iphone 6 error 4013 today flash iPhone 6 iTunes mark only flash error coming error 4013 remove nand ic. 1st Detect phone Build:May 15 2018 20:31:31 Device on COM9 is opened successfully Firmware Version:FFFF201803082152 SN:5FB9D2837836F5089B5136118829BECE CS0 ManuID:0x000004294A608298 DevID:0x00000805014E5050 CS1 ManuID:0x000004294A608298 DevID:0x00000805014E5050 NAND fw:052427P_TB_TLC2P Banks per CE:4 Blocks per Bank:2096 Pages per block:258 Pages per block SLC:86 Page Size:16448 Default bits per cell:3 Address bits bits per cell:2 Address bits:-1 4 12 9 Mark:THGBX4G9T4KLF0C_64G Chip Capacity:66.27GB 2nd config read information Save device details ( SN + WIFI + BT+model+AREA+SUB MODEL+BORD ) SN-C37P6QZ0G5MV model-MG4J2 AREA-ZD/A WIFI-28:5A:EB:5A:AB:7E BLUE TOOTH-28:5A:EB:5A:AB:7E SUB MODEL-A1586 BORD-C0745010GMVFQJYC 3rd format 4th write boot THGBX4G9T4KLF0C_64G with my All details ( SN + WIFI + BT+model+AREA+SUB MODEL+BORD ) all Done 5th flask again flash Done phone not activation Could Not activate iphone again remove nand 1st Detect phone 2nd Build:May 15 2018 20:31:31 Device on COM9 is opened successfully Firmware Version:FFFF201803082152 SN:5FB9D2837836F5089B5136118829BECE CS0 ManuID:0x000004294A608298 DevID:0x00000805014E5050 CS1 ManuID:0x000004294A608298 DevID:0x00000805014E5050 NAND fw:052427P_TB_TLC2P Banks per CE:4 Blocks per Bank:2096 Pages per block:258 Pages per block SLC:86 Page Size:16448 Default bits per cell:3 Address bits bits per cell:2 Address bits:-1 4 12 9 Mark:THGBX4G9T4KLF0C_64G Chip Capacity:66.27GB 2nd config read information Save device details ( SN + WIFI + BT+model+AREA+SUB MODEL+BORD ) SN-C37P6QZ0G5MV model-MG4J2 AREA-ZD/A WIFI-28:5A:EB:5A:AB:7E BLUE TOOTH-28:5A:EB:5A:AB:7E SUB MODEL-A1586 BORD-C0745010GMVFQJYC 3rd format 4th write boot THGBX4G9T4KLF0C_64G with my details ( SN + WIFI + BT ) only problem same error 5th flask again flash Done phone not activation Could Not activate iphone how solved my problem |
probably some configuration , lets do this together remotely . PM sent. Best Regards |
Bro its ur problem solved??? I want to know if problem solved or not.. So that we can learn also incase .. |
Hi team Is you solve this problem Better you uplod vidoe for new user and brtter understanding |
Wrong configuration . Just transfer original chip details to new chip 1- read the chip details ( old chip ) and save 2- put the new chip 3 - select device select the boot and fill the original info which you saved in step 1 4 - Write Boot 5 - when finish assemble and done ! |
