04-22-2018, 21:53 | #1 (permalink) |
No Life Poster Join Date: Jun 2012 Location: WolrdWide HK SAR
Member: 1766790 Status: Offline Thanks Meter: 268 | Usa metro pcs application (app unlocked devices ) / htc / samsung / alcatel / etc Submit Only If Imei Clean On Metropcs No Refund For Imeis In Blacklist With Error Not Eligible For Unlock No Refund For Imeis Of T-mobile No Refund For Imeis Already Unlocked Once Unlocked, You Must Connect The Phone To A Stable Wireless Network, Open The App And Touch Device Unlock Unlock Permanent. When The Device Is Restarted Will Be Unlocked. Verification Process: If You Have Problems Unlocking The Phone After Delivery: Press Verify Button Or Open Support Ticket To Verify Your Order Without Sending Any Video As Start . After That We Will Verify Yorur Order With Supplier Who Will Redo The Order And Will Send Code To Verify Your Order . This Code Will Need To Put On Paper And Record Video Showing The Code On Paper And The Unlocking Process If Still Fail . Once You Do So Your Order Will Be Refunded Within 24 H . Note Verification Time Is Only 7 Days. After 7 Days No Verification Will Be Accepted For Verification : press verify button or Email us or open support ticket to verify your order after that we will redo and give you special code from supplier to put on paper and record a video the video must be recorded showing code and steps as follow : https://youtu . be/hukZOwuF9k4 once we receive your video we will refund your order www.xpertsGsm.com Last edited by Xpertsgsm.Unlocks; 06-25-2018 at 07:01. |
The Following User Says Thank You to Xpertsgsm.Unlocks For This Useful Post: |
