15:04 | #3 (permalink) | |
Member: 304251 Status: Offline Thanks Meter: 789 | Quote:
Platform: SAMSUNG Selected model: SM-N910C Reset FRP/ Reactivation lock operation for SM-N910C will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-N910C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Advanced mode! Firmware write started. Writing Custom section... Custom section has been written successfully. Firmware writing successfully completed. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 1.4.4.0 Software version. also still asked for google account ?? | |
10-06-2018, 08:25 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Yes, Reactivation Lock will remains. You can reset Reactivation Lock (also You can reset FRP lock) via Octoplus Samsung Factory Reset FRP / Reactivation Lock using Octoplus Suite Software. Operation is not free and require Octoplus Server Credits, please look here: http://forum.gsmhosting.com/vbb/f699...018-a-1747228/. |
10-06-2018, 15:21 | #7 (permalink) | |
Welcome to Octoplus Suite version 1.5.7 ------------------------------------------------------------------------------------------- Selected Vendor: Samsung Reactivation Lock Removal Service Model: Samsung Reactivation Lock Removal Service Delivery time: from 1 Hour to 12 Hour Getting additional info... OK Need credits: 70 Your balance: 100 To get more info about this service, please use "Information" button. ------------------------------------------------------------------------------------------- Selected vendor: Samsung Reactivation Lock Removal Service Selected model: Samsung Reactivation Lock Removal Service Checking input params...OK Connecting to server...OK Octopus smart card is not present. Username: vegasss81 Authorizing...OK Checking balance...OK Checking operation...OK Get credits, needed for current operation...OK Your balance: 100 credits. This operation will cost You 70 credits. Sending request to server...Failed! Internal Server Error (errCode:0002) | |
10-07-2018, 10:01 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | No, You use incorrect Service. Do the following - go to "Samsung" tab, slect any Samsung device model from the list of Software and press "Factory Services (Reset FRP / Unlock)" button. |
