Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products > NAND-PRO
Old 10-04-2018, 08:49   #1 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,712
IPAD AIR 2 isp detect
Build:Aug 27 2018 12:56:07
Device on COM103 is opened successfully
Firmware Version:FFFF201803082152
SN:3E3C12EC1344190081F2838062B7DEFB
CS0 ManuID:0x00002928270A2620 DevID:0xFFFFFFFFFF4E5050
CS1 ManuID:0xFFFFFFFFFFFFFFFF DevID:0xFFFFFFFFFFFFFFFF
NAND fw:052226P_SD_TLC2P
Banks per CE:4
Blocks per Bank:2096
Pages per block:258
Pages per block SLC:86
Page Size:16448
Default bits per cell:3
Address bits bits per cell:2
Address bits:-1 4 12 9
Chip Capacity:66.27GB
NAND IC CODE
SANDISK
SDMJLBCF4 - 0646
The Following 2 Users Say Thank You to MARVZ_TG For This Useful Post:
Old 10-04-2018, 09:05   #2 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,712
SDMJLBCF4 - 064G
sandisk nand ic
Old 10-05-2018, 00:40   #3 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,712
Cant read SN and write
The Following User Says Thank You to MARVZ_TG For This Useful Post:
Old 02-28-2019, 05:06   #4 (permalink)
Member: 757188
Thanks Meter: 22
I have the same problem as you.
The Following User Says Thank You to UFS+JAF For This Useful Post:
Old 03-08-2019, 06:11   #5 (permalink)
Member: 757188
Thanks Meter: 22
log detect ipad air 1. error.
NAND fw:041018P_SNDSK_19
Banks per CE:4
Blocks per Bank:1056
Pages per block:256
Pages per block SLC:128
Page Size:16448
Default bits per cell:2
Address bits:1 4 11 8
Mark:H2JTDG8UD1BMS 16G
Chip Capacity:33.13GB
Information at CE0 Bank3 Block0x0 Page0
Erase CE0 Bank3 Block0 error while writing info
Erase boot at CE0 Bank0 Block0x0 unsuccessfully.
Erase boot at CE0 Bank0 Block0x1 unsuccessfully.
Erase boot at CE0 Bank0 Block0x2 unsuccessfully.
Erase boot at CE0 Bank0 Block0x3 unsuccessfully.
Erase boot at CE0 Bank0 Block0x4 unsuccessfully.
Erase boot at CE0 Bank0 Block0x5 unsuccessfully.
Erase boot at CE0 Bank0 Block0x6 unsuccessfully.
Erase boot at CE0 Bank0 Block0x7 unsuccessfully.
Erase boot at CE0 Bank0 Block0x8 unsuccessfully.
Erase boot at CE0 Bank0 Block0x9 unsuccessfully.
Erase boot at CE0 Bank0 Block0xA unsuccessfully.
Erase boot at CE0 Bank0 Block0xB unsuccessfully.
Erase boot at CE0 Bank0 Block0xC unsuccessfully.
Erase boot at CE0 Bank0 Block0xD unsuccessfully.
Erase boot at CE0 Bank0 Block0xE unsuccessfully.
Erase boot at CE0 Bank0 Block0xF unsuccessfully.
Erase boot at CE0 Bank0 Block0x10 unsuccessfully.
Erase boot at CE0 Bank0 Block0x11 unsuccessfully.
Erase boot at CE0 Bank0 Block0x12 unsuccessfully.
Erase boot at CE0 Bank0 Block0x13 unsuccessfully.
Erase boot at CE0 Bank0 Block0x14 unsuccessfully.
Erase boot at CE0 Bank0 Block0x15 unsuccessfully.
Erase boot at CE0 Bank0 Block0x16 unsuccessfully.
Erase boot at CE0 Bank0 Block0x17 unsuccessfully.
Erase boot at CE0 Bank0 Block0x18 unsuccessfully.
Erase boot at CE0 Bank0 Block0x19 unsuccessfully.
Erase boot at CE0 Bank0 Block0x1A unsuccessfully.
Erase boot at CE0 Bank0 Block0x1B unsuccessfully.
Erase boot at CE0 Bank0 Block0x1C unsuccessfully.
Erase boot at CE0 Bank0 Block0x1D unsuccessfully.
Erase boot at CE0 Bank0 Block0x1E unsuccessfully.
Erase boot at CE0 Bank0 Block0x1F unsuccessfully.
Erase boot at CE0 Bank0 Block0x20 unsuccessfully.
Erase boot at CE0 Bank0 Block0x21 unsuccessfully.
Erase boot at CE0 Bank0 Block0x22 unsuccessfully.
Erase boot at CE0 Bank0 Block0x23 unsuccessfully.
Erase boot at CE0 Bank0 Block0x24 unsuccessfully.
Erase boot at CE0 Bank0 Block0x25 unsuccessfully.
Erase boot at CE0 Bank0 Block0x26 unsuccessfully.
Erase boot at CE0 Bank0 Block0x27 unsuccessfully.
Erase boot at CE0 Bank0 Block0x28 unsuccessfully.
Erase boot at CE0 Bank0 Block0x29 unsuccessfully.
Erase boot at CE0 Bank0 Block0x2A unsuccessfully.
Erase boot at CE0 Bank0 Block0x2B unsuccessfully.
Erase boot at CE0 Bank0 Block0x2C unsuccessfully.
Erase boot at CE0 Bank0 Block0x2D unsuccessfully.
Erase boot at CE0 Bank0 Block0x2E unsuccessfully.
Erase boot at CE0 Bank0 Block0x2F unsuccessfully.
Erase boot at CE0 Bank0 Block0x30 unsuccessfully.
Erase boot at CE0 Bank0 Block0x31 unsuccessfully.
Erase boot at CE0 Bank0 Block0x32 unsuccessfully.
Erase boot at CE0 Bank0 Block0x33 unsuccessfully.
Erase boot at CE0 Bank0 Block0x34 unsuccessfully.
Erase boot at CE0 Bank0 Block0x35 unsuccessfully.
Erase boot at CE0 Bank0 Block0x36 unsuccessfully.
Erase boot at CE0 Bank0 Block0x37 unsuccessfully.
Erase boot at CE0 Bank0 Block0x38 unsuccessfully.
Erase boot at CE0 Bank0 Block0x39 unsuccessfully.
Erase boot at CE0 Bank0 Block0x3A unsuccessfully.
Erase boot at CE0 Bank0 Block0x3B unsuccessfully.
Erase boot at CE0 Bank0 Block0x3C unsuccessfully.
Erase boot at CE0 Bank0 Block0x3D unsuccessfully.
Erase boot at CE0 Bank0 Block0x3E unsuccessfully.
Erase boot at CE0 Bank0 Block0x3F unsuccessfully.
Erase boot at CE0 Bank1 Block0x0 unsuccessfully.
Erase boot at CE0 Bank1 Block0x1 unsuccessfully.
Erase boot at CE0 Bank1 Block0x2 unsuccessfully.
Erase boot at CE0 Bank1 Block0x3 unsuccessfully.
Erase boot at CE0 Bank1 Block0x4 unsuccessfully.
Erase boot at CE0 Bank1 Block0x5 unsuccessfully.
Erase boot at CE0 Bank1 Block0x6 unsuccessfully.
Erase boot at CE0 Bank1 Block0x7 unsuccessfully.
Erase boot at CE0 Bank1 Block0x8 unsuccessfully.
Erase boot at CE0 Bank1 Block0x9 unsuccessfully.
Erase boot at CE0 Bank1 Block0xA unsuccessfully.
Erase boot at CE0 Bank1 Block0xB unsuccessfully.
Erase boot at CE0 Bank1 Block0xC unsuccessfully.
Erase boot at CE0 Bank1 Block0xD unsuccessfully.
Erase boot at CE0 Bank1 Block0xE unsuccessfully.
Erase boot at CE0 Bank1 Block0xF unsuccessfully.
Erase boot at CE0 Bank1 Block0x10 unsuccessfully.
Erase boot at CE0 Bank1 Block0x11 unsuccessfully.
Erase boot at CE0 Bank1 Block0x12 unsuccessfully.
Erase boot at CE0 Bank1 Block0x13 unsuccessfully.
Erase boot at CE0 Bank1 Block0x14 unsuccessfully.
Erase boot at CE0 Bank1 Block0x15 unsuccessfully.
Erase boot at CE0 Bank1 Block0x16 unsuccessfully.
Erase boot at CE0 Bank1 Block0x17 unsuccessfully.
Erase boot at CE0 Bank1 Block0x18 unsuccessfully.
Erase boot at CE0 Bank1 Block0x19 unsuccessfully.
Erase boot at CE0 Bank1 Block0x1A unsuccessfully.
Erase boot at CE0 Bank1 Block0x1B unsuccessfully.
Erase boot at CE0 Bank1 Block0x1C unsuccessfully.
Erase boot at CE0 Bank1 Block0x1D unsuccessfully.
Erase boot at CE0 Bank1 Block0x1E unsuccessfully.
Erase boot at CE0 Bank1 Block0x1F unsuccessfully.
Erase boot at CE0 Bank1 Block0x20 unsuccessfully.
Erase boot at CE0 Bank1 Block0x21 unsuccessfully.
Erase boot at CE0 Bank1 Block0x22 unsuccessfully.
Erase boot at CE0 Bank1 Block0x23 unsuccessfully.
Erase boot at CE0 Bank1 Block0x24 unsuccessfully.
Erase boot at CE0 Bank1 Block0x25 unsuccessfully.
Erase boot at CE0 Bank1 Block0x26 unsuccessfully.
Erase boot at CE0 Bank1 Block0x27 unsuccessfully.
Erase boot at CE0 Bank1 Block0x28 unsuccessfully.
Erase boot at CE0 Bank1 Block0x29 unsuccessfully.
Erase boot at CE0 Bank1 Block0x2A unsuccessfully.
Erase boot at CE0 Bank1 Block0x2B unsuccessfully.
Erase boot at CE0 Bank1 Block0x2C unsuccessfully.
Erase boot at CE0 Bank1 Block0x2D unsuccessfully.
Erase boot at CE0 Bank1 Block0x2E unsuccessfully.
Erase boot at CE0 Bank1 Block0x2F unsuccessfully.
Erase boot at CE0 Bank1 Block0x30 unsuccessfully.
Erase boot at CE0 Bank1 Block0x31 unsuccessfully.
Erase boot at CE0 Bank1 Block0x32 unsuccessfully.
Erase boot at CE0 Bank1 Block0x33 unsuccessfully.
Erase boot at CE0 Bank1 Block0x34 unsuccessfully.
Erase boot at CE0 Bank1 Block0x35 unsuccessfully.
Erase boot at CE0 Bank1 Block0x36 unsuccessfully.
Erase boot at CE0 Bank1 Block0x37 unsuccessfully.
Erase boot at CE0 Bank1 Block0x38 unsuccessfully.
Erase boot at CE0 Bank1 Block0x39 unsuccessfully.
Erase boot at CE0 Bank1 Block0x3A unsuccessfully.
Erase boot at CE0 Bank1 Block0x3B unsuccessfully.
Erase boot at CE0 Bank1 Block0x3C unsuccessfully.
Erase boot at CE0 Bank1 Block0x3D unsuccessfully.
Erase boot at CE0 Bank1 Block0x3E unsuccessfully.
Erase boot at CE0 Bank1 Block0x3F unsuccessfully.
Erase boot at CE0 Bank2 Block0x0 unsuccessfully.
Erase boot at CE0 Bank2 Block0x1 unsuccessfully.
Erase boot at CE0 Bank2 Block0x2 unsuccessfully.
Erase boot at CE0 Bank2 Block0x3 unsuccessfully.
Erase boot at CE0 Bank2 Block0x4 unsuccessfully.
Erase boot at CE0 Bank2 Block0x5 unsuccessfully.
Erase boot at CE0 Bank2 Block0x6 unsuccessfully.
Erase boot at CE0 Bank2 Block0x7 unsuccessfully.
Erase boot at CE0 Bank2 Block0x8 unsuccessfully.
Erase boot at CE0 Bank2 Block0x9 unsuccessfully.
Erase boot at CE0 Bank2 Block0xA unsuccessfully.
Erase boot at CE0 Bank2 Block0xB unsuccessfully.
Erase boot at CE0 Bank2 Block0xC unsuccessfully.
Erase boot at CE0 Bank2 Block0xD unsuccessfully.
Erase boot at CE0 Bank2 Block0xE unsuccessfully.
Erase boot at CE0 Bank2 Block0xF unsuccessfully.
Erase boot at CE0 Bank2 Block0x10 unsuccessfully.
Erase boot at CE0 Bank2 Block0x11 unsuccessfully.
Erase boot at CE0 Bank2 Block0x12 unsuccessfully.
Erase boot at CE0 Bank2 Block0x13 unsuccessfully.
Erase boot at CE0 Bank2 Block0x14 unsuccessfully.
Erase boot at CE0 Bank2 Block0x15 unsuccessfully.
Erase boot at CE0 Bank2 Block0x16 unsuccessfully.
Erase boot at CE0 Bank2 Block0x17 unsuccessfully.
Erase boot at CE0 Bank2 Block0x18 unsuccessfully.
Erase boot at CE0 Bank2 Block0x19 unsuccessfully.
Erase boot at CE0 Bank2 Block0x1A unsuccessfully.
Erase boot at CE0 Bank2 Block0x1B unsuccessfully.
Erase boot at CE0 Bank2 Block0x1C unsuccessfully.
Erase boot at CE0 Bank2 Block0x1D unsuccessfully.
Erase boot at CE0 Bank2 Block0x1E unsuccessfully.
Erase boot at CE0 Bank2 Block0x1F unsuccessfully.
Erase boot at CE0 Bank2 Block0x20 unsuccessfully.
Erase boot at CE0 Bank2 Block0x21 unsuccessfully.
Erase boot at CE0 Bank2 Block0x22 unsuccessfully.
Erase boot at CE0 Bank2 Block0x23 unsuccessfully.
Erase boot at CE0 Bank2 Block0x24 unsuccessfully.
Erase boot at CE0 Bank2 Block0x25 unsuccessfully.
Erase boot at CE0 Bank2 Block0x26 unsuccessfully.
Erase boot at CE0 Bank2 Block0x27 unsuccessfully.
Erase boot at CE0 Bank2 Block0x28 unsuccessfully.
Erase boot at CE0 Bank2 Block0x29 unsuccessfully.
Erase boot at CE0 Bank2 Block0x2A unsuccessfully.
Erase boot at CE0 Bank2 Block0x2B unsuccessfully.
Erase boot at CE0 Bank2 Block0x2C unsuccessfully.
Erase boot at CE0 Bank2 Block0x2D unsuccessfully.
Erase boot at CE0 Bank2 Block0x2E unsuccessfully.
Erase boot at CE0 Bank2 Block0x2F unsuccessfully.
Erase boot at CE0 Bank2 Block0x30 unsuccessfully.
Erase boot at CE0 Bank2 Block0x31 unsuccessfully.
Erase boot at CE0 Bank2 Block0x32 unsuccessfully.
Erase boot at CE0 Bank2 Block0x33 unsuccessfully.
Erase boot at CE0 Bank2 Block0x34 unsuccessfully.
Erase boot at CE0 Bank2 Block0x35 unsuccessfully.
Erase boot at CE0 Bank2 Block0x36 unsuccessfully.
Erase boot at CE0 Bank2 Block0x37 unsuccessfully.
Erase boot at CE0 Bank2 Block0x38 unsuccessfully.
Erase boot at CE0 Bank2 Block0x39 unsuccessfully.
Erase boot at CE0 Bank2 Block0x3A unsuccessfully.
Erase boot at CE0 Bank2 Block0x3B unsuccessfully.
Erase boot at CE0 Bank2 Block0x3C unsuccessfully.
Erase boot at CE0 Bank2 Block0x3D unsuccessfully.
Erase boot at CE0 Bank2 Block0x3E unsuccessfully.
Erase boot at CE0 Bank2 Block0x3F unsuccessfully.
Erase boot at CE0 Bank3 Block0x0 unsuccessfully.
Erase boot at CE0 Bank3 Block0x1 unsuccessfully.
Erase boot at CE0 Bank3 Block0x2 unsuccessfully.
Erase boot at CE0 Bank3 Block0x3 unsuccessfully.
Erase boot at CE0 Bank3 Block0x4 unsuccessfully.
Erase boot at CE0 Bank3 Block0x5 unsuccessfully.
Erase boot at CE0 Bank3 Block0x6 unsuccessfully.
Erase boot at CE0 Bank3 Block0x7 unsuccessfully.
Erase boot at CE0 Bank3 Block0x8 unsuccessfully.
Erase boot at CE0 Bank3 Block0x9 unsuccessfully.
Erase boot at CE0 Bank3 Block0xA unsuccessfully.
Erase boot at CE0 Bank3 Block0xB unsuccessfully.
Erase boot at CE0 Bank3 Block0xC unsuccessfully.
Erase boot at CE0 Bank3 Block0xD unsuccessfully.
Erase boot at CE0 Bank3 Block0xE unsuccessfully.
Erase boot at CE0 Bank3 Block0xF unsuccessfully.
Erase boot at CE0 Bank3 Block0x10 unsuccessfully.
Erase boot at CE0 Bank3 Block0x11 unsuccessfully.
Erase boot at CE0 Bank3 Block0x12 unsuccessfully.
Erase boot at CE0 Bank3 Block0x13 unsuccessfully.
Erase boot at CE0 Bank3 Block0x14 unsuccessfully.
Erase boot at CE0 Bank3 Block0x15 unsuccessfully.
Erase boot at CE0 Bank3 Block0x16 unsuccessfully.
Erase boot at CE0 Bank3 Block0x17 unsuccessfully.
Erase boot at CE0 Bank3 Block0x18 unsuccessfully.
Erase boot at CE0 Bank3 Block0x19 unsuccessfully.
Erase boot at CE0 Bank3 Block0x1A unsuccessfully.
Erase boot at CE0 Bank3 Block0x1B unsuccessfully.
Erase boot at CE0 Bank3 Block0x1C unsuccessfully.
Erase boot at CE0 Bank3 Block0x1D unsuccessfully.
Erase boot at CE0 Bank3 Block0x1E unsuccessfully.
Erase boot at CE0 Bank3 Block0x1F unsuccessfully.
Erase boot at CE0 Bank3 Block0x20 unsuccessfully.
Erase boot at CE0 Bank3 Block0x21 unsuccessfully.
Erase boot at CE0 Bank3 Block0x22 unsuccessfully.
Erase boot at CE0 Bank3 Block0x23 unsuccessfully.
Erase boot at CE0 Bank3 Block0x24 unsuccessfully.
Erase boot at CE0 Bank3 Block0x25 unsuccessfully.
Erase boot at CE0 Bank3 Block0x26 unsuccessfully.
Erase boot at CE0 Bank3 Block0x27 unsuccessfully.
Erase boot at CE0 Bank3 Block0x28 unsuccessfully.
Erase boot at CE0 Bank3 Block0x29 unsuccessfully.
Erase boot at CE0 Bank3 Block0x2A unsuccessfully.
Erase boot at CE0 Bank3 Block0x2B unsuccessfully.
Erase boot at CE0 Bank3 Block0x2C unsuccessfully.
Erase boot at CE0 Bank3 Block0x2D unsuccessfully.
Erase boot at CE0 Bank3 Block0x2E unsuccessfully.
Erase boot at CE0 Bank3 Block0x2F unsuccessfully.
Erase boot at CE0 Bank3 Block0x30 unsuccessfully.
Erase boot at CE0 Bank3 Block0x31 unsuccessfully.
Erase boot at CE0 Bank3 Block0x32 unsuccessfully.
Erase boot at CE0 Bank3 Block0x33 unsuccessfully.
Erase boot at CE0 Bank3 Block0x34 unsuccessfully.
Erase boot at CE0 Bank3 Block0x35 unsuccessfully.
Erase boot at CE0 Bank3 Block0x36 unsuccessfully.
Erase boot at CE0 Bank3 Block0x37 unsuccessfully.
Erase boot at CE0 Bank3 Block0x38 unsuccessfully.
Erase boot at CE0 Bank3 Block0x39 unsuccessfully.
Erase boot at CE0 Bank3 Block0x3A unsuccessfully.
Erase boot at CE0 Bank3 Block0x3B unsuccessfully.
Erase boot at CE0 Bank3 Block0x3C unsuccessfully.
Erase boot at CE0 Bank3 Block0x3D unsuccessfully.
Erase boot at CE0 Bank3 Block0x3E unsuccessfully.
Erase boot at CE0 Bank3 Block0x3F unsuccessfully.
Erase boot at CE1 Bank0 Block0x0 unsuccessfully.
Erase boot at CE1 Bank0 Block0x1 unsuccessfully.
Erase boot at CE1 Bank0 Block0x2 unsuccessfully.
Erase boot at CE1 Bank0 Block0x3 unsuccessfully.
Erase boot at CE1 Bank0 Block0x4 unsuccessfully.
Erase boot at CE1 Bank0 Block0x5 unsuccessfully.
Erase boot at CE1 Bank0 Block0x6 unsuccessfully.
Erase boot at CE1 Bank0 Block0x7 unsuccessfully.
Erase boot at CE1 Bank0 Block0x8 unsuccessfully.
Erase boot at CE1 Bank0 Block0x9 unsuccessfully.
Erase boot at CE1 Bank0 Block0xA unsuccessfully.
Erase boot at CE1 Bank0 Block0xB unsuccessfully.
Erase boot at CE1 Bank0 Block0xC unsuccessfully.
Erase boot at CE1 Bank0 Block0xD unsuccessfully.
Erase boot at CE1 Bank0 Block0xE unsuccessfully.
Erase boot at CE1 Bank0 Block0xF unsuccessfully.
Erase boot at CE1 Bank0 Block0x10 unsuccessfully.
Erase boot at CE1 Bank0 Block0x11 unsuccessfully.
Erase boot at CE1 Bank0 Block0x12 unsuccessfully.
Erase boot at CE1 Bank0 Block0x13 unsuccessfully.
Erase boot at CE1 Bank0 Block0x14 unsuccessfully.
Erase boot at CE1 Bank0 Block0x15 unsuccessfully.
Erase boot at CE1 Bank0 Block0x16 unsuccessfully.
Erase boot at CE1 Bank0 Block0x17 unsuccessfully.
Erase boot at CE1 Bank0 Block0x18 unsuccessfully.
Erase boot at CE1 Bank0 Block0x19 unsuccessfully.
Erase boot at CE1 Bank0 Block0x1A unsuccessfully.
Erase boot at CE1 Bank0 Block0x1B unsuccessfully.
Erase boot at CE1 Bank0 Block0x1C unsuccessfully.
Erase boot at CE1 Bank0 Block0x1D unsuccessfully.
Erase boot at CE1 Bank0 Block0x1E unsuccessfully.
Erase boot at CE1 Bank0 Block0x1F unsuccessfully.
Erase boot at CE1 Bank0 Block0x20 unsuccessfully.
Erase boot at CE1 Bank0 Block0x21 unsuccessfully.
Erase boot at CE1 Bank0 Block0x22 unsuccessfully.
Erase boot at CE1 Bank0 Block0x23 unsuccessfully.
Erase boot at CE1 Bank0 Block0x24 unsuccessfully.
Erase boot at CE1 Bank0 Block0x25 unsuccessfully.
Erase boot at CE1 Bank0 Block0x26 unsuccessfully.
Erase boot at CE1 Bank0 Block0x27 unsuccessfully.
Erase boot at CE1 Bank0 Block0x28 unsuccessfully.
Erase boot at CE1 Bank0 Block0x29 unsuccessfully.
Erase boot at CE1 Bank0 Block0x2A unsuccessfully.
Erase boot at CE1 Bank0 Block0x2B unsuccessfully.
Erase boot at CE1 Bank0 Block0x2C unsuccessfully.
Erase boot at CE1 Bank0 Block0x2D unsuccessfully.
Erase boot at CE1 Bank0 Block0x2E unsuccessfully.
Erase boot at CE1 Bank0 Block0x2F unsuccessfully.
Erase boot at CE1 Bank0 Block0x30 unsuccessfully.
Erase boot at CE1 Bank0 Block0x31 unsuccessfully.
Erase boot at CE1 Bank0 Block0x32 unsuccessfully.
Erase boot at CE1 Bank0 Block0x33 unsuccessfully.
Erase boot at CE1 Bank0 Block0x34 unsuccessfully.
Erase boot at CE1 Bank0 Block0x35 unsuccessfully.
Erase boot at CE1 Bank0 Block0x36 unsuccessfully.
Erase boot at CE1 Bank0 Block0x37 unsuccessfully.
Erase boot at CE1 Bank0 Block0x38 unsuccessfully.
Erase boot at CE1 Bank0 Block0x39 unsuccessfully.
Erase boot at CE1 Bank0 Block0x3A unsuccessfully.
Erase boot at CE1 Bank0 Block0x3B unsuccessfully.
Erase boot at CE1 Bank0 Block0x3C unsuccessfully.
Erase boot at CE1 Bank0 Block0x3D unsuccessfully.
Erase boot at CE1 Bank0 Block0x3E unsuccessfully.
Erase boot at CE1 Bank0 Block0x3F unsuccessfully.
Erase boot at CE1 Bank1 Block0x0 unsuccessfully.
Erase boot at CE1 Bank1 Block0x1 unsuccessfully.
Erase boot at CE1 Bank1 Block0x2 unsuccessfully.
Erase boot at CE1 Bank1 Block0x3 unsuccessfully.
Erase boot at CE1 Bank1 Block0x4 unsuccessfully.
Erase boot at CE1 Bank1 Block0x5 unsuccessfully.
Erase boot at CE1 Bank1 Block0x6 unsuccessfully.
Erase boot at CE1 Bank1 Block0x7 unsuccessfully.
Erase boot at CE1 Bank1 Block0x8 unsuccessfully.
Erase boot at CE1 Bank1 Block0x9 unsuccessfully.
Erase boot at CE1 Bank1 Block0xA unsuccessfully.
Erase boot at CE1 Bank1 Block0xB unsuccessfully.
Erase boot at CE1 Bank1 Block0xC unsuccessfully.
Erase boot at CE1 Bank1 Block0xD unsuccessfully.
Erase boot at CE1 Bank1 Block0xE unsuccessfully.
Erase boot at CE1 Bank1 Block0xF unsuccessfully.
Erase boot at CE1 Bank1 Block0x10 unsuccessfully.
Erase boot at CE1 Bank1 Block0x11 unsuccessfully.
Erase boot at CE1 Bank1 Block0x12 unsuccessfully.
Erase boot at CE1 Bank1 Block0x13 unsuccessfully.
Erase boot at CE1 Bank1 Block0x14 unsuccessfully.
Erase boot at CE1 Bank1 Block0x15 unsuccessfully.
Erase boot at CE1 Bank1 Block0x16 unsuccessfully.
Erase boot at CE1 Bank1 Block0x17 unsuccessfully.
Erase boot at CE1 Bank1 Block0x18 unsuccessfully.
Erase boot at CE1 Bank1 Block0x19 unsuccessfully.
Erase boot at CE1 Bank1 Block0x1A unsuccessfully.
Erase boot at CE1 Bank1 Block0x1B unsuccessfully.
Erase boot at CE1 Bank1 Block0x1C unsuccessfully.
Erase boot at CE1 Bank1 Block0x1D unsuccessfully.
Erase boot at CE1 Bank1 Block0x1E unsuccessfully.
Erase boot at CE1 Bank1 Block0x1F unsuccessfully.
Erase boot at CE1 Bank1 Block0x20 unsuccessfully.
Erase boot at CE1 Bank1 Block0x21 unsuccessfully.
Erase boot at CE1 Bank1 Block0x22 unsuccessfully.
Erase boot at CE1 Bank1 Block0x23 unsuccessfully.
Erase boot at CE1 Bank1 Block0x24 unsuccessfully.
Erase boot at CE1 Bank1 Block0x25 unsuccessfully.
Erase boot at CE1 Bank1 Block0x26 unsuccessfully.
Erase boot at CE1 Bank1 Block0x27 unsuccessfully.
Erase boot at CE1 Bank1 Block0x28 unsuccessfully.
Erase boot at CE1 Bank1 Block0x29 unsuccessfully.
Erase boot at CE1 Bank1 Block0x2A unsuccessfully.
Erase boot at CE1 Bank1 Block0x2B unsuccessfully.
Erase boot at CE1 Bank1 Block0x2C unsuccessfully.
Erase boot at CE1 Bank1 Block0x2D unsuccessfully.
Erase boot at CE1 Bank1 Block0x2E unsuccessfully.
Erase boot at CE1 Bank1 Block0x2F unsuccessfully.
Erase boot at CE1 Bank1 Block0x30 unsuccessfully.
Erase boot at CE1 Bank1 Block0x31 unsuccessfully.
Erase boot at CE1 Bank1 Block0x32 unsuccessfully.
Erase boot at CE1 Bank1 Block0x33 unsuccessfully.
Erase boot at CE1 Bank1 Block0x34 unsuccessfully.
Erase boot at CE1 Bank1 Block0x35 unsuccessfully.
Erase boot at CE1 Bank1 Block0x36 unsuccessfully.
Erase boot at CE1 Bank1 Block0x37 unsuccessfully.
Erase boot at CE1 Bank1 Block0x38 unsuccessfully.
Erase boot at CE1 Bank1 Block0x39 unsuccessfully.
Erase boot at CE1 Bank1 Block0x3A unsuccessfully.
Erase boot at CE1 Bank1 Block0x3B unsuccessfully.
Erase boot at CE1 Bank1 Block0x3C unsuccessfully.
Erase boot at CE1 Bank1 Block0x3D unsuccessfully.
Erase boot at CE1 Bank1 Block0x3E unsuccessfully.
Erase boot at CE1 Bank1 Block0x3F unsuccessfully.
Erase boot at CE1 Bank2 Block0x0 unsuccessfully.
Erase boot at CE1 Bank2 Block0x1 unsuccessfully.
Erase boot at CE1 Bank2 Block0x2 unsuccessfully.
Erase boot at CE1 Bank2 Block0x3 unsuccessfully.
Erase boot at CE1 Bank2 Block0x4 unsuccessfully.
Erase boot at CE1 Bank2 Block0x5 unsuccessfully.
Erase boot at CE1 Bank2 Block0x6 unsuccessfully.
Erase boot at CE1 Bank2 Block0x7 unsuccessfully.
Erase boot at CE1 Bank2 Block0x8 unsuccessfully.
Erase boot at CE1 Bank2 Block0x9 unsuccessfully.
Erase boot at CE1 Bank2 Block0xA unsuccessfully.
Erase boot at CE1 Bank2 Block0xB unsuccessfully.
Erase boot at CE1 Bank2 Block0xC unsuccessfully.
Erase boot at CE1 Bank2 Block0xD unsuccessfully.
Erase boot at CE1 Bank2 Block0xE unsuccessfully.
Erase boot at CE1 Bank2 Block0xF unsuccessfully.
Erase boot at CE1 Bank2 Block0x10 unsuccessfully.
Erase boot at CE1 Bank2 Block0x11 unsuccessfully.
Erase boot at CE1 Bank2 Block0x12 unsuccessfully.
Erase boot at CE1 Bank2 Block0x13 unsuccessfully.
Erase boot at CE1 Bank2 Block0x14 unsuccessfully.
Erase boot at CE1 Bank2 Block0x15 unsuccessfully.
Erase boot at CE1 Bank2 Block0x16 unsuccessfully.
Erase boot at CE1 Bank2 Block0x17 unsuccessfully.
Erase boot at CE1 Bank2 Block0x18 unsuccessfully.
Erase boot at CE1 Bank2 Block0x19 unsuccessfully.
Erase boot at CE1 Bank2 Block0x1A unsuccessfully.
Erase boot at CE1 Bank2 Block0x1B unsuccessfully.
Erase boot at CE1 Bank2 Block0x1C unsuccessfully.
Erase boot at CE1 Bank2 Block0x1D unsuccessfully.
Erase boot at CE1 Bank2 Block0x1E unsuccessfully.
Erase boot at CE1 Bank2 Block0x1F unsuccessfully.
Erase boot at CE1 Bank2 Block0x20 unsuccessfully.
Erase boot at CE1 Bank2 Block0x21 unsuccessfully.
Erase boot at CE1 Bank2 Block0x22 unsuccessfully.
Erase boot at CE1 Bank2 Block0x23 unsuccessfully.
Erase boot at CE1 Bank2 Block0x24 unsuccessfully.
Erase boot at CE1 Bank2 Block0x25 unsuccessfully.
Erase boot at CE1 Bank2 Block0x26 unsuccessfully.
Erase boot at CE1 Bank2 Block0x27 unsuccessfully.
Erase boot at CE1 Bank2 Block0x28 unsuccessfully.
Erase boot at CE1 Bank2 Block0x29 unsuccessfully.
Erase boot at CE1 Bank2 Block0x2A unsuccessfully.
Erase boot at CE1 Bank2 Block0x2B unsuccessfully.
Erase boot at CE1 Bank2 Block0x2C unsuccessfully.
Erase boot at CE1 Bank2 Block0x2D unsuccessfully.
Erase boot at CE1 Bank2 Block0x2E unsuccessfully.
Erase boot at CE1 Bank2 Block0x2F unsuccessfully.
Erase boot at CE1 Bank2 Block0x30 unsuccessfully.
Erase boot at CE1 Bank2 Block0x31 unsuccessfully.
Erase boot at CE1 Bank2 Block0x32 unsuccessfully.
Erase boot at CE1 Bank2 Block0x33 unsuccessfully.
Erase boot at CE1 Bank2 Block0x34 unsuccessfully.
Erase boot at CE1 Bank2 Block0x35 unsuccessfully.
Erase boot at CE1 Bank2 Block0x36 unsuccessfully.
Erase boot at CE1 Bank2 Block0x37 unsuccessfully.
Erase boot at CE1 Bank2 Block0x38 unsuccessfully.
Erase boot at CE1 Bank2 Block0x39 unsuccessfully.
Erase boot at CE1 Bank2 Block0x3A unsuccessfully.
Erase boot at CE1 Bank2 Block0x3B unsuccessfully.
Erase boot at CE1 Bank2 Block0x3C unsuccessfully.
Erase boot at CE1 Bank2 Block0x3D unsuccessfully.
Erase boot at CE1 Bank2 Block0x3E unsuccessfully.
Erase boot at CE1 Bank2 Block0x3F unsuccessfully.
Erase boot at CE1 Bank3 Block0x0 unsuccessfully.
Erase boot at CE1 Bank3 Block0x1 unsuccessfully.
Erase boot at CE1 Bank3 Block0x2 unsuccessfully.
Erase boot at CE1 Bank3 Block0x3 unsuccessfully.
Erase boot at CE1 Bank3 Block0x4 unsuccessfully.
Erase boot at CE1 Bank3 Block0x5 unsuccessfully.
Erase boot at CE1 Bank3 Block0x6 unsuccessfully.
Erase boot at CE1 Bank3 Block0x7 unsuccessfully.
Erase boot at CE1 Bank3 Block0x8 unsuccessfully.
Erase boot at CE1 Bank3 Block0x9 unsuccessfully.
Erase boot at CE1 Bank3 Block0xA unsuccessfully.
Erase boot at CE1 Bank3 Block0xB unsuccessfully.
Erase boot at CE1 Bank3 Block0xC unsuccessfully.
Erase boot at CE1 Bank3 Block0xD unsuccessfully.
Erase boot at CE1 Bank3 Block0xE unsuccessfully.
Erase boot at CE1 Bank3 Block0xF unsuccessfully.
Erase boot at CE1 Bank3 Block0x10 unsuccessfully.
Erase boot at CE1 Bank3 Block0x11 unsuccessfully.
Erase boot at CE1 Bank3 Block0x12 unsuccessfully.
Erase boot at CE1 Bank3 Block0x13 unsuccessfully.
Erase boot at CE1 Bank3 Block0x14 unsuccessfully.
Erase boot at CE1 Bank3 Block0x15 unsuccessfully.
Erase boot at CE1 Bank3 Block0x16 unsuccessfully.
Erase boot at CE1 Bank3 Block0x17 unsuccessfully.
Erase boot at CE1 Bank3 Block0x18 unsuccessfully.
Erase boot at CE1 Bank3 Block0x19 unsuccessfully.
Erase boot at CE1 Bank3 Block0x1A unsuccessfully.
Erase boot at CE1 Bank3 Block0x1B unsuccessfully.
Erase boot at CE1 Bank3 Block0x1C unsuccessfully.
Erase boot at CE1 Bank3 Block0x1D unsuccessfully.
Erase boot at CE1 Bank3 Block0x1E unsuccessfully.
Erase boot at CE1 Bank3 Block0x1F unsuccessfully.
Erase boot at CE1 Bank3 Block0x20 unsuccessfully.
Erase boot at CE1 Bank3 Block0x21 unsuccessfully.
Erase boot at CE1 Bank3 Block0x22 unsuccessfully.
Erase boot at CE1 Bank3 Block0x23 unsuccessfully.
Erase boot at CE1 Bank3 Block0x24 unsuccessfully.
Erase boot at CE1 Bank3 Block0x25 unsuccessfully.
Erase boot at CE1 Bank3 Block0x26 unsuccessfully.
Erase boot at CE1 Bank3 Block0x27 unsuccessfully.
Erase boot at CE1 Bank3 Block0x28 unsuccessfully.
Erase boot at CE1 Bank3 Block0x29 unsuccessfully.
Erase boot at CE1 Bank3 Block0x2A unsuccessfully.
Erase boot at CE1 Bank3 Block0x2B unsuccessfully.
Erase boot at CE1 Bank3 Block0x2C unsuccessfully.
Erase boot at CE1 Bank3 Block0x2D unsuccessfully.
Erase boot at CE1 Bank3 Block0x2E unsuccessfully.
Erase boot at CE1 Bank3 Block0x2F unsuccessfully.
Erase boot at CE1 Bank3 Block0x30 unsuccessfully.
Erase boot at CE1 Bank3 Block0x31 unsuccessfully.
Erase boot at CE1 Bank3 Block0x32 unsuccessfully.
Erase boot at CE1 Bank3 Block0x33 unsuccessfully.
Erase boot at CE1 Bank3 Block0x34 unsuccessfully.
Erase boot at CE1 Bank3 Block0x35 unsuccessfully.
Erase boot at CE1 Bank3 Block0x36 unsuccessfully.
Erase boot at CE1 Bank3 Block0x37 unsuccessfully.
Erase boot at CE1 Bank3 Block0x38 unsuccessfully.
Erase boot at CE1 Bank3 Block0x39 unsuccessfully.
Erase boot at CE1 Bank3 Block0x3A unsuccessfully.
Erase boot at CE1 Bank3 Block0x3B unsuccessfully.
Erase boot at CE1 Bank3 Block0x3C unsuccessfully.
Erase boot at CE1 Bank3 Block0x3D unsuccessfully.
Erase boot at CE1 Bank3 Block0x3E unsuccessfully.
Erase boot at CE1 Bank3 Block0x3F unsuccessfully.
Erase boot at CE0 Bank0 Block0x410 unsuccessfully.
Erase boot at CE0 Bank0 Block0x411 unsuccessfully.
Erase boot at CE0 Bank0 Block0x412 unsuccessfully.
Erase boot at CE0 Bank0 Block0x413 unsuccessfully.
Erase boot at CE0 Bank0 Block0x414 unsuccessfully.
Erase boot at CE0 Bank0 Block0x415 unsuccessfully.
Erase boot at CE0 Bank0 Block0x416 unsuccessfully.
Erase boot at CE0 Bank0 Block0x417 unsuccessfully.
Erase boot at CE0 Bank0 Block0x418 unsuccessfully.
Erase boot at CE0 Bank0 Block0x419 unsuccessfully.
Erase boot at CE0 Bank0 Block0x41A unsuccessfully.
Erase boot at CE0 Bank0 Block0x41B unsuccessfully.
Erase boot at CE0 Bank0 Block0x41C unsuccessfully.
Erase boot at CE0 Bank0 Block0x41D unsuccessfully.
Erase boot at CE0 Bank0 Block0x41E unsuccessfully.
Erase boot at CE0 Bank0 Block0x41F unsuccessfully.
Erase boot at CE0 Bank1 Block0x410 unsuccessfully.
Erase boot at CE0 Bank1 Block0x411 unsuccessfully.
Erase boot at CE0 Bank1 Block0x412 unsuccessfully.
Erase boot at CE0 Bank1 Block0x413 unsuccessfully.
Erase boot at CE0 Bank1 Block0x414 unsuccessfully.
Erase boot at CE0 Bank1 Block0x415 unsuccessfully.
Erase boot at CE0 Bank1 Block0x416 unsuccessfully.
Erase boot at CE0 Bank1 Block0x417 unsuccessfully.
Erase boot at CE0 Bank1 Block0x418 unsuccessfully.
Erase boot at CE0 Bank1 Block0x419 unsuccessfully.
Erase boot at CE0 Bank1 Block0x41A unsuccessfully.
Erase boot at CE0 Bank1 Block0x41B unsuccessfully.
Erase boot at CE0 Bank1 Block0x41C unsuccessfully.
Erase boot at CE0 Bank1 Block0x41D unsuccessfully.
Erase boot at CE0 Bank1 Block0x41E unsuccessfully.
Erase boot at CE0 Bank1 Block0x41F unsuccessfully.
Erase boot at CE0 Bank2 Block0x410 unsuccessfully.
Erase boot at CE0 Bank2 Block0x411 unsuccessfully.
Erase boot at CE0 Bank2 Block0x412 unsuccessfully.
Erase boot at CE0 Bank2 Block0x413 unsuccessfully.
Erase boot at CE0 Bank2 Block0x414 unsuccessfully.
Erase boot at CE0 Bank2 Block0x415 unsuccessfully.
Erase boot at CE0 Bank2 Block0x416 unsuccessfully.
Erase boot at CE0 Bank2 Block0x417 unsuccessfully.
Erase boot at CE0 Bank2 Block0x418 unsuccessfully.
Erase boot at CE0 Bank2 Block0x419 unsuccessfully.
Erase boot at CE0 Bank2 Block0x41A unsuccessfully.
Erase boot at CE0 Bank2 Block0x41B unsuccessfully.
Erase boot at CE0 Bank2 Block0x41C unsuccessfully.
Erase boot at CE0 Bank2 Block0x41D unsuccessfully.
Erase boot at CE0 Bank2 Block0x41E unsuccessfully.
Erase boot at CE0 Bank2 Block0x41F unsuccessfully.
Erase boot at CE0 Bank3 Block0x410 unsuccessfully.
Erase boot at CE0 Bank3 Block0x411 unsuccessfully.
Erase boot at CE0 Bank3 Block0x412 unsuccessfully.
Erase boot at CE0 Bank3 Block0x413 unsuccessfully.
Erase boot at CE0 Bank3 Block0x414 unsuccessfully.
Erase boot at CE0 Bank3 Block0x415 unsuccessfully.
Erase boot at CE0 Bank3 Block0x416 unsuccessfully.
Erase boot at CE0 Bank3 Block0x417 unsuccessfully.
Erase boot at CE0 Bank3 Block0x418 unsuccessfully.
Erase boot at CE0 Bank3 Block0x419 unsuccessfully.
Erase boot at CE0 Bank3 Block0x41A unsuccessfully.
Erase boot at CE0 Bank3 Block0x41B unsuccessfully.
Erase boot at CE0 Bank3 Block0x41C unsuccessfully.
Erase boot at CE0 Bank3 Block0x41D unsuccessfully.
Erase boot at CE0 Bank3 Block0x41E unsuccessfully.
Erase boot at CE0 Bank3 Block0x41F unsuccessfully.
Erase boot at CE1 Bank0 Block0x410 unsuccessfully.
Erase boot at CE1 Bank0 Block0x411 unsuccessfully.
Erase boot at CE1 Bank0 Block0x412 unsuccessfully.
Erase boot at CE1 Bank0 Block0x413 unsuccessfully.
Erase boot at CE1 Bank0 Block0x414 unsuccessfully.
Erase boot at CE1 Bank0 Block0x415 unsuccessfully.
Erase boot at CE1 Bank0 Block0x416 unsuccessfully.
Erase boot at CE1 Bank0 Block0x417 unsuccessfully.
Erase boot at CE1 Bank0 Block0x418 unsuccessfully.
Erase boot at CE1 Bank0 Block0x419 unsuccessfully.
Erase boot at CE1 Bank0 Block0x41A unsuccessfully.
Erase boot at CE1 Bank0 Block0x41B unsuccessfully.
Erase boot at CE1 Bank0 Block0x41C unsuccessfully.
Erase boot at CE1 Bank0 Block0x41D unsuccessfully.
Erase boot at CE1 Bank0 Block0x41E unsuccessfully.
Erase boot at CE1 Bank0 Block0x41F unsuccessfully.
Erase boot at CE1 Bank1 Block0x410 unsuccessfully.
Erase boot at CE1 Bank1 Block0x411 unsuccessfully.
Erase boot at CE1 Bank1 Block0x412 unsuccessfully.
Erase boot at CE1 Bank1 Block0x413 unsuccessfully.
Erase boot at CE1 Bank1 Block0x414 unsuccessfully.
Erase boot at CE1 Bank1 Block0x415 unsuccessfully.
Erase boot at CE1 Bank1 Block0x416 unsuccessfully.
Erase boot at CE1 Bank1 Block0x417 unsuccessfully.
Erase boot at CE1 Bank1 Block0x418 unsuccessfully.
Erase boot at CE1 Bank1 Block0x419 unsuccessfully.
Erase boot at CE1 Bank1 Block0x41A unsuccessfully.
Erase boot at CE1 Bank1 Block0x41B unsuccessfully.
Erase boot at CE1 Bank1 Block0x41C unsuccessfully.
Erase boot at CE1 Bank1 Block0x41D unsuccessfully.
Erase boot at CE1 Bank1 Block0x41E unsuccessfully.
Erase boot at CE1 Bank1 Block0x41F unsuccessfully.
Erase boot at CE1 Bank2 Block0x410 unsuccessfully.
Erase boot at CE1 Bank2 Block0x411 unsuccessfully.
Erase boot at CE1 Bank2 Block0x412 unsuccessfully.
Erase boot at CE1 Bank2 Block0x413 unsuccessfully.
Erase boot at CE1 Bank2 Block0x414 unsuccessfully.
Erase boot at CE1 Bank2 Block0x415 unsuccessfully.
Erase boot at CE1 Bank2 Block0x416 unsuccessfully.
Erase boot at CE1 Bank2 Block0x417 unsuccessfully.
Erase boot at CE1 Bank2 Block0x418 unsuccessfully.
Erase boot at CE1 Bank2 Block0x419 unsuccessfully.
Erase boot at CE1 Bank2 Block0x41A unsuccessfully.
Erase boot at CE1 Bank2 Block0x41B unsuccessfully.
Erase boot at CE1 Bank2 Block0x41C unsuccessfully.
Erase boot at CE1 Bank2 Block0x41D unsuccessfully.
Erase boot at CE1 Bank2 Block0x41E unsuccessfully.
Erase boot at CE1 Bank2 Block0x41F unsuccessfully.
Erase boot at CE1 Bank3 Block0x410 unsuccessfully.
Erase boot at CE1 Bank3 Block0x411 unsuccessfully.
Erase boot at CE1 Bank3 Block0x412 unsuccessfully.
Erase boot at CE1 Bank3 Block0x413 unsuccessfully.
Erase boot at CE1 Bank3 Block0x414 unsuccessfully.
Erase boot at CE1 Bank3 Block0x415 unsuccessfully.
Erase boot at CE1 Bank3 Block0x416 unsuccessfully.
Erase boot at CE1 Bank3 Block0x417 unsuccessfully.
Erase boot at CE1 Bank3 Block0x418 unsuccessfully.
Erase boot at CE1 Bank3 Block0x419 unsuccessfully.
Erase boot at CE1 Bank3 Block0x41A unsuccessfully.
Erase boot at CE1 Bank3 Block0x41B unsuccessfully.
Erase boot at CE1 Bank3 Block0x41C unsuccessfully.
Erase boot at CE1 Bank3 Block0x41D unsuccessfully.
Erase boot at CE1 Bank3 Block0x41E unsuccessfully.
Erase boot at CE1 Bank3 Block0x41F unsuccessfully.
Erase CE0 Bank0 Block3 error
Erase CE1 Bank1 Block2 error
Erase CE0 Bank1 Block2 error
Erase CE1 Bank0 Block2 error
Old 04-03-2019, 04:25   #6 (permalink)
Member: 757188
Thanks Meter: 22
hepl me Cannot write HDD.
NAND fw:052427P_TB_TLC2P
Banks per CE:8
Pages per block:258
Page Size:16448
Chip Capacity:132.54GB
Information at CE0 Bank6 Block0x0 Page0
Erase boot at CE0 Bank4 Block0x0 unsuccessfully.
Erase boot at CE0 Bank4 Block0x1 unsuccessfully.
Erase boot at CE0 Bank4 Block0x2 unsuccessfully.
Erase boot at CE0 Bank4 Block0x3 unsuccessfully.
Erase boot at CE0 Bank4 Block0x4 unsuccessfully.
Erase boot at CE0 Bank4 Block0x5 unsuccessfully.
Erase boot at CE0 Bank4 Block0x6 unsuccessfully.
Erase boot at CE0 Bank4 Block0x7 unsuccessfully.
Erase boot at CE0 Bank4 Block0x8 unsuccessfully.
Erase boot at CE0 Bank4 Block0x9 unsuccessfully.
Erase boot at CE0 Bank4 Block0xA unsuccessfully.
Erase boot at CE0 Bank4 Block0xB unsuccessfully.
Erase boot at CE0 Bank4 Block0xC unsuccessfully.
Erase boot at CE0 Bank4 Block0xD unsuccessfully.
Erase boot at CE0 Bank4 Block0xE unsuccessfully.
Erase boot at CE0 Bank4 Block0xF unsuccessfully.
Erase boot at CE0 Bank4 Block0x10 unsuccessfully.
Erase boot at CE0 Bank4 Block0x11 unsuccessfully.
Erase boot at CE0 Bank4 Block0x12 unsuccessfully.
Erase boot at CE0 Bank4 Block0x13 unsuccessfully.
Erase boot at CE0 Bank4 Block0x14 unsuccessfully.
Erase boot at CE0 Bank4 Block0x15 unsuccessfully.
Erase boot at CE0 Bank4 Block0x16 unsuccessfully.
Erase boot at CE0 Bank4 Block0x17 unsuccessfully.
Erase boot at CE0 Bank4 Block0x18 unsuccessfully.
Erase boot at CE0 Bank4 Block0x19 unsuccessfully.
Erase boot at CE0 Bank4 Block0x1A unsuccessfully.
Erase boot at CE0 Bank4 Block0x1B unsuccessfully.
Erase boot at CE0 Bank4 Block0x1C unsuccessfully.
Erase boot at CE0 Bank4 Block0x1D unsuccessfully.
Erase boot at CE0 Bank4 Block0x1E unsuccessfully.
Erase boot at CE0 Bank4 Block0x1F unsuccessfully.
Erase boot at CE0 Bank4 Block0x20 unsuccessfully.
Erase boot at CE0 Bank4 Block0x21 unsuccessfully.
Erase boot at CE0 Bank4 Block0x22 unsuccessfully.
Erase boot at CE0 Bank4 Block0x23 unsuccessfully.
Erase boot at CE0 Bank4 Block0x24 unsuccessfully.
Erase boot at CE0 Bank4 Block0x25 unsuccessfully.
Erase boot at CE0 Bank4 Block0x26 unsuccessfully.
Erase boot at CE0 Bank4 Block0x27 unsuccessfully.
Erase boot at CE0 Bank4 Block0x28 unsuccessfully.
Erase boot at CE0 Bank4 Block0x29 unsuccessfully.
Erase boot at CE0 Bank4 Block0x2A unsuccessfully.
Erase boot at CE0 Bank4 Block0x2B unsuccessfully.
Erase boot at CE0 Bank4 Block0x2C unsuccessfully.
Erase boot at CE0 Bank4 Block0x2D unsuccessfully.
Erase boot at CE0 Bank4 Block0x2E unsuccessfully.
Erase boot at CE0 Bank4 Block0x2F unsuccessfully.
Erase boot at CE0 Bank4 Block0x30 unsuccessfully.
Erase boot at CE0 Bank4 Block0x31 unsuccessfully.
Erase boot at CE0 Bank4 Block0x32 unsuccessfully.
Erase boot at CE0 Bank4 Block0x33 unsuccessfully.
Erase boot at CE0 Bank4 Block0x34 unsuccessfully.
Erase boot at CE0 Bank4 Block0x35 unsuccessfully.
Erase boot at CE0 Bank4 Block0x36 unsuccessfully.
Erase boot at CE0 Bank4 Block0x37 unsuccessfully.
Erase boot at CE0 Bank4 Block0x38 unsuccessfully.
Erase boot at CE0 Bank4 Block0x39 unsuccessfully.
Erase boot at CE0 Bank4 Block0x3A unsuccessfully.
Erase boot at CE0 Bank4 Block0x3B unsuccessfully.
Erase boot at CE0 Bank4 Block0x3C unsuccessfully.
Erase boot at CE0 Bank4 Block0x3D unsuccessfully.
Erase boot at CE0 Bank4 Block0x3E unsuccessfully.
Erase boot at CE0 Bank4 Block0x3F unsuccessfully.
Erase boot at CE0 Bank5 Block0x0 unsuccessfully.
Erase boot at CE0 Bank5 Block0x1 unsuccessfully.
Erase boot at CE0 Bank5 Block0x2 unsuccessfully.
Erase boot at CE0 Bank5 Block0x3 unsuccessfully.
Erase boot at CE0 Bank5 Block0x4 unsuccessfully.
Erase boot at CE0 Bank5 Block0x5 unsuccessfully.
Erase boot at CE0 Bank5 Block0x6 unsuccessfully.
Erase boot at CE0 Bank5 Block0x7 unsuccessfully.
Erase boot at CE0 Bank5 Block0x8 unsuccessfully.
Erase boot at CE0 Bank5 Block0x9 unsuccessfully.
Erase boot at CE0 Bank5 Block0xA unsuccessfully.
Erase boot at CE0 Bank5 Block0xB unsuccessfully.
Erase boot at CE0 Bank5 Block0xC unsuccessfully.
Erase boot at CE0 Bank5 Block0xD unsuccessfully.
Erase boot at CE0 Bank5 Block0xE unsuccessfully.
Erase boot at CE0 Bank5 Block0xF unsuccessfully.
Erase boot at CE0 Bank5 Block0x10 unsuccessfully.
Erase boot at CE0 Bank5 Block0x11 unsuccessfully.
Erase boot at CE0 Bank5 Block0x12 unsuccessfully.
Erase boot at CE0 Bank5 Block0x13 unsuccessfully.
Erase boot at CE0 Bank5 Block0x14 unsuccessfully.
Erase boot at CE0 Bank5 Block0x15 unsuccessfully.
Erase boot at CE0 Bank5 Block0x16 unsuccessfully.
Erase boot at CE0 Bank5 Block0x17 unsuccessfully.
Erase boot at CE0 Bank5 Block0x18 unsuccessfully.
Erase boot at CE0 Bank5 Block0x19 unsuccessfully.
Erase boot at CE0 Bank5 Block0x1A unsuccessfully.
Erase boot at CE0 Bank5 Block0x1B unsuccessfully.
Erase boot at CE0 Bank5 Block0x1C unsuccessfully.
Erase boot at CE0 Bank5 Block0x1D unsuccessfully.
Erase boot at CE0 Bank5 Block0x1E unsuccessfully.
Erase boot at CE0 Bank5 Block0x1F unsuccessfully.
Erase boot at CE0 Bank5 Block0x20 unsuccessfully.
Erase boot at CE0 Bank5 Block0x21 unsuccessfully.
Erase boot at CE0 Bank5 Block0x22 unsuccessfully.
Erase boot at CE0 Bank5 Block0x23 unsuccessfully.
Erase boot at CE0 Bank5 Block0x24 unsuccessfully.
Erase boot at CE0 Bank5 Block0x25 unsuccessfully.
Erase boot at CE0 Bank5 Block0x26 unsuccessfully.
Erase boot at CE0 Bank5 Block0x27 unsuccessfully.
Erase boot at CE0 Bank5 Block0x28 unsuccessfully.
Erase boot at CE0 Bank5 Block0x29 unsuccessfully.
Erase boot at CE0 Bank5 Block0x2A unsuccessfully.
Erase boot at CE0 Bank5 Block0x2B unsuccessfully.
Erase boot at CE0 Bank5 Block0x2C unsuccessfully.
Erase boot at CE0 Bank5 Block0x2D unsuccessfully.
Erase boot at CE0 Bank5 Block0x2E unsuccessfully.
Erase boot at CE0 Bank5 Block0x2F unsuccessfully.
Erase boot at CE0 Bank5 Block0x30 unsuccessfully.
Erase boot at CE0 Bank5 Block0x31 unsuccessfully.
Erase boot at CE0 Bank5 Block0x32 unsuccessfully.
Erase boot at CE0 Bank5 Block0x33 unsuccessfully.
Erase boot at CE0 Bank5 Block0x34 unsuccessfully.
Erase boot at CE0 Bank5 Block0x35 unsuccessfully.
Erase boot at CE0 Bank5 Block0x36 unsuccessfully.
Erase boot at CE0 Bank5 Block0x37 unsuccessfully.
Erase boot at CE0 Bank5 Block0x38 unsuccessfully.
Erase boot at CE0 Bank5 Block0x39 unsuccessfully.
Erase boot at CE0 Bank5 Block0x3A unsuccessfully.
Erase boot at CE0 Bank5 Block0x3B unsuccessfully.
Erase boot at CE0 Bank5 Block0x3C unsuccessfully.
Erase boot at CE0 Bank5 Block0x3D unsuccessfully.
Erase boot at CE0 Bank5 Block0x3E unsuccessfully.
Erase boot at CE0 Bank5 Block0x3F unsuccessfully.
Erase boot at CE0 Bank6 Block0x0 unsuccessfully.
Erase boot at CE0 Bank6 Block0x1 unsuccessfully.
Erase boot at CE0 Bank6 Block0x2 unsuccessfully.
Erase boot at CE0 Bank6 Block0x3 unsuccessfully.
Erase boot at CE0 Bank6 Block0x4 unsuccessfully.
Erase boot at CE0 Bank6 Block0x5 unsuccessfully.
Erase boot at CE0 Bank6 Block0x6 unsuccessfully.
Erase boot at CE0 Bank6 Block0x7 unsuccessfully.
Erase boot at CE0 Bank6 Block0x8 unsuccessfully.
Erase boot at CE0 Bank6 Block0x9 unsuccessfully.
Erase boot at CE0 Bank6 Block0xA unsuccessfully.
Erase boot at CE0 Bank6 Block0xB unsuccessfully.
Erase boot at CE0 Bank6 Block0xC unsuccessfully.
Erase boot at CE0 Bank6 Block0xD unsuccessfully.
Erase boot at CE0 Bank6 Block0xE unsuccessfully.
Erase boot at CE0 Bank6 Block0xF unsuccessfully.
Erase boot at CE0 Bank6 Block0x10 unsuccessfully.
Erase boot at CE0 Bank6 Block0x11 unsuccessfully.
Erase boot at CE0 Bank6 Block0x12 unsuccessfully.
Erase boot at CE0 Bank6 Block0x13 unsuccessfully.
Erase boot at CE0 Bank6 Block0x14 unsuccessfully.
Erase boot at CE0 Bank6 Block0x15 unsuccessfully.
Erase boot at CE0 Bank6 Block0x16 unsuccessfully.
Erase boot at CE0 Bank6 Block0x17 unsuccessfully.
Erase boot at CE0 Bank6 Block0x18 unsuccessfully.
Erase boot at CE0 Bank6 Block0x19 unsuccessfully.
Erase boot at CE0 Bank6 Block0x1A unsuccessfully.
Erase boot at CE0 Bank6 Block0x1B unsuccessfully.
Erase boot at CE0 Bank6 Block0x1C unsuccessfully.
Erase boot at CE0 Bank6 Block0x1D unsuccessfully.
Erase boot at CE0 Bank6 Block0x1E unsuccessfully.
Erase boot at CE0 Bank6 Block0x1F unsuccessfully.
Erase boot at CE0 Bank6 Block0x20 unsuccessfully.
Erase boot at CE0 Bank6 Block0x21 unsuccessfully.
Erase boot at CE0 Bank6 Block0x22 unsuccessfully.
Erase boot at CE0 Bank6 Block0x23 unsuccessfully.
Erase boot at CE0 Bank6 Block0x24 unsuccessfully.
Erase boot at CE0 Bank6 Block0x25 unsuccessfully.
Erase boot at CE0 Bank6 Block0x26 unsuccessfully.
Erase boot at CE0 Bank6 Block0x27 unsuccessfully.
Erase boot at CE0 Bank6 Block0x28 unsuccessfully.
Erase boot at CE0 Bank6 Block0x29 unsuccessfully.
Erase boot at CE0 Bank6 Block0x2A unsuccessfully.
Erase boot at CE0 Bank6 Block0x2B unsuccessfully.
Erase boot at CE0 Bank6 Block0x2C unsuccessfully.
Erase boot at CE0 Bank6 Block0x2D unsuccessfully.
Erase boot at CE0 Bank6 Block0x2E unsuccessfully.
Erase boot at CE0 Bank6 Block0x2F unsuccessfully.
Erase boot at CE0 Bank6 Block0x30 unsuccessfully.
Erase boot at CE0 Bank6 Block0x31 unsuccessfully.
Erase boot at CE0 Bank6 Block0x32 unsuccessfully.
Erase boot at CE0 Bank6 Block0x33 unsuccessfully.
Erase boot at CE0 Bank6 Block0x34 unsuccessfully.
Erase boot at CE0 Bank6 Block0x35 unsuccessfully.
Erase boot at CE0 Bank6 Block0x36 unsuccessfully.
Erase boot at CE0 Bank6 Block0x37 unsuccessfully.
Erase boot at CE0 Bank6 Block0x38 unsuccessfully.
Erase boot at CE0 Bank6 Block0x39 unsuccessfully.
Erase boot at CE0 Bank6 Block0x3A unsuccessfully.
Erase boot at CE0 Bank6 Block0x3B unsuccessfully.
Erase boot at CE0 Bank6 Block0x3C unsuccessfully.
Erase boot at CE0 Bank6 Block0x3D unsuccessfully.
Erase boot at CE0 Bank6 Block0x3E unsuccessfully.
Erase boot at CE0 Bank6 Block0x3F unsuccessfully.
Erase boot at CE0 Bank7 Block0x0 unsuccessfully.
Erase boot at CE0 Bank7 Block0x1 unsuccessfully.
Erase boot at CE0 Bank7 Block0x2 unsuccessfully.
Erase boot at CE0 Bank7 Block0x3 unsuccessfully.
Erase boot at CE0 Bank7 Block0x4 unsuccessfully.
Erase boot at CE0 Bank7 Block0x5 unsuccessfully.
Erase boot at CE0 Bank7 Block0x6 unsuccessfully.
Erase boot at CE0 Bank7 Block0x7 unsuccessfully.
Erase boot at CE0 Bank7 Block0x8 unsuccessfully.
Erase boot at CE0 Bank7 Block0x9 unsuccessfully.
Erase boot at CE0 Bank7 Block0xA unsuccessfully.
Erase boot at CE0 Bank7 Block0xB unsuccessfully.
Erase boot at CE0 Bank7 Block0xC unsuccessfully.
Erase boot at CE0 Bank7 Block0xD unsuccessfully.
Erase boot at CE0 Bank7 Block0xE unsuccessfully.
Erase boot at CE0 Bank7 Block0xF unsuccessfully.
Erase boot at CE0 Bank7 Block0x10 unsuccessfully.
Erase boot at CE0 Bank7 Block0x11 unsuccessfully.
Erase boot at CE0 Bank7 Block0x12 unsuccessfully.
Erase boot at CE0 Bank7 Block0x13 unsuccessfully.
Erase boot at CE0 Bank7 Block0x14 unsuccessfully.
Erase boot at CE0 Bank7 Block0x15 unsuccessfully.
Erase boot at CE0 Bank7 Block0x16 unsuccessfully.
Erase boot at CE0 Bank7 Block0x17 unsuccessfully.
Erase boot at CE0 Bank7 Block0x18 unsuccessfully.
Erase boot at CE0 Bank7 Block0x19 unsuccessfully.
Erase boot at CE0 Bank7 Block0x1A unsuccessfully.
Erase boot at CE0 Bank7 Block0x1B unsuccessfully.
Erase boot at CE0 Bank7 Block0x1C unsuccessfully.
Erase boot at CE0 Bank7 Block0x1D unsuccessfully.
Erase boot at CE0 Bank7 Block0x1E unsuccessfully.
Erase boot at CE0 Bank7 Block0x1F unsuccessfully.
Erase boot at CE0 Bank7 Block0x20 unsuccessfully.
Erase boot at CE0 Bank7 Block0x21 unsuccessfully.
Erase boot at CE0 Bank7 Block0x22 unsuccessfully.
Erase boot at CE0 Bank7 Block0x23 unsuccessfully.
Erase boot at CE0 Bank7 Block0x24 unsuccessfully.
Erase boot at CE0 Bank7 Block0x25 unsuccessfully.
Erase boot at CE0 Bank7 Block0x26 unsuccessfully.
Erase boot at CE0 Bank7 Block0x27 unsuccessfully.
Erase boot at CE0 Bank7 Block0x28 unsuccessfully.
Erase boot at CE0 Bank7 Block0x29 unsuccessfully.
Erase boot at CE0 Bank7 Block0x2A unsuccessfully.
Erase boot at CE0 Bank7 Block0x2B unsuccessfully.
Erase boot at CE0 Bank7 Block0x2C unsuccessfully.
Erase boot at CE0 Bank7 Block0x2D unsuccessfully.
Erase boot at CE0 Bank7 Block0x2E unsuccessfully.
Erase boot at CE0 Bank7 Block0x2F unsuccessfully.
Erase boot at CE0 Bank7 Block0x30 unsuccessfully.
Erase boot at CE0 Bank7 Block0x31 unsuccessfully.
Erase boot at CE0 Bank7 Block0x32 unsuccessfully.
Erase boot at CE0 Bank7 Block0x33 unsuccessfully.
Erase boot at CE0 Bank7 Block0x34 unsuccessfully.
Erase boot at CE0 Bank7 Block0x35 unsuccessfully.
Erase boot at CE0 Bank7 Block0x36 unsuccessfully.
Erase boot at CE0 Bank7 Block0x37 unsuccessfully.
Erase boot at CE0 Bank7 Block0x38 unsuccessfully.
Erase boot at CE0 Bank7 Block0x39 unsuccessfully.
Erase boot at CE0 Bank7 Block0x3A unsuccessfully.
Erase boot at CE0 Bank7 Block0x3B unsuccessfully.
Erase boot at CE0 Bank7 Block0x3C unsuccessfully.
Erase boot at CE0 Bank7 Block0x3D unsuccessfully.
Erase boot at CE0 Bank7 Block0x3E unsuccessfully.
Erase boot at CE0 Bank7 Block0x3F unsuccessfully.
Erase boot at CE1 Bank4 Block0x0 unsuccessfully.
Erase boot at CE1 Bank4 Block0x1 unsuccessfully.
Erase boot at CE1 Bank4 Block0x2 unsuccessfully.
Erase boot at CE1 Bank4 Block0x3 unsuccessfully.
Erase boot at CE1 Bank4 Block0x4 unsuccessfully.
Erase boot at CE1 Bank4 Block0x5 unsuccessfully.
Erase boot at CE1 Bank4 Block0x6 unsuccessfully.
Erase boot at CE1 Bank4 Block0x7 unsuccessfully.
Erase boot at CE1 Bank4 Block0x8 unsuccessfully.
Erase boot at CE1 Bank4 Block0x9 unsuccessfully.
Erase boot at CE1 Bank4 Block0xA unsuccessfully.
Erase boot at CE1 Bank4 Block0xB unsuccessfully.
Erase boot at CE1 Bank4 Block0xC unsuccessfully.
Erase boot at CE1 Bank4 Block0xD unsuccessfully.
Erase boot at CE1 Bank4 Block0xE unsuccessfully.
Erase boot at CE1 Bank4 Block0xF unsuccessfully.
Erase boot at CE1 Bank4 Block0x10 unsuccessfully.
Erase boot at CE1 Bank4 Block0x11 unsuccessfully.
Erase boot at CE1 Bank4 Block0x12 unsuccessfully.
Erase boot at CE1 Bank4 Block0x13 unsuccessfully.
Erase boot at CE1 Bank4 Block0x14 unsuccessfully.
Erase boot at CE1 Bank4 Block0x15 unsuccessfully.
Erase boot at CE1 Bank4 Block0x16 unsuccessfully.
Erase boot at CE1 Bank4 Block0x17 unsuccessfully.
Erase boot at CE1 Bank4 Block0x18 unsuccessfully.
Erase boot at CE1 Bank4 Block0x19 unsuccessfully.
Erase boot at CE1 Bank4 Block0x1A unsuccessfully.
Erase boot at CE1 Bank4 Block0x1B unsuccessfully.
Erase boot at CE1 Bank4 Block0x1C unsuccessfully.
Erase boot at CE1 Bank4 Block0x1D unsuccessfully.
Erase boot at CE1 Bank4 Block0x1E unsuccessfully.
Erase boot at CE1 Bank4 Block0x1F unsuccessfully.
Erase boot at CE1 Bank4 Block0x20 unsuccessfully.
Erase boot at CE1 Bank4 Block0x21 unsuccessfully.
Erase boot at CE1 Bank4 Block0x22 unsuccessfully.
Erase boot at CE1 Bank4 Block0x23 unsuccessfully.
Erase boot at CE1 Bank4 Block0x24 unsuccessfully.
Erase boot at CE1 Bank4 Block0x25 unsuccessfully.
Erase boot at CE1 Bank4 Block0x26 unsuccessfully.
Erase boot at CE1 Bank4 Block0x27 unsuccessfully.
Erase boot at CE1 Bank4 Block0x28 unsuccessfully.
Erase boot at CE1 Bank4 Block0x29 unsuccessfully.
Erase boot at CE1 Bank4 Block0x2A unsuccessfully.
Erase boot at CE1 Bank4 Block0x2B unsuccessfully.
Erase boot at CE1 Bank4 Block0x2C unsuccessfully.
Erase boot at CE1 Bank4 Block0x2D unsuccessfully.
Erase boot at CE1 Bank4 Block0x2E unsuccessfully.
Erase boot at CE1 Bank4 Block0x2F unsuccessfully.
Erase boot at CE1 Bank4 Block0x30 unsuccessfully.
Erase boot at CE1 Bank4 Block0x31 unsuccessfully.
Erase boot at CE1 Bank4 Block0x32 unsuccessfully.
Erase boot at CE1 Bank4 Block0x33 unsuccessfully.
Erase boot at CE1 Bank4 Block0x34 unsuccessfully.
Erase boot at CE1 Bank4 Block0x35 unsuccessfully.
Erase boot at CE1 Bank4 Block0x36 unsuccessfully.
Erase boot at CE1 Bank4 Block0x37 unsuccessfully.
Erase boot at CE1 Bank4 Block0x38 unsuccessfully.
Erase boot at CE1 Bank4 Block0x39 unsuccessfully.
Erase boot at CE1 Bank4 Block0x3A unsuccessfully.
Erase boot at CE1 Bank4 Block0x3B unsuccessfully.
Erase boot at CE1 Bank4 Block0x3C unsuccessfully.
Erase boot at CE1 Bank4 Block0x3D unsuccessfully.
Erase boot at CE1 Bank4 Block0x3E unsuccessfully.
Erase boot at CE1 Bank4 Block0x3F unsuccessfully.
Erase boot at CE1 Bank5 Block0x0 unsuccessfully.
Erase boot at CE1 Bank5 Block0x1 unsuccessfully.
Erase boot at CE1 Bank5 Block0x2 unsuccessfully.
Erase boot at CE1 Bank5 Block0x3 unsuccessfully.
Erase boot at CE1 Bank5 Block0x4 unsuccessfully.
Erase boot at CE1 Bank5 Block0x5 unsuccessfully.
Erase boot at CE1 Bank5 Block0x6 unsuccessfully.
Erase boot at CE1 Bank5 Block0x7 unsuccessfully.
Erase boot at CE1 Bank5 Block0x8 unsuccessfully.
Erase boot at CE1 Bank5 Block0x9 unsuccessfully.
Erase boot at CE1 Bank5 Block0xA unsuccessfully.
Erase boot at CE1 Bank5 Block0xB unsuccessfully.
Erase boot at CE1 Bank5 Block0xC unsuccessfully.
Erase boot at CE1 Bank5 Block0xD unsuccessfully.
Erase boot at CE1 Bank5 Block0xE unsuccessfully.
Erase boot at CE1 Bank5 Block0xF unsuccessfully.
Erase boot at CE1 Bank5 Block0x10 unsuccessfully.
Erase boot at CE1 Bank5 Block0x11 unsuccessfully.
Erase boot at CE1 Bank5 Block0x12 unsuccessfully.
Erase boot at CE1 Bank5 Block0x13 unsuccessfully.
Erase boot at CE1 Bank5 Block0x14 unsuccessfully.
Erase boot at CE1 Bank5 Block0x15 unsuccessfully.
Erase boot at CE1 Bank5 Block0x16 unsuccessfully.
Erase boot at CE1 Bank5 Block0x17 unsuccessfully.
Erase boot at CE1 Bank5 Block0x18 unsuccessfully.
Erase boot at CE1 Bank5 Block0x19 unsuccessfully.
Erase boot at CE1 Bank5 Block0x1A unsuccessfully.
Erase boot at CE1 Bank5 Block0x1B unsuccessfully.
Erase boot at CE1 Bank5 Block0x1C unsuccessfully.
Erase boot at CE1 Bank5 Block0x1D unsuccessfully.
Erase boot at CE1 Bank5 Block0x1E unsuccessfully.
Erase boot at CE1 Bank5 Block0x1F unsuccessfully.
Erase boot at CE1 Bank5 Block0x20 unsuccessfully.
Erase boot at CE1 Bank5 Block0x21 unsuccessfully.
Erase boot at CE1 Bank5 Block0x22 unsuccessfully.
Erase boot at CE1 Bank5 Block0x23 unsuccessfully.
Erase boot at CE1 Bank5 Block0x24 unsuccessfully.
Erase boot at CE1 Bank5 Block0x25 unsuccessfully.
Erase boot at CE1 Bank5 Block0x26 unsuccessfully.
Erase boot at CE1 Bank5 Block0x27 unsuccessfully.
Erase boot at CE1 Bank5 Block0x28 unsuccessfully.
Erase boot at CE1 Bank5 Block0x29 unsuccessfully.
Erase boot at CE1 Bank5 Block0x2A unsuccessfully.
Erase boot at CE1 Bank5 Block0x2B unsuccessfully.
Erase boot at CE1 Bank5 Block0x2C unsuccessfully.
Erase boot at CE1 Bank5 Block0x2D unsuccessfully.
Erase boot at CE1 Bank5 Block0x2E unsuccessfully.
Erase boot at CE1 Bank5 Block0x2F unsuccessfully.
Erase boot at CE1 Bank5 Block0x30 unsuccessfully.
Erase boot at CE1 Bank5 Block0x31 unsuccessfully.
Erase boot at CE1 Bank5 Block0x32 unsuccessfully.
Erase boot at CE1 Bank5 Block0x33 unsuccessfully.
Erase boot at CE1 Bank5 Block0x34 unsuccessfully.
Erase boot at CE1 Bank5 Block0x35 unsuccessfully.
Erase boot at CE1 Bank5 Block0x36 unsuccessfully.
Erase boot at CE1 Bank5 Block0x37 unsuccessfully.
Erase boot at CE1 Bank5 Block0x38 unsuccessfully.
Erase boot at CE1 Bank5 Block0x39 unsuccessfully.
Erase boot at CE1 Bank5 Block0x3A unsuccessfully.
Erase boot at CE1 Bank5 Block0x3B unsuccessfully.
Erase boot at CE1 Bank5 Block0x3C unsuccessfully.
Erase boot at CE1 Bank5 Block0x3D unsuccessfully.
Erase boot at CE1 Bank5 Block0x3E unsuccessfully.
Erase boot at CE1 Bank5 Block0x3F unsuccessfully.
Erase boot at CE1 Bank6 Block0x0 unsuccessfully.
Erase boot at CE1 Bank6 Block0x1 unsuccessfully.
Erase boot at CE1 Bank6 Block0x2 unsuccessfully.
Erase boot at CE1 Bank6 Block0x3 unsuccessfully.
Erase boot at CE1 Bank6 Block0x4 unsuccessfully.
Erase boot at CE1 Bank6 Block0x5 unsuccessfully.
Erase boot at CE1 Bank6 Block0x6 unsuccessfully.
Erase boot at CE1 Bank6 Block0x7 unsuccessfully.
Erase boot at CE1 Bank6 Block0x8 unsuccessfully.
Erase boot at CE1 Bank6 Block0x9 unsuccessfully.
Erase boot at CE1 Bank6 Block0xA unsuccessfully.
Erase boot at CE1 Bank6 Block0xB unsuccessfully.
Erase boot at CE1 Bank6 Block0xC unsuccessfully.
Erase boot at CE1 Bank6 Block0xD unsuccessfully.
Erase boot at CE1 Bank6 Block0xE unsuccessfully.
Erase boot at CE1 Bank6 Block0xF unsuccessfully.
Erase boot at CE1 Bank6 Block0x10 unsuccessfully.
Erase boot at CE1 Bank6 Block0x11 unsuccessfully.
Erase boot at CE1 Bank6 Block0x12 unsuccessfully.
Erase boot at CE1 Bank6 Block0x13 unsuccessfully.
Erase boot at CE1 Bank6 Block0x14 unsuccessfully.
Erase boot at CE1 Bank6 Block0x15 unsuccessfully.
Erase boot at CE1 Bank6 Block0x16 unsuccessfully.
Erase boot at CE1 Bank6 Block0x17 unsuccessfully.
Erase boot at CE1 Bank6 Block0x18 unsuccessfully.
Erase boot at CE1 Bank6 Block0x19 unsuccessfully.
Erase boot at CE1 Bank6 Block0x1A unsuccessfully.
Erase boot at CE1 Bank6 Block0x1B unsuccessfully.
Erase boot at CE1 Bank6 Block0x1C unsuccessfully.
Erase boot at CE1 Bank6 Block0x1D unsuccessfully.
Erase boot at CE1 Bank6 Block0x1E unsuccessfully.
Erase boot at CE1 Bank6 Block0x1F unsuccessfully.
Erase boot at CE1 Bank6 Block0x20 unsuccessfully.
Erase boot at CE1 Bank6 Block0x21 unsuccessfully.
Erase boot at CE1 Bank6 Block0x22 unsuccessfully.
Erase boot at CE1 Bank6 Block0x23 unsuccessfully.
Erase boot at CE1 Bank6 Block0x24 unsuccessfully.
Erase boot at CE1 Bank6 Block0x25 unsuccessfully.
Erase boot at CE1 Bank6 Block0x26 unsuccessfully.
Erase boot at CE1 Bank6 Block0x27 unsuccessfully.
Erase boot at CE1 Bank6 Block0x28 unsuccessfully.
Erase boot at CE1 Bank6 Block0x29 unsuccessfully.
Erase boot at CE1 Bank6 Block0x2A unsuccessfully.
Erase boot at CE1 Bank6 Block0x2B unsuccessfully.
Erase boot at CE1 Bank6 Block0x2C unsuccessfully.
Erase boot at CE1 Bank6 Block0x2D unsuccessfully.
Erase boot at CE1 Bank6 Block0x2E unsuccessfully.
Erase boot at CE1 Bank6 Block0x2F unsuccessfully.
Erase boot at CE1 Bank6 Block0x30 unsuccessfully.
Erase boot at CE1 Bank6 Block0x31 unsuccessfully.
Erase boot at CE1 Bank6 Block0x32 unsuccessfully.
Erase boot at CE1 Bank6 Block0x33 unsuccessfully.
Erase boot at CE1 Bank6 Block0x34 unsuccessfully.
Erase boot at CE1 Bank6 Block0x35 unsuccessfully.
Erase boot at CE1 Bank6 Block0x36 unsuccessfully.
Erase boot at CE1 Bank6 Block0x37 unsuccessfully.
Erase boot at CE1 Bank6 Block0x38 unsuccessfully.
Erase boot at CE1 Bank6 Block0x39 unsuccessfully.
Erase boot at CE1 Bank6 Block0x3A unsuccessfully.
Erase boot at CE1 Bank6 Block0x3B unsuccessfully.
Erase boot at CE1 Bank6 Block0x3C unsuccessfully.
Erase boot at CE1 Bank6 Block0x3D unsuccessfully.
Erase boot at CE1 Bank6 Block0x3E unsuccessfully.
Erase boot at CE1 Bank6 Block0x3F unsuccessfully.
Erase boot at CE1 Bank7 Block0x0 unsuccessfully.
Erase boot at CE1 Bank7 Block0x1 unsuccessfully.
Erase boot at CE1 Bank7 Block0x2 unsuccessfully.
Erase boot at CE1 Bank7 Block0x3 unsuccessfully.
Erase boot at CE1 Bank7 Block0x4 unsuccessfully.
Erase boot at CE1 Bank7 Block0x5 unsuccessfully.
Erase boot at CE1 Bank7 Block0x6 unsuccessfully.
Erase boot at CE1 Bank7 Block0x7 unsuccessfully.
Erase boot at CE1 Bank7 Block0x8 unsuccessfully.
Erase boot at CE1 Bank7 Block0x9 unsuccessfully.
Erase boot at CE1 Bank7 Block0xA unsuccessfully.
Erase boot at CE1 Bank7 Block0xB unsuccessfully.
Erase boot at CE1 Bank7 Block0xC unsuccessfully.
Erase boot at CE1 Bank7 Block0xD unsuccessfully.
Erase boot at CE1 Bank7 Block0xE unsuccessfully.
Erase boot at CE1 Bank7 Block0xF unsuccessfully.
Erase boot at CE1 Bank7 Block0x10 unsuccessfully.
Erase boot at CE1 Bank7 Block0x11 unsuccessfully.
Erase boot at CE1 Bank7 Block0x12 unsuccessfully.
Erase boot at CE1 Bank7 Block0x13 unsuccessfully.
Erase boot at CE1 Bank7 Block0x14 unsuccessfully.
Erase boot at CE1 Bank7 Block0x15 unsuccessfully.
Erase boot at CE1 Bank7 Block0x16 unsuccessfully.
Erase boot at CE1 Bank7 Block0x17 unsuccessfully.
Erase boot at CE1 Bank7 Block0x18 unsuccessfully.
Erase boot at CE1 Bank7 Block0x19 unsuccessfully.
Erase boot at CE1 Bank7 Block0x1A unsuccessfully.
Erase boot at CE1 Bank7 Block0x1B unsuccessfully.
Erase boot at CE1 Bank7 Block0x1C unsuccessfully.
Erase boot at CE1 Bank7 Block0x1D unsuccessfully.
Erase boot at CE1 Bank7 Block0x1E unsuccessfully.
Erase boot at CE1 Bank7 Block0x1F unsuccessfully.
Erase boot at CE1 Bank7 Block0x20 unsuccessfully.
Erase boot at CE1 Bank7 Block0x21 unsuccessfully.
Erase boot at CE1 Bank7 Block0x22 unsuccessfully.
Erase boot at CE1 Bank7 Block0x23 unsuccessfully.
Erase boot at CE1 Bank7 Block0x24 unsuccessfully.
Erase boot at CE1 Bank7 Block0x25 unsuccessfully.
Erase boot at CE1 Bank7 Block0x26 unsuccessfully.
Erase boot at CE1 Bank7 Block0x27 unsuccessfully.
Erase boot at CE1 Bank7 Block0x28 unsuccessfully.
Erase boot at CE1 Bank7 Block0x29 unsuccessfully.
Erase boot at CE1 Bank7 Block0x2A unsuccessfully.
Erase boot at CE1 Bank7 Block0x2B unsuccessfully.
Erase boot at CE1 Bank7 Block0x2C unsuccessfully.
Erase boot at CE1 Bank7 Block0x2D unsuccessfully.
Erase boot at CE1 Bank7 Block0x2E unsuccessfully.
Erase boot at CE1 Bank7 Block0x2F unsuccessfully.
Erase boot at CE1 Bank7 Block0x30 unsuccessfully.
Erase boot at CE1 Bank7 Block0x31 unsuccessfully.
Erase boot at CE1 Bank7 Block0x32 unsuccessfully.
Erase boot at CE1 Bank7 Block0x33 unsuccessfully.
Erase boot at CE1 Bank7 Block0x34 unsuccessfully.
Erase boot at CE1 Bank7 Block0x35 unsuccessfully.
Erase boot at CE1 Bank7 Block0x36 unsuccessfully.
Erase boot at CE1 Bank7 Block0x37 unsuccessfully.
Erase boot at CE1 Bank7 Block0x38 unsuccessfully.
Erase boot at CE1 Bank7 Block0x39 unsuccessfully.
Erase boot at CE1 Bank7 Block0x3A unsuccessfully.
Erase boot at CE1 Bank7 Block0x3B unsuccessfully.
Erase boot at CE1 Bank7 Block0x3C unsuccessfully.
Erase boot at CE1 Bank7 Block0x3D unsuccessfully.
Erase boot at CE1 Bank7 Block0x3E unsuccessfully.
Erase boot at CE1 Bank7 Block0x3F unsuccessfully.
Erase boot at CE0 Bank0 Block0x820 unsuccessfully.
Erase boot at CE0 Bank0 Block0x821 unsuccessfully.
Erase boot at CE0 Bank0 Block0x822 unsuccessfully.
Erase boot at CE0 Bank0 Block0x823 unsuccessfully.
Erase boot at CE0 Bank0 Block0x824 unsuccessfully.
Erase boot at CE0 Bank0 Block0x825 unsuccessfully.
Erase boot at CE0 Bank0 Block0x826 unsuccessfully.
Erase boot at CE0 Bank0 Block0x827 unsuccessfully.
Erase boot at CE0 Bank0 Block0x828 unsuccessfully.
Erase boot at CE0 Bank0 Block0x829 unsuccessfully.
Erase boot at CE0 Bank0 Block0x82A unsuccessfully.
Erase boot at CE0 Bank0 Block0x82B unsuccessfully.
Erase boot at CE0 Bank0 Block0x82C unsuccessfully.
Erase boot at CE0 Bank0 Block0x82D unsuccessfully.
Erase boot at CE0 Bank0 Block0x82E unsuccessfully.
Erase boot at CE0 Bank0 Block0x82F unsuccessfully.
Erase boot at CE0 Bank1 Block0x820 unsuccessfully.
Erase boot at CE0 Bank1 Block0x821 unsuccessfully.
Erase boot at CE0 Bank1 Block0x822 unsuccessfully.
Erase boot at CE0 Bank1 Block0x823 unsuccessfully.
Erase boot at CE0 Bank1 Block0x824 unsuccessfully.
Erase boot at CE0 Bank1 Block0x825 unsuccessfully.
Erase boot at CE0 Bank1 Block0x826 unsuccessfully.
Erase boot at CE0 Bank1 Block0x827 unsuccessfully.
Erase boot at CE0 Bank1 Block0x828 unsuccessfully.
Erase boot at CE0 Bank1 Block0x829 unsuccessfully.
Erase boot at CE0 Bank1 Block0x82A unsuccessfully.
Erase boot at CE0 Bank1 Block0x82B unsuccessfully.
Erase boot at CE0 Bank1 Block0x82C unsuccessfully.
Erase boot at CE0 Bank1 Block0x82D unsuccessfully.
Erase boot at CE0 Bank1 Block0x82E unsuccessfully.
Erase boot at CE0 Bank1 Block0x82F unsuccessfully.
Erase boot at CE0 Bank2 Block0x820 unsuccessfully.
Erase boot at CE0 Bank2 Block0x821 unsuccessfully.
Erase boot at CE0 Bank2 Block0x822 unsuccessfully.
Erase boot at CE0 Bank2 Block0x823 unsuccessfully.
Erase boot at CE0 Bank2 Block0x824 unsuccessfully.
Erase boot at CE0 Bank2 Block0x825 unsuccessfully.
Erase boot at CE0 Bank2 Block0x826 unsuccessfully.
Erase boot at CE0 Bank2 Block0x827 unsuccessfully.
Erase boot at CE0 Bank2 Block0x828 unsuccessfully.
Erase boot at CE0 Bank2 Block0x829 unsuccessfully.
Erase boot at CE0 Bank2 Block0x82A unsuccessfully.
Erase boot at CE0 Bank2 Block0x82B unsuccessfully.
Erase boot at CE0 Bank2 Block0x82C unsuccessfully.
Erase boot at CE0 Bank2 Block0x82D unsuccessfully.
Erase boot at CE0 Bank2 Block0x82E unsuccessfully.
Erase boot at CE0 Bank2 Block0x82F unsuccessfully.
Erase boot at CE0 Bank3 Block0x820 unsuccessfully.
Erase boot at CE0 Bank3 Block0x821 unsuccessfully.
Erase boot at CE0 Bank3 Block0x822 unsuccessfully.
Erase boot at CE0 Bank3 Block0x823 unsuccessfully.
Erase boot at CE0 Bank3 Block0x824 unsuccessfully.
Erase boot at CE0 Bank3 Block0x825 unsuccessfully.
Erase boot at CE0 Bank3 Block0x826 unsuccessfully.
Erase boot at CE0 Bank3 Block0x827 unsuccessfully.
Erase boot at CE0 Bank3 Block0x828 unsuccessfully.
Erase boot at CE0 Bank3 Block0x829 unsuccessfully.
Erase boot at CE0 Bank3 Block0x82A unsuccessfully.
Erase boot at CE0 Bank3 Block0x82B unsuccessfully.
Erase boot at CE0 Bank3 Block0x82C unsuccessfully.
Erase boot at CE0 Bank3 Block0x82D unsuccessfully.
Erase boot at CE0 Bank3 Block0x82E unsuccessfully.
Erase boot at CE0 Bank3 Block0x82F unsuccessfully.
Erase boot at CE0 Bank4 Block0x820 unsuccessfully.
Erase boot at CE0 Bank4 Block0x821 unsuccessfully.
Erase boot at CE0 Bank4 Block0x822 unsuccessfully.
Erase boot at CE0 Bank4 Block0x823 unsuccessfully.
Erase boot at CE0 Bank4 Block0x824 unsuccessfully.
Erase boot at CE0 Bank4 Block0x825 unsuccessfully.
Erase boot at CE0 Bank4 Block0x826 unsuccessfully.
Erase boot at CE0 Bank4 Block0x827 unsuccessfully.
Erase boot at CE0 Bank4 Block0x828 unsuccessfully.
Erase boot at CE0 Bank4 Block0x829 unsuccessfully.
Erase boot at CE0 Bank4 Block0x82A unsuccessfully.
Erase boot at CE0 Bank4 Block0x82B unsuccessfully.
Erase boot at CE0 Bank4 Block0x82C unsuccessfully.
Erase boot at CE0 Bank4 Block0x82D unsuccessfully.
Erase boot at CE0 Bank4 Block0x82E unsuccessfully.
Erase boot at CE0 Bank4 Block0x82F unsuccessfully.
Erase boot at CE0 Bank5 Block0x820 unsuccessfully.
Erase boot at CE0 Bank5 Block0x821 unsuccessfully.
Erase boot at CE0 Bank5 Block0x822 unsuccessfully.
Erase boot at CE0 Bank5 Block0x823 unsuccessfully.
Erase boot at CE0 Bank5 Block0x824 unsuccessfully.
Erase boot at CE0 Bank5 Block0x825 unsuccessfully.
Erase boot at CE0 Bank5 Block0x826 unsuccessfully.
Erase boot at CE0 Bank5 Block0x827 unsuccessfully.
Erase boot at CE0 Bank5 Block0x828 unsuccessfully.
Erase boot at CE0 Bank5 Block0x829 unsuccessfully.
Erase boot at CE0 Bank5 Block0x82A unsuccessfully.
Erase boot at CE0 Bank5 Block0x82B unsuccessfully.
Erase boot at CE0 Bank5 Block0x82C unsuccessfully.
Erase boot at CE0 Bank5 Block0x82D unsuccessfully.
Erase boot at CE0 Bank5 Block0x82E unsuccessfully.
Erase boot at CE0 Bank5 Block0x82F unsuccessfully.
Erase boot at CE0 Bank6 Block0x820 unsuccessfully.
Erase boot at CE0 Bank6 Block0x821 unsuccessfully.
Erase boot at CE0 Bank6 Block0x822 unsuccessfully.
Erase boot at CE0 Bank6 Block0x823 unsuccessfully.
Erase boot at CE0 Bank6 Block0x824 unsuccessfully.
Erase boot at CE0 Bank6 Block0x825 unsuccessfully.
Erase boot at CE0 Bank6 Block0x826 unsuccessfully.
Erase boot at CE0 Bank6 Block0x827 unsuccessfully.
Erase boot at CE0 Bank6 Block0x828 unsuccessfully.
Erase boot at CE0 Bank6 Block0x829 unsuccessfully.
Erase boot at CE0 Bank6 Block0x82A unsuccessfully.
Erase boot at CE0 Bank6 Block0x82B unsuccessfully.
Erase boot at CE0 Bank6 Block0x82C unsuccessfully.
Erase boot at CE0 Bank6 Block0x82D unsuccessfully.
Erase boot at CE0 Bank6 Block0x82E unsuccessfully.
Erase boot at CE0 Bank6 Block0x82F unsuccessfully.
Erase boot at CE0 Bank7 Block0x820 unsuccessfully.
Erase boot at CE0 Bank7 Block0x821 unsuccessfully.
Erase boot at CE0 Bank7 Block0x822 unsuccessfully.
Erase boot at CE0 Bank7 Block0x823 unsuccessfully.
Erase boot at CE0 Bank7 Block0x824 unsuccessfully.
Erase boot at CE0 Bank7 Block0x825 unsuccessfully.
Erase boot at CE0 Bank7 Block0x826 unsuccessfully.
Erase boot at CE0 Bank7 Block0x827 unsuccessfully.
Erase boot at CE0 Bank7 Block0x828 unsuccessfully.
Erase boot at CE0 Bank7 Block0x829 unsuccessfully.
Erase boot at CE0 Bank7 Block0x82A unsuccessfully.
Erase boot at CE0 Bank7 Block0x82B unsuccessfully.
Erase boot at CE0 Bank7 Block0x82C unsuccessfully.
Erase boot at CE0 Bank7 Block0x82D unsuccessfully.
Erase boot at CE0 Bank7 Block0x82E unsuccessfully.
Erase boot at CE0 Bank7 Block0x82F unsuccessfully.
Erase boot at CE1 Bank0 Block0x820 unsuccessfully.
Erase boot at CE1 Bank0 Block0x821 unsuccessfully.
Erase boot at CE1 Bank0 Block0x822 unsuccessfully.
Erase boot at CE1 Bank0 Block0x823 unsuccessfully.
Erase boot at CE1 Bank0 Block0x824 unsuccessfully.
Erase boot at CE1 Bank0 Block0x825 unsuccessfully.
Erase boot at CE1 Bank0 Block0x826 unsuccessfully.
Erase boot at CE1 Bank0 Block0x827 unsuccessfully.
Erase boot at CE1 Bank0 Block0x828 unsuccessfully.
Erase boot at CE1 Bank0 Block0x829 unsuccessfully.
Erase boot at CE1 Bank0 Block0x82A unsuccessfully.
Erase boot at CE1 Bank0 Block0x82B unsuccessfully.
Erase boot at CE1 Bank0 Block0x82C unsuccessfully.
Erase boot at CE1 Bank0 Block0x82D unsuccessfully.
Erase boot at CE1 Bank0 Block0x82E unsuccessfully.
Erase boot at CE1 Bank0 Block0x82F unsuccessfully.
Erase boot at CE1 Bank1 Block0x820 unsuccessfully.
Erase boot at CE1 Bank1 Block0x821 unsuccessfully.
Erase boot at CE1 Bank1 Block0x822 unsuccessfully.
Erase boot at CE1 Bank1 Block0x823 unsuccessfully.
Erase boot at CE1 Bank1 Block0x824 unsuccessfully.
Erase boot at CE1 Bank1 Block0x825 unsuccessfully.
Erase boot at CE1 Bank1 Block0x826 unsuccessfully.
Erase boot at CE1 Bank1 Block0x827 unsuccessfully.
Erase boot at CE1 Bank1 Block0x828 unsuccessfully.
Erase boot at CE1 Bank1 Block0x829 unsuccessfully.
Erase boot at CE1 Bank1 Block0x82A unsuccessfully.
Erase boot at CE1 Bank1 Block0x82B unsuccessfully.
Erase boot at CE1 Bank1 Block0x82C unsuccessfully.
Erase boot at CE1 Bank1 Block0x82D unsuccessfully.
Erase boot at CE1 Bank1 Block0x82E unsuccessfully.
Erase boot at CE1 Bank1 Block0x82F unsuccessfully.
Erase boot at CE1 Bank2 Block0x820 unsuccessfully.
Erase boot at CE1 Bank2 Block0x821 unsuccessfully.
Erase boot at CE1 Bank2 Block0x822 unsuccessfully.
Erase boot at CE1 Bank2 Block0x823 unsuccessfully.
Erase boot at CE1 Bank2 Block0x824 unsuccessfully.
Erase boot at CE1 Bank2 Block0x825 unsuccessfully.
Erase boot at CE1 Bank2 Block0x826 unsuccessfully.
Erase boot at CE1 Bank2 Block0x827 unsuccessfully.
Erase boot at CE1 Bank2 Block0x828 unsuccessfully.
Erase boot at CE1 Bank2 Block0x829 unsuccessfully.
Erase boot at CE1 Bank2 Block0x82A unsuccessfully.
Erase boot at CE1 Bank2 Block0x82B unsuccessfully.
Erase boot at CE1 Bank2 Block0x82C unsuccessfully.
Erase boot at CE1 Bank2 Block0x82D unsuccessfully.
Erase boot at CE1 Bank2 Block0x82E unsuccessfully.
Erase boot at CE1 Bank2 Block0x82F unsuccessfully.
Erase boot at CE1 Bank3 Block0x820 unsuccessfully.
Erase boot at CE1 Bank3 Block0x821 unsuccessfully.
Erase boot at CE1 Bank3 Block0x822 unsuccessfully.
Erase boot at CE1 Bank3 Block0x823 unsuccessfully.
Erase boot at CE1 Bank3 Block0x824 unsuccessfully.
Erase boot at CE1 Bank3 Block0x825 unsuccessfully.
Erase boot at CE1 Bank3 Block0x826 unsuccessfully.
Erase boot at CE1 Bank3 Block0x827 unsuccessfully.
Erase boot at CE1 Bank3 Block0x828 unsuccessfully.
Erase boot at CE1 Bank3 Block0x829 unsuccessfully.
Erase boot at CE1 Bank3 Block0x82A unsuccessfully.
Erase boot at CE1 Bank3 Block0x82B unsuccessfully.
Erase boot at CE1 Bank3 Block0x82C unsuccessfully.
Erase boot at CE1 Bank3 Block0x82D unsuccessfully.
Erase boot at CE1 Bank3 Block0x82E unsuccessfully.
Erase boot at CE1 Bank3 Block0x82F unsuccessfully.
Erase boot at CE1 Bank4 Block0x820 unsuccessfully.
Erase boot at CE1 Bank4 Block0x821 unsuccessfully.
Erase boot at CE1 Bank4 Block0x822 unsuccessfully.
Erase boot at CE1 Bank4 Block0x823 unsuccessfully.
Erase boot at CE1 Bank4 Block0x824 unsuccessfully.
Erase boot at CE1 Bank4 Block0x825 unsuccessfully.
Erase boot at CE1 Bank4 Block0x826 unsuccessfully.
Erase boot at CE1 Bank4 Block0x827 unsuccessfully.
Erase boot at CE1 Bank4 Block0x828 unsuccessfully.
Erase boot at CE1 Bank4 Block0x829 unsuccessfully.
Erase boot at CE1 Bank4 Block0x82A unsuccessfully.
Erase boot at CE1 Bank4 Block0x82B unsuccessfully.
Erase boot at CE1 Bank4 Block0x82C unsuccessfully.
Erase boot at CE1 Bank4 Block0x82D unsuccessfully.
Erase boot at CE1 Bank4 Block0x82E unsuccessfully.
Erase boot at CE1 Bank4 Block0x82F unsuccessfully.
Erase boot at CE1 Bank5 Block0x820 unsuccessfully.
Erase boot at CE1 Bank5 Block0x821 unsuccessfully.
Erase boot at CE1 Bank5 Block0x822 unsuccessfully.
Erase boot at CE1 Bank5 Block0x823 unsuccessfully.
Erase boot at CE1 Bank5 Block0x824 unsuccessfully.
Erase boot at CE1 Bank5 Block0x825 unsuccessfully.
Erase boot at CE1 Bank5 Block0x826 unsuccessfully.
Erase boot at CE1 Bank5 Block0x827 unsuccessfully.
Erase boot at CE1 Bank5 Block0x828 unsuccessfully.
Erase boot at CE1 Bank5 Block0x829 unsuccessfully.
Erase boot at CE1 Bank5 Block0x82A unsuccessfully.
Erase boot at CE1 Bank5 Block0x82B unsuccessfully.
Erase boot at CE1 Bank5 Block0x82C unsuccessfully.
Erase boot at CE1 Bank5 Block0x82D unsuccessfully.
Erase boot at CE1 Bank5 Block0x82E unsuccessfully.
Erase boot at CE1 Bank5 Block0x82F unsuccessfully.
Erase boot at CE1 Bank6 Block0x820 unsuccessfully.
Erase boot at CE1 Bank6 Block0x821 unsuccessfully.
Erase boot at CE1 Bank6 Block0x822 unsuccessfully.
Erase boot at CE1 Bank6 Block0x823 unsuccessfully.
Erase boot at CE1 Bank6 Block0x824 unsuccessfully.
Erase boot at CE1 Bank6 Block0x825 unsuccessfully.
Erase boot at CE1 Bank6 Block0x826 unsuccessfully.
Erase boot at CE1 Bank6 Block0x827 unsuccessfully.
Erase boot at CE1 Bank6 Block0x828 unsuccessfully.
Erase boot at CE1 Bank6 Block0x829 unsuccessfully.
Erase boot at CE1 Bank6 Block0x82A unsuccessfully.
Erase boot at CE1 Bank6 Block0x82B unsuccessfully.
Erase boot at CE1 Bank6 Block0x82C unsuccessfully.
Erase boot at CE1 Bank6 Block0x82D unsuccessfully.
Erase boot at CE1 Bank6 Block0x82E unsuccessfully.
Erase boot at CE1 Bank6 Block0x82F unsuccessfully.
Erase boot at CE1 Bank7 Block0x820 unsuccessfully.
Erase boot at CE1 Bank7 Block0x821 unsuccessfully.
Erase boot at CE1 Bank7 Block0x822 unsuccessfully.
Erase boot at CE1 Bank7 Block0x823 unsuccessfully.
Erase boot at CE1 Bank7 Block0x824 unsuccessfully.
Erase boot at CE1 Bank7 Block0x825 unsuccessfully.
Erase boot at CE1 Bank7 Block0x826 unsuccessfully.
Erase boot at CE1 Bank7 Block0x827 unsuccessfully.
Erase boot at CE1 Bank7 Block0x828 unsuccessfully.
Erase boot at CE1 Bank7 Block0x829 unsuccessfully.
Erase boot at CE1 Bank7 Block0x82A unsuccessfully.
Erase boot at CE1 Bank7 Block0x82B unsuccessfully.
Erase boot at CE1 Bank7 Block0x82C unsuccessfully.
Erase boot at CE1 Bank7 Block0x82D unsuccessfully.
Erase boot at CE1 Bank7 Block0x82E unsuccessfully.
Erase boot at CE1 Bank7 Block0x82F unsuccessfully.
Erase CE0 Bank6 Block0 error
Erase CE1 Bank4 Block0 error
Erase CE0 Bank4 Block0 error
Erase CE1 Bank2 Block0 error
Erase CE0 Bank6 Block0 error while writing info
Page generated in 0.82349 seconds with 7 queries
