Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > XpertsGsm (The Wholesale Unlocking Database)
Old 05-02-2018, 11:13   #1 (permalink)
Member: 1766790
Thanks Meter: 257
[ SERIAL + WIFI + BT ] For UNLOCK ICLOUD (( ALL MODELS SUPPORTED )) (VERIFY 24h)
[ SERIAL + WIFI + BT ] FOR IPAD NAND REPAIR (( ALL MODELS SUPPORTED )) (VERIFY 24h)
This not unlock service.
We will give you new serial with BT and WiFi adress to unlock your ipad by hardware.
i will send the info instant when im online
((VERIFY TIME IS 1-24h ONLY !!!)
____________________________
NOTE : try to put your icloud id as fast as you write the serial on your ipad
IF owner of the device make it ON then if you restore your device
it will be relocked to icloud and you have to buy new serial
and we are not responsible for this
DISCLAIMER : AFTER RESET IPAD IT MAY RELOCK
WE ARE NOT RESPONSIBLE FOR THIS
BETTER YOU PUT ICLOUD ID DIRECTLY ONCE YOU GET THE SN AND WRITE IT ON YOUR DEVICE .. THIS MAY PROTECT RELOCK ISSUE AFTER RESTORE
now service back with all models supported
we are main provider in market
send your Serials now
XpertsGsm Server
The Following 2 Users Say Thank You to Xpertsgsm.Unlocks For This Useful Post:
Old 05-28-2018, 14:50   #2 (permalink)
Member: 1766790
Thanks Meter: 257
We updated the verification policy
now you can verify activation error within 1-7 days
and FMI ON within 24 hours
thanks and good day
Old 10-22-2018, 15:38   #3 (permalink)
Member: 2199321
hi suport ipad pro a9x ?
hi is iPad pro supported ?
Old 10-22-2018, 21:43   #4 (permalink)
Member: 2210075
Sonork: 1000.2
i have ipad pro 12'' with 4g sim is that ipad supported ? or only wifi model ?
Old 10-26-2018, 15:31   #5 (permalink)
Member: 1766790
Thanks Meter: 257
1.If your device is a cellular version ( 4g - lte ) , You need to cut off the gsm baseband to make it be the wifi only .
2. Dismantle the IC Nand Flash and using box edit write new Full set serial by ( Navi pro -IPbox .WL...ect)
3.Restore your divice , activate it with itunes
4. Enjoy your iDevice
Old 10-21-2019, 21:08   #6 (permalink)
Member: 2627417
cuando dices que si restablece se bloquea de nuevo quiere decir que es como un bypass??
Old 10-23-2019, 17:45   #7 (permalink)
Member: 1766790
Thanks Meter: 257
we said this :
Page generated in 0.22733 seconds with 7 queries
