01-11-2024, 10:36 | #1 (permalink) |
Junior Member Join Date: Jul 2018 Location: Bulgaria, Dulovo
Member: 2849478 Status: Offline Thanks Meter: 1 | Huawei MAR-LX1A dead after downgrade [Answered] To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2: COM3 USB Serial Port Job ID: 00000000018E35A2 2024-01-11 08:55:09 Starting Write Firmware(Factory mode) Selected phone model: MAR-LX1A Warning: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option"). Warning: Selected response: Proceed Selected file: I can't copy link so here is empty Selected Partial flashing mode! Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Loading firmware configuaration file... Initializing remote service connection... Downloading resource... Writing bootloader MAR-BD 1.0.0.55... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Bootloader firmware files has been written successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: 76YDU20714016927 Device Model: MAR-LX1A System: MAR-L21A 10.0.0.532(C431E15R2P7) Removing firmware protection... Write Firmware(Factory mode) failed. Performed by 1.3.4 Software version. What can I do? |
01-13-2024, 11:03 | #2 (permalink) |
Member: 2849478 Status: Offline Thanks Meter: 1 | Well I flashed the phone with update_full_base firmware downloaded from the net. Now it starts and displays "Your device has loaded a different operating system." and restarts in eRecovery mode. Where I can download software for this phone? Is there any in support area? |
01-16-2024, 10:17 | #5 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Online Thanks Meter: 2,141 | You can try to re-flash device firstly with board firmware via Factory mode, then re-flash device with same stock firmware version via Fastboot mode. Thereafter, send us result. |
