Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > FAT-ON Team Products > NAND-PRO
Old 05-23-2018, 20:37   #1 (permalink)
Member: 1418524
Thanks Meter: 170
iphone 6 error 4013
today flash iPhone 6 iTunes mark only
flash error coming error 4013
remove nand ic.
1st Detect phone
Build:May 15 2018 20:31:31
Device on COM9 is opened successfully
Firmware Version:FFFF201803082152
SN:5FB9D2837836F5089B5136118829BECE
CS0 ManuID:0x000004294A608298 DevID:0x00000805014E5050
CS1 ManuID:0x000004294A608298 DevID:0x00000805014E5050
NAND fw:052427P_TB_TLC2P
Banks per CE:4
Blocks per Bank:2096
Pages per block:258
Pages per block SLC:86
Page Size:16448
Default bits per cell:3
Address bits bits per cell:2
Address bits:-1 4 12 9
Mark:THGBX4G9T4KLF0C_64G
Chip Capacity:66.27GB
2nd
config
read information
Save device details ( SN + WIFI + BT+model+AREA+SUB MODEL+BORD )
SN-C37P6QZ0G5MV
model-MG4J2
AREA-ZD/A
WIFI-28:5A:EB:5A:AB:7E
BLUE TOOTH-28:5A:EB:5A:AB:7E
SUB MODEL-A1586
BORD-C0745010GMVFQJYC
3rd
format
4th
write boot
THGBX4G9T4KLF0C_64G with my All details ( SN + WIFI + BT+model+AREA+SUB MODEL+BORD )
all Done
5th
flask again
flash Done
phone not activation
Could Not activate iphone
again remove nand
1st Detect phone
2nd
Banks per CE:4
Pages per block:258
Page Size:16448
2nd
config
read information
SN-C37P6QZ0G5MV
model-MG4J2
AREA-ZD/A
SUB MODEL-A1586
3rd
format
4th
write boot
THGBX4G9T4KLF0C_64G with my details ( SN + WIFI + BT ) only problem same error
5th
flask again
flash Done
how solved my problem
Old 05-28-2018, 09:29   #2 (permalink)
Member: 2547620
Thanks Meter: 3,131
probably some configuration , lets do this together remotely .
PM sent.
Best Regards
Old 06-26-2018, 09:03   #3 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 374
Bro its ur problem solved???
I want to know if problem solved or not..
So that we can learn also incase ..
Old 06-26-2018, 18:49   #4 (permalink)
Qaisar Mahmood's Avatar
Member: 226457
Sonork: 100.1604561
Thanks Meter: 14,901
Hi team
Is you solve this problem
Better you uplod vidoe for new user and brtter understanding
Old 06-27-2018, 03:09   #5 (permalink)
Member: 2547620
Thanks Meter: 3,131
Wrong configuration .
Just transfer original chip details to new chip
1- read the chip details ( old chip ) and save
2- put the new chip
3 - select device select the boot
and fill the original info which you saved in step 1
4 - Write Boot
5 - when finish assemble and done !
The Following 2 Users Say Thank You to FAT-ON For This Useful Post:
Page generated in 0.28862 seconds with 7 queries
