06-25-2019, 14:39 | #1 (permalink) |
Freak Poster Join Date: May 2015 Location: Pakistan
Member: 2401943 Status: Offline Thanks Meter: 182 | Error: Writing SYSTEM partition failed [Answered] To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2: COM10 USB Serial Port 3: COM7 Intel(R) Active Management Technology - SOL 2019-06-25 13:33:24 GMT ------------------------------------------------- Starting Read Info (Fastboot Mode) Searching connected Fastboot devices... S/N: 8BG7S15A21010643 Build Number: SCL-U31C185B161 Read Info (Fastboot Mode) done. Performed by 1.1.0 Software version. 2019-06-25 13:35:20 GMT ------------------------------------------------- Starting Write Firmware Searching connected Fastboot devices... System: SCL-U31C185B161 S/N: 8BG7S15A21010643 Selected firmware: G:/Huawei+/SCL-U31/Huawei_Y6_SCL-U31_(SCL-U31C185B161/dload/UPDATE.APP Extracting firmware partitions... partition has been extracted successfully Checking firmware compatibility Connecting to server... Writing RPM partition.. RPM partition has been written successfully Writing TZ partition.. TZ partition has been written successfully Writing SBL1 partition.. SBL1 partition has been written successfully Writing MODEM partition.. MODEM partition has been written successfully Writing FSG partition.. FSG partition has been written successfully Writing RECOVERY partition.. RECOVERY partition has been written successfully Writing ERECOVERY partition.. ERECOVERY partition has been written successfully Writing SYSTEM partition.. Error: Writing SYSTEM partition failed Write Firmware failed. Performed by 1.1.0 Software version. |
