06-22-2019, 19:52 | #1 (permalink) |
Banned Join Date: Apr 2014 Location: FUTURE
Member: 2171001 Status: Offline Thanks Meter: 196 | dra-lx1 repair imei failed [Answered] i was wondering if u test repair imei solution for dra-lx2 dra-lx5 it always give error i tested many verions i wish you can fix this issue in future Last edited by sam_alshahba; 06-22-2019 at 19:58. |
06-24-2019, 08:30 | #3 (permalink) | |
Member: 2171001 Status: Offline Thanks Meter: 196 | Quote:
????-??-?? ??:??:??.??? Loading application settings ????-??-?? ??:??:??.??? Refreshing serial ports list ????-??-?? ??:??:??.??? Found COM ports: ????-??-?? ??:??:??.??? 1: COM7 USB Serial Port ????-??-?? ??:??:??.??? Welcome to Octoplus Huawei Software v.1.1.0 ????-??-?? ??:??:??.??? ????-??-?? ??:??:??.??? To enable 'Manufacture' mode dial ????-??-?? ??:??:??.??? - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ????-??-?? ??:??:??.??? ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode ????-??-?? ??:??:??.??? - for MTK based models: *#*#14789632#*#* ????-??-?? ??:??:??.??? ProjectMenu > Background Settings > USB Port Settings > Debug Mode ????-??-?? ??:??:??.??? ????-??-?? ??:??:??.??? To enable 'Fastboot' mode ????-??-?? ??:??:??.??? 1. Power off the phone. Remove SD and SIM cards ????-??-?? ??:??:??.??? 2. Press 'Vol-' and insert USB cable ????-??-?? ??:??:??.??? 3. Wait until phone enters 'Fastboot' mode ????-??-?? ??:??:??.??? ????-??-?? ??:??:??.??? To enable 'Upgrade' mode ????-??-?? ??:??:??.??? 1. Power off the phone. Remove SD and SIM cards ????-??-?? ??:??:??.??? 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable ????-??-?? ??:??:??.??? 3. Wait until phone enters 'Upgrade mode' ????-??-?? ??:??:??.??? Init finished ????-??-?? ??:??:??.??? Refreshing serial ports list ????-??-?? ??:??:??.??? Found COM ports: ????-??-?? ??:??:??.??? 1: COM7 USB Serial Port ????-??-?? ??:??:??.??? ????-??-?? ??:??:?? GMT ------------------------------------------------- ????-??-?? ??:??:??.??? Starting Connect ????-??-?? ??:??:??.??? Selected phone model: DRA-LX2 ????-??-?? ??:??:??.??? Please Power off the phone, Press 'Vol-' and insert USB cable ????-??-?? ??:??:??.??? Detecting Chip Version... ????-??-?? ??:??:??.??? HW Chip : MT6739 ????-??-?? ??:??:??.??? HW Version : 8A00.CB00.0002.0000 ????-??-?? ??:??:??.??? Brom Version: 5 ????-??-?? ??:??:??.??? Boot Loader Version: FE ????-??-?? ??:??:??.??? Sending Authentication Data ????-??-?? ??:??:??.??? Waiting after authentication data failed ????-??-?? ??:??:??.??? Sending Authentication Error ????-??-?? ??:??:??.??? Authentication Error ????-??-?? ??:??:??.??? ????-??-?? ??:??:??.??? Connect failed. ????-??-?? ??:??:??.??? Performed by 1.1.0 Software version. | |
06-24-2019, 10:50 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | That's may cause the problem, please try to reflash your device with stock firmware, then repeat Repair IMEI operation. |
