06-03-2018, 12:14 | #1 (permalink) |
Freak Poster Join Date: Aug 2012 Location: Phillippines
Member: 1798740 Status: Offline Sonork: 1621776 Thanks Meter: 12 | SOV32 to E6653 help..... i have to debrand this phone to E6653 search from google i found 2 ftf file E6653_32.4.A.1.54_R2E_Central Europe 5 Generic_1298-7654.ftf E6653_32.3.A.0.376_Customized_DE_1298-3675_R5D.ftf but error to flash |
06-05-2018, 05:50 | #2 (permalink) |
Member: 1798740 Status: Offline Sonork: 1621776 Thanks Meter: 12 | sorry i forgot patch file for 64bit from here https://www.youtube.com/watch?v=bMkOAGkjPc4 05/010/2018 12:10:49 - INFO - <- This level is successfully initialized 05/010/2018 12:10:50 - INFO - Flashtool run from eclipse 05/010/2018 12:10:51 - INFO - Executing search strategies to find proxy selector 05/010/2018 12:10:51 - INFO - No proxy found for IE. Trying next one 05/010/2018 12:10:51 - INFO - Strategy firefox failed trying next one : No Firefox installation found 05/010/2018 12:10:51 - INFO - No proxy found for java. Trying next one 05/010/2018 12:10:51 - INFO - Syncing devices from github 05/010/2018 12:10:51 - INFO - Opening devices repository. 05/010/2018 12:10:52 - INFO - Scanning devices folder for changes. 05/011/2018 12:11:03 - INFO - Pulling changes from github. 05/011/2018 12:11:18 - INFO - Quietly closing devices repository. 05/011/2018 12:11:18 - INFO - Quietly closing devices repository. 05/011/2018 12:11:18 - WARN - close() called when useCnt is already zero for Repository[C:\Users\admin\Desktop\Xperia Z5\devices\.git] 05/011/2018 12:11:18 - INFO - Devices sync finished. 05/011/2018 12:11:18 - INFO - Loading devices database 05/011/2018 12:11:19 - INFO - Loaded 106 devices 05/011/2018 12:11:19 - INFO - Starting phone detection 05/011/2018 12:11:23 - INFO - Device connected with USB debugging on 05/011/2018 12:11:23 - ERROR - Cannot identify your device. 05/011/2018 12:11:23 - INFO - Selecting from user input 05/011/2018 12:11:26 - ERROR - You can only flash devices. 05/011/2018 12:11:26 - INFO - Device disconnected 05/011/2018 12:11:56 - INFO - Selected Bundle for Sony Xperia Z5(E6653). FW release : 32.3.A.0.376. Customization : Customized DE 05/011/2018 12:11:56 - INFO - Preparing files for flashing 05/014/2018 12:14:31 - INFO - Please connect your device into flashmode. 05/014/2018 12:14:49 - INFO - Device connected in flash mode 05/014/2018 12:14:50 - INFO - Opening device for R/W 05/014/2018 12:14:50 - INFO - Reading device information 05/014/2018 12:14:50 - INFO - Phone ready for flashmode operations. 05/014/2018 12:14:50 - INFO - Opening TA partition 2 05/014/2018 12:14:51 - INFO - Current device : SOV32 - BH903VTX4M - 1297-7258_R17B - 1295-6743_32.0.D.0.291 - GENERIC_32.0.D.0.291 05/014/2018 12:14:51 - INFO - Closing TA partition 05/014/2018 12:14:51 - INFO - Start Flashing 05/014/2018 12:14:51 - INFO - Processing loader.sin 05/014/2018 12:14:51 - INFO - Checking header 05/014/2018 12:14:51 - INFO - Flashing data 05/014/2018 12:14:51 - INFO - Loader : S1_Root_f936 - Version : MSM8994_50 / Boot version : S1_Boot_MSM8994_LA1.2_119 / Bootloader status : NOT_ROOTABLE 05/014/2018 12:14:51 - INFO - Max packet size set to 4M 05/014/2018 12:14:51 - INFO - USB buffer size set to 512K 05/015/2018 12:15:05 - INFO - No flash script found. Using 0.9.18 flash engine 05/015/2018 12:15:05 - INFO - Opening TA partition 2 05/015/2018 12:15:05 - INFO - Writing TA unit 00002774. Value : 01 05/015/2018 12:15:05 - INFO - Closing TA partition 05/015/2018 12:15:05 - INFO - Opening TA partition 2 05/015/2018 12:15:12 - INFO - Closing TA partition 05/015/2018 12:15:12 - INFO - Opening TA partition 2 05/015/2018 12:15:12 - INFO - Processing amss_fsg.sin 05/015/2018 12:15:12 - INFO - Checking header 05/015/2018 12:15:12 - INFO - Flashing data 05/015/2018 12:15:12 - INFO - Processing amss_fs_1.sin 05/015/2018 12:15:12 - INFO - Checking header 05/015/2018 12:15:12 - INFO - Flashing data 05/015/2018 12:15:12 - INFO - Processing amss_fs_2.sin 05/015/2018 12:15:12 - INFO - Checking header 05/015/2018 12:15:12 - INFO - Flashing data 05/015/2018 12:15:12 - INFO - Processing apps_log.sin 05/015/2018 12:15:12 - INFO - Checking header 05/015/2018 12:15:12 - INFO - Flashing data 05/015/2018 12:15:12 - INFO - Processing cache.sin 05/015/2018 12:15:12 - INFO - Checking header 05/015/2018 12:15:13 - INFO - Flashing data 05/015/2018 12:15:13 - INFO - Processing fotakernel.sin 05/015/2018 12:15:13 - INFO - Checking header 05/015/2018 12:15:13 - INFO - Flashing data 05/015/2018 12:15:18 - INFO - Processing kernel.sin 05/015/2018 12:15:18 - INFO - Checking header 05/015/2018 12:15:19 - INFO - Flashing data 05/015/2018 12:15:23 - INFO - Processing modem.sin 05/015/2018 12:15:23 - INFO - Checking header 05/015/2018 12:15:23 - INFO - Flashing data 05/015/2018 12:15:32 - INFO - Processing ramdump.sin 05/015/2018 12:15:32 - INFO - Checking header 05/015/2018 12:15:32 - INFO - Flashing data 05/015/2018 12:15:34 - INFO - Closing TA partition 05/015/2018 12:15:34 - INFO - Opening TA partition 2 05/015/2018 12:15:34 - INFO - Processing oem.sin 05/015/2018 12:15:34 - INFO - Checking header 05/015/2018 12:15:34 - INFO - Flashing data 05/015/2018 12:15:55 - INFO - Processing system.sin 05/015/2018 12:15:55 - INFO - Checking header 05/015/2018 12:15:55 - INFO - Flashing data 05/026/2018 12:26:26 - INFO - Processing userdata.sin 05/026/2018 12:26:26 - INFO - Checking header 05/026/2018 12:26:26 - INFO - Flashing data 05/026/2018 12:26:58 - INFO - Closing TA partition 05/026/2018 12:26:58 - INFO - Opening TA partition 2 05/026/2018 12:26:58 - INFO - Closing TA partition 05/026/2018 12:26:58 - INFO - Opening TA partition 2 05/026/2018 12:26:59 - INFO - Processing elabel.sin 05/026/2018 12:26:59 - INFO - Checking header 05/026/2018 12:26:59 - INFO - Flashing data 05/027/2018 12:27:02 - INFO - Closing TA partition 05/027/2018 12:27:02 - INFO - Opening TA partition 2 05/027/2018 12:27:02 - INFO - Writing TA unit 00002725. Value : 32 30 31 38 2D 30 36 2D 30 35 20 31 32 3A 32 37 3A 30 32 00 05/027/2018 12:27:02 - INFO - Writing TA unit 00002774. Value : 00 05/027/2018 12:27:02 - INFO - Closing TA partition 05/027/2018 12:27:02 - INFO - Ending flash session 05/027/2018 12:27:02 - INFO - Flashing finished. 05/027/2018 12:27:02 - INFO - Please unplug and start your phone 05/027/2018 12:27:02 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings 05/027/2018 12:27:03 - INFO - Device connected in flash mode 05/027/2018 12:27:37 - INFO - Device disconnected now its done |
The Following 2 Users Say Thank You to oxygen10 For This Useful Post: |
