Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus Huawei Tool
Old 08-27-2018, 11:07   #1 (permalink)
Member: 2669781
Thanks Meter: 1,839
Thumbs up HUAWEI Mate 9 / MHA-L29 Factory Reset Protection disabled without a hitch
Full log of the operation/
Welcome to Octoplus/Octopus Huawei Software v.1.0.3
To enable 'Manufacture' mode dial
  - for Qualcomm and Hisilicon based models: *#*#2846579#*#*
ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode
To enable 'Fastboot' mode
  1. Power off the phone. Remove SD and SIM cards
  2. Press 'Vol-' and insert USB cable
  3. Wait until phone enters 'Fastboot' mode
2018-08-27 09:55:40 GMT -------------------------------------------------
Starting Reset FRP (Fastboot Mode)
Searching for connected Fastboot devices...
Device Model: MHA-L29
IMEI A: 861957038159132
IMEI B: 861957038164330
S/N: AHK0217115003975
Initializing Reset FRP process...
Connecting to server...
Writing Reset FRP data...
Reset FRP (Fastboot Mode) done.
Performed by 1.0.3 Software version.
The Following 5 Users Say Thank You to lyes_albert For This Useful Post:
Old 12-17-2018, 11:16   #2 (permalink)
Member: 1926663
Thanks Meter: 22
Hi, I need to do FRP to a mate 9 MHA-L29 but I can not get it in fasboot mode, any solution?
Old 12-17-2018, 11:22   #3 (permalink)
Member: 2669781
Thanks Meter: 1,839
Hi sir,
Can you further describe the issue?
Booting to fastboot ain't that hard, Just hold volume down while plugging the USB cable, phone should be totally OFF.
Check whether Volume buttons are properly and fully functioning, your USB cable as wel...
Old 12-17-2018, 11:32   #4 (permalink)
Member: 1926663
Thanks Meter: 22
Originally Posted by lyes_albert View Post
Hi sir,
OK the buttons work correctly the cables are correct but I can not get in between to load and do not enter fatboot mode
Old 12-17-2018, 11:34   #5 (permalink)
Member: 2669781
Thanks Meter: 1,839
Turn the phone off, totally off...
Then hold volume down, an hook your cable up to PC.. Keep holding volume down for about 15 secs,
Please what happens to the phone when all that is done? To which mode does it go?
Old 12-17-2018, 11:57   #6 (permalink)
Member: 1926663
Thanks Meter: 22
The phone off I press volume down I connect the cable and keep volume down the phone goes into charge mode
Old 12-17-2018, 12:01   #7 (permalink)
Member: 2669781
Thanks Meter: 1,839
This is a weird case, it should go into Fastboot mode, unless one of the following things ain't properly functioning; Volume buttons, PC usb port, or the cable .....
Did you try to plug it on a different USB port? change the PC, change the Cable please....it should normally work..
Did you see any drivers installing while plugging the phone on normal mode?
Old 12-17-2018, 12:15   #8 (permalink)
Member: 1926663
Thanks Meter: 22
In normal mode I connect it and load it but no driver appears
Old 12-17-2018, 12:18   #9 (permalink)
Member: 2669781
Thanks Meter: 1,839
if no drivers pop up to install during normal mode, then I believe, something wrong with your phone's USB socket,
Probably, the phone's USB connector has been replaced, and DATA pins haven't been properly soldered, that's why the phone is charging but, drivers are not being installed...
Good luck
Old 12-17-2018, 12:26   #10 (permalink)
Member: 1926663
Thanks Meter: 22
Ok, thanks, I'm going to see
Old 12-17-2018, 13:13   #11 (permalink)
Member: 1926663
Thanks Meter: 22
I have disassembled it and the connector is apparently fine, is there any other way to enter fasboot mode?
Old 12-23-2018, 15:42   #12 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 480
Boot in to recovery by holding vol + and power button together after entering recovery you can go to fastboot from there by selecting reboot to bootloader
Page generated in 0.18421 seconds with 9 queries
