07-16-2019, 21:30 | #1 (permalink) |
Freak Poster Join Date: Oct 2017 Location: pakistan
Member: 2767415 Status: Offline Thanks Meter: 30 | huawei p8 lite stuck on rescue mode [Answered] fastboot info firmware is ale-l21c185b574 i download ale-l21c185b574 but still saw firmware is not compatible for phone log Welcome to Octoplus Huawei Software v.1.1.0 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Nuvoton Communications Port 2: COM17 USB Serial Port Selected file: C:/Users/ANGEL/Desktop/UPDATE.APP 2019-07-16 20:26:27 GMT ------------------------------------------------- Starting Write Firmware Searching connected Fastboot devices... Device Model: ALE-L21 System: ALE-L21C185B574 |
07-17-2019, 12:12 | #4 (permalink) |
Member: 2767415 Status: Offline Thanks Meter: 30 | Welcome to Octoplus Huawei Software v.1.1.0 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Nuvoton Communications Port 2: COM17 USB Serial Port Selected file: C:/Users/ANGEL/Desktop/UPDATE.APP 2019-07-17 11:10:10 GMT ------------------------------------------------- Starting Write Firmware Searching connected Fastboot devices... Device Model: ALE-L21 System: ALE-L21C185B574 |
07-17-2019, 12:14 | #6 (permalink) |
Member: 2767415 Status: Offline Thanks Meter: 30 | 2019-07-17 11:01:34.041 Loading application settings 2019-07-17 11:01:34.048 Refreshing serial ports list 2019-07-17 11:01:34.376 Found COM ports: 2019-07-17 11:01:34.376 1: COM1 Nuvoton Communications Port 2019-07-17 11:01:34.376 2: COM17 USB Serial Port 2019-07-17 11:01:34.448 Welcome to Octoplus Huawei Software v.1.1.0 2019-07-17 11:01:34.448 2019-07-17 11:01:34.448 To enable 'Manufacture' mode dial 2019-07-17 11:01:34.449 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2019-07-17 11:01:34.449 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2019-07-17 11:01:34.449 - for MTK based models: *#*#14789632#*#* 2019-07-17 11:01:34.450 ProjectMenu > Background Settings > USB Port Settings > Debug Mode 2019-07-17 11:01:34.450 2019-07-17 11:01:34.450 To enable 'Fastboot' mode 2019-07-17 11:01:34.450 1. Power off the phone. Remove SD and SIM cards 2019-07-17 11:01:34.451 2. Press 'Vol-' and insert USB cable 2019-07-17 11:01:34.451 3. Wait until phone enters 'Fastboot' mode 2019-07-17 11:01:34.451 2019-07-17 11:01:34.452 To enable 'Upgrade' mode 2019-07-17 11:01:34.452 1. Power off the phone. Remove SD and SIM cards 2019-07-17 11:01:34.452 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2019-07-17 11:01:34.453 3. Wait until phone enters 'Upgrade mode' 2019-07-17 11:01:34.518 Refreshing serial ports list 2019-07-17 11:01:34.792 Found COM ports: 2019-07-17 11:01:34.792 1: COM1 Nuvoton Communications Port 2019-07-17 11:01:34.792 2: COM17 USB Serial Port 2019-07-17 11:01:34.867 Init finished 2019-07-17 11:02:18.747 Selected file: C:/Users/ANGEL/Desktop/UPDATE.APP 2019-07-17 11:10:10.813 2019-07-17 11:10:10 GMT ------------------------------------------------- 2019-07-17 11:10:10.815 Starting Write Firmware 2019-07-17 11:10:10.817 Searching connected Fastboot devices... 2019-07-17 11:10:11.826 Total interfaces: 1 2019-07-17 11:10:11.826 Interface 0 : flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#w3d7n16810011976#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} 2019-07-17 11:10:13.227 Device Model: ALE-L21 2019-07-17 11:10:13.229 System: ALE-L21C185B574 2019-07-17 11:10:13.231 IMEI A: 862491031381401 2019-07-17 11:10:13.233 S/N: W3D7N16810011976 2019-07-17 11:10:13.235 Selected firmware: C:/Users/ANGEL/Desktop/UPDATE.APP 2019-07-17 11:10:13.627 Command not allowed 2019-07-17 11:10:13.629 Extracting firmware partitions... 2019-07-17 11:10:23.934 partition has been extracted successfully 2019-07-17 11:10:23.936 Checking firmware compatibility 2019-07-17 11:10:24.334 Firmware is not compatible 2019-07-17 11:10:32.758 Selected firmware is not compatible with your device revision. Writing of this firmware may lead to phone damage! 2019-07-17 11:10:33.158 Connecting to server... 2019-07-17 11:10:34.279 FRP unlock 0 2019-07-17 11:10:34.610 Writing erase FRP data 2019-07-17 11:10:42.479 Writing MODEMIMAGE partition.. 2019-07-17 11:10:45.621 MODEMIMAGE partition has been written successfully 2019-07-17 11:10:45.624 Writing MODEMNVM1 partition.. 2019-07-17 11:10:46.796 MODEMNVM1 partition has been written successfully 2019-07-17 11:10:46.800 Writing MCUIMAGE partition.. 2019-07-17 11:10:47.600 MCUIMAGE partition has been written successfully 2019-07-17 11:10:47.603 Writing HIFI partition.. 2019-07-17 11:10:48.477 HIFI partition has been written successfully 2019-07-17 11:10:48.480 Writing DSP partition.. 2019-07-17 11:10:49.348 DSP partition has been written successfully 2019-07-17 11:10:49.352 Writing DTIMAGE partition.. 2019-07-17 11:10:50.571 DTIMAGE partition has been written successfully 2019-07-17 11:10:50.575 Writing SECURETYSTORAGE partition.. 2019-07-17 11:10:51.419 SECURETYSTORAGE partition has been written successfully 2019-07-17 11:10:51.423 Writing NVME partition.. 2019-07-17 11:10:52.223 NVME partition has been written successfully 2019-07-17 11:10:52.227 Writing FASTBOOT1 partition.. 2019-07-17 11:11:13.427 Writing FASTBOOT1 partition failed 2019-07-17 11:11:13.431 2019-07-17 11:11:13.436 Write Firmware failed. 2019-07-17 11:11:13.440 Performed by 1.1.0 Software version. |
07-17-2019, 12:58 | #8 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Use Sd Card method if not goes in Upgrade Mode how you say. Also loock here: Quote:
