01-12-2020, 09:16 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | bnd-l21 flashing problam [Answered] Welcome to Octoplus Huawei Software v.1.1.3 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM8 USB Serial Port 2: COM3 HDA CX11270 Soft Modem Selected file: C:/Users/alimobile/Desktop/UPDATE.APP Warning: This is OTA type file and can't be written via software. Writing this firmware may damage the phone. Please use file from our support area. PACKAGE_TYPE: ONLINE_UPDATE VERLIST : BND_GLOBAL_CUST 9.1.0(C900) 2020-01-12 08:12:42 GMT ------------------------------------------------- Starting Read Info (Fastboot Mode) Searching Fastboot devices... Warning: Reading serial number failed Device Model: BND-L21 Build Number: BND-L21 9.1.0.140(C185E2R1P2) Read Info (Fastboot Mode) done. Performed by 1.1.3 Software version. Selected phone model: BND-L21 2020-01-12 08:13:35 GMT ------------------------------------------------- Starting Write Firmware Extracting firmware partitions... Partition has been extract successfully Checking firmware package type Selected firmware is not compatible with your device revision Connecting to phone.. Phone connect successfully Writing SHA256RSA partition.. SHA256RSA partition has been written successfully Writing CRC partition.. CRC partition has been written successfully Writing CURVER partition.. CURVER partition has been written successfully Writing VERLIST partition.. VERLIST partition has been written successfully Writing PACKAGE_TYPE partition.. Error: Failed write PACKAGE_TYPE partition Write Firmware failed. Performed by 1.1.3 Software version. |
01-12-2020, 09:25 | #2 (permalink) |
No Life Poster Join Date: Jun 2011 Location: earth
Member: 1591394 Status: Offline Thanks Meter: 552 | u need use full update not ota one, if it will no help u can try by board software https://drive.google.com/file/d/108u...z35dv_UP9/view by test point of coz |
The Following User Says Thank You to kikas112 For This Useful Post: |
