Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus Huawei Tool
Old 01-04-2019, 15:18   #1 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,104
Thumbs up first test to unbrick (boot repaire) RNE-L21 with Board firmware with test version
first scoop to repaire boot with Octoplus Huawei Software v.1.0.5.1 done
2019-01-04 13:30:54.211	Loading application settings
2019-01-04 13:30:54.227	Refreshing serial ports list
2019-01-04 13:30:54.570	Found COM ports:
2019-01-04 13:30:54.570	1: COM1 Port de communication
2019-01-04 13:30:54.570	2: COM3 USB Serial Port
2019-01-04 13:30:54.570	3: COM4 USB Serial Port
2019-01-04 13:30:54.601	Welcome to Octoplus Huawei Software v.1.0.5.1
2019-01-04 13:30:54.601	To enable 'Manufacture' mode dial
2019-01-04 13:30:54.601	- for Qualcomm and Hisilicon based models: *#*#2846579#*#*
2019-01-04 13:30:54.601	ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode
2019-01-04 13:30:54.601	To enable 'Fastboot' mode
2019-01-04 13:30:54.601	1. Power off the phone. Remove SD and SIM cards
2019-01-04 13:30:54.601	2. Press 'Vol-' and insert USB cable
2019-01-04 13:30:54.601	3. Wait until phone enters 'Fastboot' mode
2019-01-04 13:30:54.601	To enable 'Upgrade' mode
2019-01-04 13:30:54.601	2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable
2019-01-04 13:30:54.601	3. Wait until phone enters 'Upgrade mode'
2019-01-04 13:30:54.679	Init finished
2019-01-04 13:31:22.786	Selected file: G:/HUAWEI/RNE-L21/Software/factory_verison
2019-01-04 13:31:53.328	2019-01-04 13:31:53 GMT -------------------------------------------------
2019-01-04 13:31:53.328	Starting Write Firmware
2019-01-04 13:31:53.359	Searching connected Fastboot devices...
2019-01-04 13:32:08.445	Fastboot devices not found
2019-01-04 13:32:08.445	Write Firmware failed.
2019-01-04 13:32:08.461	Performed by 1.0.5.1 Software version.
2019-01-04 13:32:37.572	2019-01-04 13:32:37 GMT -------------------------------------------------
2019-01-04 13:32:37.572	Starting Write Firmware
2019-01-04 13:32:37.635	Connecting to phone..
2019-01-04 13:32:37.654	Phone connect successfully
2019-01-04 13:32:37.657	Phone connect successfully
2019-01-04 13:32:37.659	Writing board firmware files...
2019-01-04 13:32:37.660	Writing XLOADER partition..
2019-01-04 13:32:40.915	XLOADER partition has been written successfully
2019-01-04 13:32:40.915	Writing FASTBOOT partition..
2019-01-04 13:32:52.590	FASTBOOT partition has been written successfully
2019-01-04 13:32:52.591
2019-01-04 13:32:52.593	Write Firmware done.
2019-01-04 13:32:52.595	Performed by 1.0.5.1 Software version.
The Following 10 Users Say Thank You to rebainoor For This Useful Post:
Old 01-04-2019, 19:15   #2 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 429
Where is ver. 1.0.5.1??
Old 01-04-2019, 20:16   #3 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,104
in test mode and if you need test it with bicked huawei phone its for your awn risk
The Following 2 Users Say Thank You to rebainoor For This Useful Post:
Old 01-07-2019, 17:34   #4 (permalink)
Member: 478535
Thanks Meter: 433
rebainoor, acording to log all went well, is that what you experienced? Phone fully working after this test?
Thanks for the test rebainoor and a big thanks to octoplus team for the effort in completing the tool to get more functionalities!
The Following 2 Users Say Thank You to Desirat For This Useful Post:
Old 01-07-2019, 17:37   #5 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,104
its work normaly after unbrick it you need flash it in upgrade mode and fully change region/vendor
2019-01-04 19:12:52.174	2019-01-04 19:12:52 GMT -------------------------------------------------
2019-01-04 19:12:52.174	Starting Auto detect
2019-01-04 19:12:52.217	Running detect for HiSilicon
2019-01-04 19:12:52.334	Detect HiSilicon platform ok
2019-01-04 19:12:52.334	Detected HiSilicon Android Device at COM78
2019-01-04 19:12:52.342	Read pre auth info for HiSilicon
2019-01-04 19:12:52.454	Can't get device model.
2019-01-04 19:12:52.613	Removing security protection...
2019-01-04 19:12:54.732	Auth 1 HiSilicon fail
2019-01-04 19:12:54.852	Connecting to server...
2019-01-04 19:12:55.834	Check auth 3
2019-01-04 19:12:56.896	Authorization is successful
2019-01-04 19:12:56.901	Reading basic data...
2019-01-04 19:12:57.202	Can't read Vendor/Country code.
2019-01-04 19:12:57.329	Can't get device model.
2019-01-04 19:12:57.449	Reading secure data...
2019-01-04 19:13:05.087	Device Model: Huawei HiSilicon Device
2019-01-04 19:13:05.092	Firmware: System-FAC 5.1.0.88(008G)
2019-01-04 19:13:05.098	Boot: Chipset-Chipset-dallas-FAC 5.1.0.1(01YP)_BOOT
2019-01-04 19:13:05.105	Fastboot: Chipset-Chipset-dallas-FAC 5.1.0.1(01YP)_FASTBOOT
2019-01-04 19:13:05.111	System: System-FAC 5.1.0.88(008G)
2019-01-04 19:13:05.117	Recovery: (unknow)
2019-01-04 19:13:05.123	MEID: 00000000000000
2019-01-04 19:13:05.126	PESN: 00000000
2019-01-04 19:13:05.129	IMEI A: 8679730xxxxxxxx
2019-01-04 19:13:05.133	IMEI B: 8679730xxxxxxxx
2019-01-04 19:13:05.137	Bluetooth MAC: B0:E1:7E:xx:xx:xx
2019-01-04 19:13:05.140	WiFi MAC: B0:E1:7E:xx:xx:xx
2019-01-04 19:13:05.144	S/N: FFY5T17B2xxxxxxxxxx
2019-01-04 19:13:05.148	Board S/N: 5T4QGL1xxxxxxxxx
2019-01-04 19:13:05.151
2019-01-04 19:13:05.154	Auto detect done.
2019-01-04 19:13:05.156	Performed by 1.0.5.1 Software version.
2019-01-04 19:14:43.403	2019-01-04 19:14:43 GMT -------------------------------------------------
2019-01-04 19:14:43.412	Starting Write Firmware
2019-01-04 19:14:43.436	Selected firmware:G:/HUAWEI/RNE-L21/dload/UPDATE.APP
2019-01-04 19:14:43.438	Extracting firmware partitions...
2019-01-04 19:14:49.157	partition has been extract successfully
2019-01-04 19:14:49.167	Connecting to phone..
2019-01-04 19:15:04.185	Phone connect successfully
2019-01-04 19:15:04.194	Writing firmware..
2019-01-04 19:15:09.186	Writing SHA256RSA partition..
2019-01-04 19:15:10.279	SHA256RSA partition has been written successfully
2019-01-04 19:15:10.279	Writing CRC partition..
2019-01-04 19:15:11.355	CRC partition has been written successfully
2019-01-04 19:15:11.365	Writing CURVER partition..
2019-01-04 19:15:12.382	CURVER partition has been written successfully
2019-01-04 19:15:12.382	Writing VERLIST partition..
2019-01-04 19:15:13.395	VERLIST partition has been written successfully
2019-01-04 19:15:13.398	Writing PACKAGE_TYPE partition..
2019-01-04 19:15:14.410	PACKAGE_TYPE partition has been written successfully
2019-01-04 19:15:14.410	Writing EFI partition..
2019-01-04 19:15:15.484	EFI partition has been written successfully
2019-01-04 19:15:15.484	Writing XLOADER partition..
2019-01-04 19:15:16.546	XLOADER partition has been written successfully
2019-01-04 19:15:16.546	Writing FW_LPM3 partition..
2019-01-04 19:15:17.832	FW_LPM3 partition has been written successfully
2019-01-04 19:15:17.844	Writing FASTBOOT partition..
2019-01-04 19:15:19.323	FASTBOOT partition has been written successfully
2019-01-04 19:15:19.323	Writing MODEMNVM_UPDATE partition..
2019-01-04 19:15:22.205	MODEMNVM_UPDATE partition has been written successfully
2019-01-04 19:15:22.205	Writing TEEOS partition..
2019-01-04 19:15:23.625	TEEOS partition has been written successfully
2019-01-04 19:15:23.625	Writing TRUSTFIRMWARE partition..
2019-01-04 19:15:24.668	TRUSTFIRMWARE partition has been written successfully
2019-01-04 19:15:24.681	Writing SENSORHUB partition..
2019-01-04 19:15:25.851	SENSORHUB partition has been written successfully
2019-01-04 19:15:25.851	Writing FW_HIFI partition..
2019-01-04 19:15:27.857	FW_HIFI partition has been written successfully
2019-01-04 19:15:27.857	Writing KERNEL partition..
2019-01-04 19:15:32.967	KERNEL partition has been written successfully
2019-01-04 19:15:32.970	Writing RAMDISK partition..
2019-01-04 19:15:36.789	RAMDISK partition has been written successfully
2019-01-04 19:15:36.795	Writing RECOVERY_RAMDISK partition..
2019-01-04 19:15:43.405	RECOVERY_RAMDISK partition has been written successfully
2019-01-04 19:15:43.412	Writing RECOVERY_VENDOR partition..
2019-01-04 19:15:47.277	RECOVERY_VENDOR partition has been written successfully
2019-01-04 19:15:47.277	Writing ERECOVERY_KERNEL partition..
2019-01-04 19:15:52.471	ERECOVERY_KERNEL partition has been written successfully
2019-01-04 19:15:52.471	Writing ERECOVERY_RAMDISK partition..
2019-01-04 19:15:58.986	ERECOVERY_RAMDISK partition has been written successfully
2019-01-04 19:15:59.002	Writing ERECOVERY_VENDOR partition..
2019-01-04 19:16:02.753	ERECOVERY_VENDOR partition has been written successfully
2019-01-04 19:16:02.763	Writing RECOVERY_VBMETA partition..
2019-01-04 19:16:03.771	RECOVERY_VBMETA partition has been written successfully
2019-01-04 19:16:03.787	Writing ERECOVERY_VBMETA partition..
2019-01-04 19:16:04.788	ERECOVERY_VBMETA partition has been written successfully
2019-01-04 19:16:04.799	Writing DTS partition..
2019-01-04 19:16:09.864	DTS partition has been written successfully
2019-01-04 19:16:09.881	Writing MODEM_FW partition..
2019-01-04 19:16:26.863	MODEM_FW partition has been written successfully
2019-01-04 19:16:26.881	Writing VBMETA partition..
2019-01-04 19:16:27.893	VBMETA partition has been written successfully
2019-01-04 19:16:27.908	Writing ODM partition..
2019-01-04 19:16:46.151	ODM partition has been written successfully
2019-01-04 19:16:46.167	Writing CACHE partition..
2019-01-04 19:16:49.223	CACHE partition has been written successfully
2019-01-04 19:16:49.242	Writing SYSTEM partition..
2019-01-04 19:25:07.379	SYSTEM partition has been written successfully
2019-01-04 19:25:07.395	Writing CUST partition..
2019-01-04 19:25:11.429	CUST partition has been written successfully
2019-01-04 19:25:11.444	Writing VENDOR partition..
2019-01-04 19:26:46.666	VENDOR partition has been written successfully
2019-01-04 19:26:46.681	Writing VERSION partition..
2019-01-04 19:26:48.493	VERSION partition has been written successfully
2019-01-04 19:26:48.508	Writing PRODUCT partition..
2019-01-04 19:27:12.639	PRODUCT partition has been written successfully
2019-01-04 19:27:12.655	Writing USERDATA partition..
2019-01-04 19:27:22.442	USERDATA partition has been written successfully
2019-01-04 19:27:22.458	Firmware writing successfully completed
2019-01-04 19:27:22.474
2019-01-04 19:27:22.474	Write Firmware done.
2019-01-04 19:27:22.489	Performed by 1.0.5.1 Software version.
2019-01-04 19:27:39.197	Selected file: G:/HUAWEI/RNE-L21/dload/RNE-L21_hw_meafnaf/update_RNE-L21_hw_meafnaf.app
2019-01-04 19:28:04.340	2019-01-04 19:28:04 GMT -------------------------------------------------
2019-01-04 19:28:04.356	Starting Write Firmware
2019-01-04 19:28:04.387	Selected firmware:G:/HUAWEI/RNE-L21/dload/RNE-L21_hw_meafnaf/update_RNE-L21_hw_meafnaf.app
2019-01-04 19:28:04.387	Extracting firmware partitions...
2019-01-04 19:28:06.004	partition has been extract successfully
2019-01-04 19:28:06.045	Connecting to phone..
2019-01-04 19:28:21.061	Phone connect successfully
2019-01-04 19:28:21.081	Writing firmware..
2019-01-04 19:28:26.062	Writing SHA256RSA partition..
2019-01-04 19:28:27.127	SHA256RSA partition has been written successfully
2019-01-04 19:28:27.143	Writing CRC partition..
2019-01-04 19:28:28.159	CRC partition has been written successfully
2019-01-04 19:28:28.174	Writing CURVER partition..
2019-01-04 19:28:29.175	CURVER partition has been written successfully
2019-01-04 19:28:29.190	Writing VERLIST partition..
2019-01-04 19:28:30.191	VERLIST partition has been written successfully
2019-01-04 19:28:30.206	Writing PACKAGE_TYPE partition..
2019-01-04 19:28:31.222	PACKAGE_TYPE partition has been written successfully
2019-01-04 19:28:31.238	Writing EFI partition..
2019-01-04 19:28:32.254	EFI partition has been written successfully
2019-01-04 19:28:32.269	Writing CUST partition..
2019-01-04 19:28:59.449	CUST partition has been written successfully
2019-01-04 19:28:59.464	Writing VERSION partition..
2019-01-04 19:29:03.339	VERSION partition has been written successfully
2019-01-04 19:29:03.355	Writing USERDATA partition..
2019-01-04 19:32:33.387	USERDATA partition has been written successfully
2019-01-04 19:32:42.450	Firmware writing successfully completed
2019-01-04 19:32:42.466
2019-01-04 19:32:42.481	Write Firmware done.
2019-01-04 19:32:42.497	Performed by 1.0.5.1 Software version.
System-FAC 5.1.0.88(008G) = board firmware factory
board firmware its the same with combination in samsung mobile
The Following 4 Users Say Thank You to rebainoor For This Useful Post:
Old 01-08-2019, 11:16   #6 (permalink)
Member: 2249537
Thanks Meter: 51
waiting for board firmware
Old 01-09-2019, 18:45   #7 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 480
What port is required to write this board software..? Is it 9008?
Old 01-09-2019, 19:06   #8 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,104
port is HUAWEI USB COM 1.0 for Hisilicon mobile based chip
and 9008 is for qualcomm mobile based chip
The Following 3 Users Say Thank You to rebainoor For This Useful Post:
Old 01-11-2019, 14:33   #9 (permalink)
gulshan-iqbal's Avatar
Member: 388033
Thanks Meter: 693
Question
Wll bro,after flashing board firmware can u tell me in the firmware version i have downloaded where to find the real vendor and country ?
Old 01-11-2019, 15:27   #10 (permalink)
Member: 1984825
Thanks Meter: 222
Where can i find the test huawei tool 10.0.5.1
best regards
Old 01-11-2019, 16:16   #11 (permalink)
Member: 388033
Thanks Meter: 693
Thumbs up solved
Welcome to Octoplus Huawei Software v.‪1.0.5‬
Selected file: ‪D:/MTK&QU~1/Firmware/HUAWEI~1/P9LITE~1/HUAWEI~1.1_C/HUAWEI~1.1_C/Software/SDUPDA~1/dload/hw/eu/update_data_hw_eu.app‬
Selected file: ‪D:/MTK&Qualcomm-Phones/Firmware/Huawei Firmware/P9 Lite/HUAWEI P9 Lite Firmware (VNS-L21, Android 6.0, EMUI 4.1, C432B151, Bulgarian)/HUAWEI P9 Lite Firmware (VNS-L21, Android 6.0, EMUI 4.1, C432B151, Bulgarian)/Software/SDupdate_Package/dload/UPDATE.APP‬
2019-01-11 14:54:01 GMT -------------------------------------------------
IMEI A: ‪860918034986465‬
IMEI B: ‪860918034986465‬
S/N: ‪9JT7N17323000238‬
partition has been extracted successfully
Checking firmware compatibility
Writing ‪XLOADER‬ partition..
‪XLOADER‬ partition has been written successfully
Writing ‪FW_LPM3‬ partition..
‪FW_LPM3‬ partition has been written successfully
Writing ‪FASTBOOT‬ partition..
‪FASTBOOT‬ partition has been written successfully
Writing ‪MODEMNVM_UPDATE‬ partition..
‪MODEMNVM_UPDATE‬ partition has been written successfully
Writing ‪TEEOS‬ partition..
‪TEEOS‬ partition has been written successfully
Writing ‪TRUSTFIRMWARE‬ partition..
‪TRUSTFIRMWARE‬ partition has been written successfully
Writing ‪SENSORHUB‬ partition..
‪SENSORHUB‬ partition has been written successfully
Writing ‪FW_HIFI‬ partition..
‪FW_HIFI‬ partition has been written successfully
Writing ‪BOOT‬ partition..
‪BOOT‬ partition has been written successfully
Writing ‪RECOVERY‬ partition..
‪RECOVERY‬ partition has been written successfully
Writing ‪RECOVERY2‬ partition..
‪RECOVERY2‬ partition has been written successfully
Writing ‪DTS‬ partition..
‪DTS‬ partition has been written successfully
Writing ‪MODEM_FW‬ partition..
‪MODEM_FW‬ partition has been written successfully
Writing ‪CACHE‬ partition..
‪CACHE‬ partition has been written successfully
Writing ‪SYSTEM‬ partition..
‪SYSTEM‬ partition has been written successfully
Writing ‪USERDATA‬ partition..
‪USERDATA‬ partition has been written successfully
The Following User Says Thank You to gulshan-iqbal For This Useful Post:
Old 01-11-2019, 16:38   #12 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,104
for dead huawei mobile with hisilicon based cpu and to know what version it instaled befor dead you need do :
flash board firmware by select option fastboot only the mobile wil run in fastboot mode
and do read info in to know what version you need flash it
The Following 7 Users Say Thank You to rebainoor For This Useful Post:
Old 01-11-2019, 17:31   #13 (permalink)
Member: 1984825
Thanks Meter: 222
2019-01-11 16:24:32 GMT -------------------------------------------------
Starting Read Info (Fastboot Mode)
Device Model: ‪PRA-LX1‬
IMEI A: ‪867437037096290‬
IMEI B: ‪000000000000000‬
MEID: ‪00000000000000‬
S/N: ‪57U7N17C12007443‬
Build Number: ‪System 8.0.0.046(0GR2)
i need this firmware please team
Old 01-12-2019, 10:55   #14 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,412
We will try to find update firmware for this device and uplaod into the Support Area, we will inform You when it will be ready.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 01-12-2019, 12:30   #15 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,104
For what need you flash this phone ? What error appear in screen ?
Page generated in 0.27932 seconds with 8 queries
