01-07-2019, 05:46 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: World
Member: 792851 Status: Offline Thanks Meter: 136 | Huawei Honor CHM-UL00 trying to flash question [Answered] Code: Welcome to Octoplus Huawei Software v.1.0.5 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Selected file: D:/update/UPDATE.APP 2019-01-07 04:44:04 GMT ------------------------------------------------- Starting Write Firmware Extracting firmware partitions... partition has been extract successfully Connecting to phone.. Phone connecting failed Write Firmware failed. Performed by 1.0.5 Software version. 2019-01-07 04:45:05 GMT ------------------------------------------------- Starting Write Firmware Searching connected Fastboot devices... S/N: H3Z4C15604000504 Extracting firmware partitions... partition has been extracted successfully Checking firmware compatibility Write Firmware done. Performed by 1.0.5 Software version. Last edited by Octopus box; 01-07-2019 at 17:51. |
01-07-2019, 17:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,388 | Hello. What is the firmware version in your device now exaxtly? Please put the device into Fastboot mode and perform "Read info" operation. Then post here full Software lo with this info, we will check it. Also write here, what firmware do You try to write. |
01-08-2019, 22:23 | #3 (permalink) | |
Member: 792851 Status: Offline Thanks Meter: 136 | Quote:
Code: 2019-01-07 23:21:42.559 Loading application settings 2019-01-07 23:21:42.559 Refreshing serial ports list 2019-01-07 23:21:42.777 Found COM ports: 2019-01-07 23:21:42.777 1: COM5 USB Serial Port 2019-01-07 23:21:42.824 Welcome to Octoplus Huawei Software v.1.0.5 2019-01-07 23:21:42.840 2019-01-07 23:21:42.840 To enable 'Manufacture' mode dial 2019-01-07 23:21:42.840 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2019-01-07 23:21:42.840 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2019-01-07 23:21:42.840 2019-01-07 23:21:42.840 To enable 'Fastboot' mode 2019-01-07 23:21:42.840 1. Power off the phone. Remove SD and SIM cards 2019-01-07 23:21:42.840 2. Press 'Vol-' and insert USB cable 2019-01-07 23:21:42.840 3. Wait until phone enters 'Fastboot' mode 2019-01-07 23:21:42.840 2019-01-07 23:21:42.840 To enable 'Upgrade' mode 2019-01-07 23:21:42.840 1. Power off the phone. Remove SD and SIM cards 2019-01-07 23:21:42.840 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2019-01-07 23:21:42.840 3. Wait until phone enters 'Upgrade mode' 2019-01-07 23:21:42.965 Init finished 2019-01-07 23:21:55.278 2019-01-07 23:21:55 GMT ------------------------------------------------- 2019-01-07 23:21:55.278 Starting Read Info (Fastboot Mode) 2019-01-07 23:21:55.294 Searching connected Fastboot devices... 2019-01-07 23:21:56.341 Total interfaces: 1 2019-01-07 23:21:56.341 Interface 0 : flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#h3z4c15604000504#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} 2019-01-07 23:21:57.575 S/N: H3Z4C15604000504 2019-01-07 23:21:57.575 Build Number: CHM-UL00 V100R001C00B140 here fast boot flashing log, it cud not flash at all just log show flashing done Code: 2019-01-08 03:39:34.157 Starting Write Firmware 2019-01-08 03:39:34.157 Searching connected Fastboot devices... 2019-01-08 03:39:35.175 Total interfaces: 1 2019-01-08 03:39:35.175 Interface 0 : flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#h3z4c15604000504#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} 2019-01-08 03:39:35.998 S/N: H3Z4C15604000504 2019-01-08 03:39:36.404 Extracting firmware partitions... 2019-01-08 03:39:40.154 partition has been extracted successfully 2019-01-08 03:39:40.154 Checking firmware compatibility 2019-01-08 03:39:40.779 Failed to read initial Reset FRP data 2019-01-08 03:39:40.982 Failed to read initial Reset FRP data 2019-01-08 03:39:41.185 Failed to read initial Reset FRP data 2019-01-08 03:39:41.389 Failed to read initial Reset FRP data 2019-01-08 03:39:41.592 Failed to read initial Reset FRP data 2019-01-08 03:39:41.592 2019-01-08 03:39:41.592 Write Firmware done. 2019-01-08 03:39:41.592 Performed by 1.0.5 Software version. Last edited by Octopus box; 01-09-2019 at 05:37. | |
01-09-2019, 08:54 | #5 (permalink) | |
I have try all option advance mode normal mode upgrade mode all option don’t work I fix phone flash manual with adb fastboot method Thanks Last edited by Octopus box; 01-09-2019 at 09:04. | |
