10-23-2018, 21:35 | #1 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Italy
Member: 2101975 Status: Offline Thanks Meter: 21 | Huawei P8 lite 2017 PRA-LX1 IMEI Repair question [Answered] Imei repair possible on PRA-LX1 with Kirin 655 cpu and android 8.0? Last edited by Octopus box; 10-24-2018 at 04:46. |
10-24-2018, 04:46 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hi. Repairing IMEI is supported for this device model, but may not work for latest firmware versions/Security path levels. You need try and Software will automatically check, whether operation is supported for your device revision (firmware version). It is not possible to say without trying. |
10-24-2018, 13:30 | #3 (permalink) |
Member: 2101975 Status: Offline Thanks Meter: 21 | Hi. Can you assist me a little bit? I'm new for huawei devices. I have activated right now the license, installed everything, enabled manufactured mode, pressed autodected, so now I have only to change the imei or does it require before root permissions? |
10-24-2018, 19:20 | #5 (permalink) |
Member: 2101975 Status: Offline Thanks Meter: 21 | Failed Is anything else I can try? 2018-10-24 18:16:31 GMT ------------------------------------------------- Starting Connect Removing security protection... Connecting to server... Authorization successful Reading basic data... Reading secure data... Device Model: PRA-L11 Firmware: System 8.0.0.046(0I6M) Boot: System 8.0.0.046(0I6M)_BOOT Fastboot: Chipset-dallas8.0.1.001(01IY)_FASTBOOT System: System 8.0.0.046(0I6M) Recovery: (unknow) MEID: 00000000000000 PESN: 00000000 IMEI A: 866386035279005 IMEI B: 000000000000000 Bluetooth MAC: 1C:15:1F:00:BC:1E WiFi MAC: 1C:15:1F:00:AE5 S/N: 57UDU17A16000698 Board S/N: DU4REW17A9073859 Vendor Code: vodafone Country Code: it Connect done. Performed by 1.0.3 Software version. 2018-10-24 18:16:53 GMT ------------------------------------------------- Starting Repair Info New IMEI A: 866386035270000 Reading basic data... Reading secure data... Writing public keys... Identifying security... Repairing IMEI A... Resetting your device Repair Info failed. Performed by 1.0.3 Software version. Last edited by Octopus box; 10-25-2018 at 06:59. |
10-25-2018, 06:59 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Accordingly to Software log, Repair IMEI operation was performed successfully. Try to reset your device manually and check IMEI. |
10-25-2018, 11:08 | #7 (permalink) | |
Member: 2101975 Status: Offline Thanks Meter: 21 | Quote:
Really? Log says repair info failed. BTW, manually restarted device and still have the old imei. EDIT: Ok I have noticed that if pressing again the button autodetect it now reads the info and imei is changed but in phone info software I still have the old imei, is this to be considered repaired? Last edited by BxS4ever; 10-25-2018 at 11:17. | |
10-25-2018, 11:34 | #9 (permalink) |
Member: 2101975 Status: Offline Thanks Meter: 21 | Ok phone network is working again, but as I said before in phone system information, I still have the old imei number. Maybe performing a factory reset will report the new imei number? |
10-25-2018, 12:38 | #10 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Portugal
Member: 478535 Status: Online Thanks Meter: 433 | You won't loose anything by factory reset phone, unless you have files/contacts in it. In fact, it may be a cached info still on phone, so, as support told you, hard reset phone to see if it all goes well! |
The Following User Says Thank You to Desirat For This Useful Post: |
