Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NAND-PRO
Old 05-15-2018, 14:50   #1 (permalink)
Member: 1552657
Thanks Meter: 5
iphone 6 activation error
any solution change sn/ wifi mac
File Type: jpeg WhatsApp Image 2018-05-15 at 6.48.21 PM.jpeg (105.5 KB, 34 views)
Old 05-15-2018, 15:10   #2 (permalink)
Member: 1552657
Thanks Meter: 5
some one tell me change nand correct value i dont know which value plz guide may thankx
Old 05-19-2018, 02:52   #3 (permalink)
Member: 2547620
Thanks Meter: 3,431
Your question is not clear , what is your main purpose and what are you trying.
Tip :
You should use original values for the devices with the baseband
If you are trying to unlock i cloud It will not work because there is Baseband ID in calculating UDID related to IMEI but if you have replaced the NAND and looking for activating with device original IDs
- Check your device original WIFI , Bluetooth and SN number if you lost them request through some GSX services .
Best Regards
The Following User Says Thank You to FAT-ON For This Useful Post:
Old 05-21-2018, 14:36   #4 (permalink)
Member: 1552657
Thanks Meter: 5
thankx for urs reply
thankx for urs reply i got iphone 6 after reset "could not activate phone iphone" some one tell me change mac address
i remove nand write default boot
now getting error 4014
now write oraginal value from backup still getting error 4014
any help????
Old 05-21-2018, 14:42   #5 (permalink)
Member: 1552657
Thanks Meter: 5
from phone backup
read from phone ...after write same value still error no 4014
Old 05-28-2018, 09:19   #6 (permalink)
Member: 2547620
Thanks Meter: 3,431
#Select the boot
#modify the details with your original device
#Write Boot
#Done
Page generated in 0.17034 seconds with 10 queries
