Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products > NAND-PRO
Old 12-19-2017, 11:12   #1 (permalink)
Electroboys's Avatar
Member: 6594
Sonork: 100.27285
Thanks Meter: 22,433
Arrow NAND Pro Introduction
What is NAND-PRO
NAND Pro is a high speed programmer for repairing / programming / reading / upgrading iPhone and iPad NAND / ICs Chips.
Advanced hardware repair with NAND Pro requires you to be proficient in NAND IC removal (chip-off) from the Device logic board ,
once removed you can read / write / repair the NAND IC using NAND Pro hardware and software with the supports of 32 bits and 64 bits NAND ICs
Software and Hardware Protocols :
NAND Pro supports all known protocols even the unique protocols such as PPN (Perfect Page New) and NAND protocols
especially for the LGA52/LGA60 Packages using 8-bits with the average transfer rate is 8-12MB/s depending on NAND Chip
iOS Functions :
NAND Pro User interface supports changing NAND and Device information
[+] UPGRADE MEMORY
moving old disk information to new disk using your device details
  • Serial Number
  • Wi-Fi MAC ID
  • Bluetooth MAC ID
  • Region ID
  • Model ID
  • Sub-Model ID
[+] DISK ERRORS
Old and Used NAND Disk Surface might get corrupted and might need a special software touch
  • Repair Disk Errors
  • NAND Flash Error
  • iTunes Error 9
  • iTunes Error 14
  • iTunes Error 20
  • All iTunes Errors NAND Problems
[+] Accessing DATA
You can access all the disk's mounted on the NAND Disk and access all the BANKS separately or as whole
  • Reading ( Full Image)
  • Writing ( Full Image )
[+] Smart Boot Detect
Smart Boot Detection algorithm will let you write / extract boot information from the NANDs easily
Cutting-edge techniques implemented in to smart boot detection algorithm thus will make write boot information into any known/unknown chips to make it without further development request.
  • Read Boot
  • Extract Boot
  • Write Boot
We send to our customers as a complete package Software , Hardware and Socket as complete solution for iPhone and iPad Repair
Nand Pro - Ultimate NAND Flasher | Chip Level Mods
The Following 14 Users Say Thank You to Electroboys For This Useful Post:
Old 12-19-2017, 12:15   #2 (permalink)
Momin_Telecom's Avatar
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,689
most welcome but care your old user also
First ORT
Second EMMC pro
The Following 8 Users Say Thank You to Momin_Telecom For This Useful Post:
Old 12-19-2017, 12:34   #3 (permalink)
nagcharan's Avatar
Member: 2708592
Thanks Meter: 325
It can removed icloud latest x and more .....i mean support can removed icloud?
Old 12-19-2017, 12:44   #4 (permalink)
NAVAKO's Avatar
Member: 1206897
Sonork: Aleandros
Thanks Meter: 30
Not exist tool to remove directly icloud bro, on iphone not possible if not change components on board, on ipad u can but need change emmc data....ios 11 complicated situation for ipad too 🤣
The Following User Says Thank You to NAVAKO For This Useful Post:
Old 12-19-2017, 13:21   #5 (permalink)
UMeR3's Avatar
Member: 2451476
Sonork: 100.1669164
Thanks Meter: 299
pakistan seller ????? ios 11 supported or not error 9 4013 ..-1 fix or not.
ipad icloud remover or not
Old 12-19-2017, 14:06   #6 (permalink)
naushad09's Avatar
Member: 216094
Thanks Meter: 315
if this product support iphone 6s/7/7+ NAND then good otherwise ip box have alredy same.
The Following User Says Thank You to naushad09 For This Useful Post:
Old 12-19-2017, 14:44   #7 (permalink)
Member: 6594
Sonork: 100.27285
First ORT
Second EMMC pro
We have been working for very long time and other projects progress were slow but it is time we will speed all of them together !
iCloud is supported on the iPad's but not on iPhones - we will make detailed manual .
We have Latest iOS11 Boot for all supported models !
iTunes Problems Errors releated to NAND all can be fixed .
Disk Errors and Problems can be fixed too ..
Best Regards
Oz
The Following 4 Users Say Thank You to Electroboys For This Useful Post:
Old 12-19-2017, 15:05   #8 (permalink)
amar181's Avatar
Member: 510122
Sonork: 100.1606547
Thanks Meter: 1,793
What About ORT and Emmc Pro these are dead product ... ? we not trust your product its not going long time... it is short-term product ..
The Following 5 Users Say Thank You to amar181 For This Useful Post:
Old 12-19-2017, 15:21   #9 (permalink)
Member: 6594
Sonork: 100.27285
Hi Amar ,
best answer will be the action for this kind of question .
keep watching emmc pro section for following weeks
And @ALL keep the thread related to nand-pro and its functions .
Best Regards
Oz.
Old 12-19-2017, 15:25   #10 (permalink)
UMeR3's Avatar
Member: 2451476
Sonork: 100.1669164
Thanks Meter: 299
Originally Posted by Electroboys View Post
Hi Amar ,
Best Regards
Oz.
pakistani resaller no. ......................
Old 12-19-2017, 15:30   #11 (permalink)
Member: 353737
Sonork: 100.1580139
Thanks Meter: 43
This tool will support 6s ,6s plus ,7,7 plus in the future?
Old 12-19-2017, 15:40   #12 (permalink)
dam1inc's Avatar
Member: 1866487
Thanks Meter: 109
WHAT ABOUT IOS11 UDID ACTIVATION AFTER CHANGE SERIAL NUMBER ON IPADS??
Sent from my SM-G955U using Tapatalk
Old 12-19-2017, 15:40   #13 (permalink)
Member: 1961231
Thanks Meter: 36
can read only user pass if icloud on?
Old 12-19-2017, 16:17   #14 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,216
My friend What's The Benefits Means There Are Other Project For Same Work Too In Market N Most IMP Listed Models Soon Outdated ... I Need Info About New Models Will Be Added Or Not ... Future Plans ...?
Old 12-19-2017, 22:26   #15 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 629
What is NAND-PRO
iOS Functions :
[+] UPGRADE MEMORY
  • Serial Number
  • Wi-Fi MAC ID
  • Bluetooth MAC ID
  • Region ID
  • Model ID
  • Sub-Model ID
[+] DISK ERRORS
  • NAND Flash Error
  • iTunes Error 9
  • iTunes Error 14
  • iTunes Error 20
[+] Accessing DATA
  • Read Boot
  • Extract Boot
  • Write Boot
what is price for this ?
The Following User Says Thank You to ansari123 For This Useful Post:
Page generated in 0.41224 seconds with 7 queries
