01-04-2019, 15:18 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,102 | first test to unbrick (boot repaire) RNE-L21 with Board firmware with test version Code: 2019-01-04 13:30:54.211 Loading application settings 2019-01-04 13:30:54.227 Refreshing serial ports list 2019-01-04 13:30:54.570 Found COM ports: 2019-01-04 13:30:54.570 1: COM1 Port de communication 2019-01-04 13:30:54.570 2: COM3 USB Serial Port 2019-01-04 13:30:54.570 3: COM4 USB Serial Port 2019-01-04 13:30:54.601 Welcome to Octoplus Huawei Software v.1.0.5.1 2019-01-04 13:30:54.601 2019-01-04 13:30:54.601 To enable 'Manufacture' mode dial 2019-01-04 13:30:54.601 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2019-01-04 13:30:54.601 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2019-01-04 13:30:54.601 2019-01-04 13:30:54.601 To enable 'Fastboot' mode 2019-01-04 13:30:54.601 1. Power off the phone. Remove SD and SIM cards 2019-01-04 13:30:54.601 2. Press 'Vol-' and insert USB cable 2019-01-04 13:30:54.601 3. Wait until phone enters 'Fastboot' mode 2019-01-04 13:30:54.601 2019-01-04 13:30:54.601 To enable 'Upgrade' mode 2019-01-04 13:30:54.601 1. Power off the phone. Remove SD and SIM cards 2019-01-04 13:30:54.601 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2019-01-04 13:30:54.601 3. Wait until phone enters 'Upgrade mode' 2019-01-04 13:30:54.679 Init finished 2019-01-04 13:31:22.786 Selected file: G:/HUAWEI/RNE-L21/Software/factory_verison 2019-01-04 13:31:53.328 2019-01-04 13:31:53 GMT ------------------------------------------------- 2019-01-04 13:31:53.328 Starting Write Firmware 2019-01-04 13:31:53.359 Searching connected Fastboot devices... 2019-01-04 13:32:08.445 Fastboot devices not found 2019-01-04 13:32:08.445 2019-01-04 13:32:08.445 Write Firmware failed. 2019-01-04 13:32:08.461 Performed by 1.0.5.1 Software version. 2019-01-04 13:32:37.572 2019-01-04 13:32:37 GMT ------------------------------------------------- 2019-01-04 13:32:37.572 Starting Write Firmware 2019-01-04 13:32:37.635 Connecting to phone.. 2019-01-04 13:32:37.654 Phone connect successfully 2019-01-04 13:32:37.657 Phone connect successfully 2019-01-04 13:32:37.659 Writing board firmware files... 2019-01-04 13:32:37.660 Writing XLOADER partition.. 2019-01-04 13:32:40.915 XLOADER partition has been written successfully 2019-01-04 13:32:40.915 Writing FASTBOOT partition.. 2019-01-04 13:32:52.590 FASTBOOT partition has been written successfully 2019-01-04 13:32:52.591 2019-01-04 13:32:52.593 Write Firmware done. 2019-01-04 13:32:52.595 Performed by 1.0.5.1 Software version. |
The Following 10 Users Say Thank You to rebainoor For This Useful Post: |
01-07-2019, 17:34 | #4 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Portugal
Member: 478535 Status: Offline Thanks Meter: 432 | Quote:
Thanks for the test rebainoor and a big thanks to octoplus team for the effort in completing the tool to get more functionalities! | |
The Following 2 Users Say Thank You to Desirat For This Useful Post: |
01-07-2019, 17:37 | #5 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,102 | its work normaly after unbrick it you need flash it in upgrade mode and fully change region/vendor Code: 2019-01-04 19:12:52.174 2019-01-04 19:12:52 GMT ------------------------------------------------- 2019-01-04 19:12:52.174 Starting Auto detect 2019-01-04 19:12:52.217 Running detect for HiSilicon 2019-01-04 19:12:52.334 Detect HiSilicon platform ok 2019-01-04 19:12:52.334 Detected HiSilicon Android Device at COM78 2019-01-04 19:12:52.342 Read pre auth info for HiSilicon 2019-01-04 19:12:52.454 Can't get device model. 2019-01-04 19:12:52.613 Removing security protection... 2019-01-04 19:12:54.732 Auth 1 HiSilicon fail 2019-01-04 19:12:54.852 Connecting to server... 2019-01-04 19:12:55.834 Check auth 3 2019-01-04 19:12:56.896 Authorization is successful 2019-01-04 19:12:56.901 Reading basic data... 2019-01-04 19:12:57.202 Can't read Vendor/Country code. 2019-01-04 19:12:57.329 Can't get device model. 2019-01-04 19:12:57.449 Reading secure data... 2019-01-04 19:13:05.087 Device Model: Huawei HiSilicon Device 2019-01-04 19:13:05.092 Firmware: System-FAC 5.1.0.88(008G) 2019-01-04 19:13:05.098 Boot: Chipset-Chipset-dallas-FAC 5.1.0.1(01YP)_BOOT 2019-01-04 19:13:05.105 Fastboot: Chipset-Chipset-dallas-FAC 5.1.0.1(01YP)_FASTBOOT 2019-01-04 19:13:05.111 System: System-FAC 5.1.0.88(008G) 2019-01-04 19:13:05.117 Recovery: (unknow) 2019-01-04 19:13:05.123 MEID: 00000000000000 2019-01-04 19:13:05.126 PESN: 00000000 2019-01-04 19:13:05.129 IMEI A: 8679730xxxxxxxx 2019-01-04 19:13:05.133 IMEI B: 8679730xxxxxxxx 2019-01-04 19:13:05.137 Bluetooth MAC: B0:E1:7E:xx:xx:xx 2019-01-04 19:13:05.140 WiFi MAC: B0:E1:7E:xx:xx:xx 2019-01-04 19:13:05.144 S/N: FFY5T17B2xxxxxxxxxx 2019-01-04 19:13:05.148 Board S/N: 5T4QGL1xxxxxxxxx 2019-01-04 19:13:05.151 2019-01-04 19:13:05.154 Auto detect done. 2019-01-04 19:13:05.156 Performed by 1.0.5.1 Software version. 2019-01-04 19:14:43.403 2019-01-04 19:14:43 GMT ------------------------------------------------- 2019-01-04 19:14:43.412 Starting Write Firmware 2019-01-04 19:14:43.436 Selected firmware:G:/HUAWEI/RNE-L21/dload/UPDATE.APP 2019-01-04 19:14:43.438 Extracting firmware partitions... 2019-01-04 19:14:49.157 partition has been extract successfully 2019-01-04 19:14:49.167 Connecting to phone.. 2019-01-04 19:15:04.185 Phone connect successfully 2019-01-04 19:15:04.194 Writing firmware.. 2019-01-04 19:15:09.186 Writing SHA256RSA partition.. 2019-01-04 19:15:10.279 SHA256RSA partition has been written successfully 2019-01-04 19:15:10.279 Writing CRC partition.. 2019-01-04 19:15:11.355 CRC partition has been written successfully 2019-01-04 19:15:11.365 Writing CURVER partition.. 2019-01-04 19:15:12.382 CURVER partition has been written successfully 2019-01-04 19:15:12.382 Writing VERLIST partition.. 2019-01-04 19:15:13.395 VERLIST partition has been written successfully 2019-01-04 19:15:13.398 Writing PACKAGE_TYPE partition.. 2019-01-04 19:15:14.410 PACKAGE_TYPE partition has been written successfully 2019-01-04 19:15:14.410 Writing EFI partition.. 2019-01-04 19:15:15.484 EFI partition has been written successfully 2019-01-04 19:15:15.484 Writing XLOADER partition.. 2019-01-04 19:15:16.546 XLOADER partition has been written successfully 2019-01-04 19:15:16.546 Writing FW_LPM3 partition.. 2019-01-04 19:15:17.832 FW_LPM3 partition has been written successfully 2019-01-04 19:15:17.844 Writing FASTBOOT partition.. 2019-01-04 19:15:19.323 FASTBOOT partition has been written successfully 2019-01-04 19:15:19.323 Writing MODEMNVM_UPDATE partition.. 2019-01-04 19:15:22.205 MODEMNVM_UPDATE partition has been written successfully 2019-01-04 19:15:22.205 Writing TEEOS partition.. 2019-01-04 19:15:23.625 TEEOS partition has been written successfully 2019-01-04 19:15:23.625 Writing TRUSTFIRMWARE partition.. 2019-01-04 19:15:24.668 TRUSTFIRMWARE partition has been written successfully 2019-01-04 19:15:24.681 Writing SENSORHUB partition.. 2019-01-04 19:15:25.851 SENSORHUB partition has been written successfully 2019-01-04 19:15:25.851 Writing FW_HIFI partition.. 2019-01-04 19:15:27.857 FW_HIFI partition has been written successfully 2019-01-04 19:15:27.857 Writing KERNEL partition.. 2019-01-04 19:15:32.967 KERNEL partition has been written successfully 2019-01-04 19:15:32.970 Writing RAMDISK partition.. 2019-01-04 19:15:36.789 RAMDISK partition has been written successfully 2019-01-04 19:15:36.795 Writing RECOVERY_RAMDISK partition.. 2019-01-04 19:15:43.405 RECOVERY_RAMDISK partition has been written successfully 2019-01-04 19:15:43.412 Writing RECOVERY_VENDOR partition.. 2019-01-04 19:15:47.277 RECOVERY_VENDOR partition has been written successfully 2019-01-04 19:15:47.277 Writing ERECOVERY_KERNEL partition.. 2019-01-04 19:15:52.471 ERECOVERY_KERNEL partition has been written successfully 2019-01-04 19:15:52.471 Writing ERECOVERY_RAMDISK partition.. 2019-01-04 19:15:58.986 ERECOVERY_RAMDISK partition has been written successfully 2019-01-04 19:15:59.002 Writing ERECOVERY_VENDOR partition.. 2019-01-04 19:16:02.753 ERECOVERY_VENDOR partition has been written successfully 2019-01-04 19:16:02.763 Writing RECOVERY_VBMETA partition.. 2019-01-04 19:16:03.771 RECOVERY_VBMETA partition has been written successfully 2019-01-04 19:16:03.787 Writing ERECOVERY_VBMETA partition.. 2019-01-04 19:16:04.788 ERECOVERY_VBMETA partition has been written successfully 2019-01-04 19:16:04.799 Writing DTS partition.. 2019-01-04 19:16:09.864 DTS partition has been written successfully 2019-01-04 19:16:09.881 Writing MODEM_FW partition.. 2019-01-04 19:16:26.863 MODEM_FW partition has been written successfully 2019-01-04 19:16:26.881 Writing VBMETA partition.. 2019-01-04 19:16:27.893 VBMETA partition has been written successfully 2019-01-04 19:16:27.908 Writing ODM partition.. 2019-01-04 19:16:46.151 ODM partition has been written successfully 2019-01-04 19:16:46.167 Writing CACHE partition.. 2019-01-04 19:16:49.223 CACHE partition has been written successfully 2019-01-04 19:16:49.242 Writing SYSTEM partition.. 2019-01-04 19:25:07.379 SYSTEM partition has been written successfully 2019-01-04 19:25:07.395 Writing CUST partition.. 2019-01-04 19:25:11.429 CUST partition has been written successfully 2019-01-04 19:25:11.444 Writing VENDOR partition.. 2019-01-04 19:26:46.666 VENDOR partition has been written successfully 2019-01-04 19:26:46.681 Writing VERSION partition.. 2019-01-04 19:26:48.493 VERSION partition has been written successfully 2019-01-04 19:26:48.508 Writing PRODUCT partition.. 2019-01-04 19:27:12.639 PRODUCT partition has been written successfully 2019-01-04 19:27:12.655 Writing USERDATA partition.. 2019-01-04 19:27:22.442 USERDATA partition has been written successfully 2019-01-04 19:27:22.458 Firmware writing successfully completed 2019-01-04 19:27:22.474 2019-01-04 19:27:22.474 Write Firmware done. 2019-01-04 19:27:22.489 Performed by 1.0.5.1 Software version. 2019-01-04 19:27:39.197 Selected file: G:/HUAWEI/RNE-L21/dload/RNE-L21_hw_meafnaf/update_RNE-L21_hw_meafnaf.app 2019-01-04 19:28:04.340 2019-01-04 19:28:04 GMT ------------------------------------------------- 2019-01-04 19:28:04.356 Starting Write Firmware 2019-01-04 19:28:04.387 Selected firmware:G:/HUAWEI/RNE-L21/dload/RNE-L21_hw_meafnaf/update_RNE-L21_hw_meafnaf.app 2019-01-04 19:28:04.387 Extracting firmware partitions... 2019-01-04 19:28:06.004 partition has been extract successfully 2019-01-04 19:28:06.045 Connecting to phone.. 2019-01-04 19:28:21.061 Phone connect successfully 2019-01-04 19:28:21.081 Writing firmware.. 2019-01-04 19:28:26.062 Writing SHA256RSA partition.. 2019-01-04 19:28:27.127 SHA256RSA partition has been written successfully 2019-01-04 19:28:27.143 Writing CRC partition.. 2019-01-04 19:28:28.159 CRC partition has been written successfully 2019-01-04 19:28:28.174 Writing CURVER partition.. 2019-01-04 19:28:29.175 CURVER partition has been written successfully 2019-01-04 19:28:29.190 Writing VERLIST partition.. 2019-01-04 19:28:30.191 VERLIST partition has been written successfully 2019-01-04 19:28:30.206 Writing PACKAGE_TYPE partition.. 2019-01-04 19:28:31.222 PACKAGE_TYPE partition has been written successfully 2019-01-04 19:28:31.238 Writing EFI partition.. 2019-01-04 19:28:32.254 EFI partition has been written successfully 2019-01-04 19:28:32.269 Writing CUST partition.. 2019-01-04 19:28:59.449 CUST partition has been written successfully 2019-01-04 19:28:59.464 Writing VERSION partition.. 2019-01-04 19:29:03.339 VERSION partition has been written successfully 2019-01-04 19:29:03.355 Writing USERDATA partition.. 2019-01-04 19:32:33.387 USERDATA partition has been written successfully 2019-01-04 19:32:42.450 Firmware writing successfully completed 2019-01-04 19:32:42.466 2019-01-04 19:32:42.481 Write Firmware done. 2019-01-04 19:32:42.497 Performed by 1.0.5.1 Software version. board firmware its the same with combination in samsung mobile Last edited by rebainoor; 01-07-2019 at 17:46. |
The Following 4 Users Say Thank You to rebainoor For This Useful Post: |
01-09-2019, 19:06 | #8 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,102 | port is HUAWEI USB COM 1.0 for Hisilicon mobile based chip and 9008 is for qualcomm mobile based chip |
The Following 3 Users Say Thank You to rebainoor For This Useful Post: |
01-11-2019, 14:33 | #9 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Albania,City Under The Castle Age: 47
Member: 388033 Status: Offline Thanks Meter: 693 | Quote:
01-11-2019, 16:16 | #11 (permalink) | |
Member: 388033 Status: Offline Thanks Meter: 693 | solved Quote:
To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Selected file: D:/MTK&QU~1/Firmware/HUAWEI~1/P9LITE~1/HUAWEI~1.1_C/HUAWEI~1.1_C/Software/SDUPDA~1/dload/hw/eu/update_data_hw_eu.app Selected file: D:/MTK&Qualcomm-Phones/Firmware/Huawei Firmware/P9 Lite/HUAWEI P9 Lite Firmware (VNS-L21, Android 6.0, EMUI 4.1, C432B151, Bulgarian)/HUAWEI P9 Lite Firmware (VNS-L21, Android 6.0, EMUI 4.1, C432B151, Bulgarian)/Software/SDupdate_Package/dload/UPDATE.APP 2019-01-11 14:54:01 GMT ------------------------------------------------- Starting Write Firmware Searching connected Fastboot devices... IMEI A: 860918034986465 IMEI B: 860918034986465 S/N: 9JT7N17323000238 Extracting firmware partitions... partition has been extracted successfully Checking firmware compatibility Connecting to server... Writing XLOADER partition.. XLOADER partition has been written successfully Writing FW_LPM3 partition.. FW_LPM3 partition has been written successfully Writing FASTBOOT partition.. FASTBOOT partition has been written successfully Writing MODEMNVM_UPDATE partition.. MODEMNVM_UPDATE partition has been written successfully Writing TEEOS partition.. TEEOS partition has been written successfully Writing TRUSTFIRMWARE partition.. TRUSTFIRMWARE partition has been written successfully Writing SENSORHUB partition.. SENSORHUB partition has been written successfully Writing FW_HIFI partition.. FW_HIFI partition has been written successfully Writing BOOT partition.. BOOT partition has been written successfully Writing RECOVERY partition.. RECOVERY partition has been written successfully Writing RECOVERY2 partition.. RECOVERY2 partition has been written successfully Writing DTS partition.. DTS partition has been written successfully Writing MODEM_FW partition.. MODEM_FW partition has been written successfully Writing CACHE partition.. CACHE partition has been written successfully Writing SYSTEM partition.. SYSTEM partition has been written successfully Writing USERDATA partition.. USERDATA partition has been written successfully Firmware writing successfully completed | |
The Following User Says Thank You to gulshan-iqbal For This Useful Post: |
01-11-2019, 16:38 | #12 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,102 | for dead huawei mobile with hisilicon based cpu and to know what version it instaled befor dead you need do : flash board firmware by select option fastboot only the mobile wil run in fastboot mode and do read info in to know what version you need flash it |
The Following 7 Users Say Thank You to rebainoor For This Useful Post: |
01-11-2019, 17:31 | #13 (permalink) |
No Life Poster Join Date: Jul 2013 Location: in my company
Member: 1984825 Status: Offline Thanks Meter: 222 | Welcome to Octoplus Huawei Software v.1.0.5 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' 2019-01-11 16:24:32 GMT ------------------------------------------------- Starting Read Info (Fastboot Mode) Searching connected Fastboot devices... Device Model: PRA-LX1 IMEI A: 867437037096290 IMEI B: 000000000000000 MEID: 00000000000000 S/N: 57U7N17C12007443 Build Number: System 8.0.0.046(0GR2) i need this firmware please team |
01-12-2019, 10:55 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | We will try to find update firmware for this device and uplaod into the Support Area, we will inform You when it will be ready. |
01-12-2019, 12:30 | #15 (permalink) | |
Member: 231728 Status: Offline Thanks Meter: 2,102 | Quote:
