11-26-2018, 10:41 | #31 (permalink) |
Crazy Poster Join Date: Mar 2008
Member: 720794 Status: Offline Thanks Meter: 1 | Welcome to Octoplus Huawei Software v.1.0.5 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM6 Z3X BOX Serial Port 2018-11-26 09:39:58 GMT ------------------------------------------------- Starting Auto detect Detected HiSilicon Android Device at COM32 Warning: Can't get serial number. Warning: Can't get device model. Warning: Can't get IMEI/MAC info. Removing security protection... Error: Authorize HiSilicon Android Device Device firmware is currently not supported Auto detect failed. Performed by 1.0.5 Software version. |
11-26-2018, 11:53 | #34 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
From where you see that have NEW SECURITY?....you read some "INFO" in Fastboot mode or other way?.... Never had seen a Huawei and now all Huawei Technician I still doing a lot of "Ane-LX1 C432", also with New Security!!!! | |
12-03-2018, 07:19 | #35 (permalink) |
Freak Poster Join Date: Dec 2011 Location: pakistan
Member: 1703671 Status: Offline Sonork: 100.1627623 Thanks Meter: 26 | i have this problem this version already install via official recovery but failed to enable sim card then flash with octopus huawei tool & the result is 2018-12-03 06:11:19 GMT ------------------------------------------------- Starting Read Info (Fastboot Mode) Searching connected Fastboot devices... S/N: WCH7N15A******** Build Number: ATH-UL06C469B130 Read Info (Fastboot Mode) done. Performed by 1.0.5 Software version. 2018-12-03 06:11:26 GMT ------------------------------------------------- Starting Write Firmware Searching connected Fastboot devices... S/N: WCH7N15A13000194 Extracting firmware partitions... partition has been extracted successfully Checking firmware compatibility Connecting to server... Writing RPM partition.. RPM partition has been written successfully Writing TZ partition.. TZ partition has been written successfully Writing SBL1 partition.. SBL1 partition has been written successfully Writing MODEM partition.. MODEM partition has been written successfully Writing HYP partition.. HYP partition has been written successfully Writing FSG partition.. FSG partition has been written successfully Writing RECOVERY partition.. RECOVERY partition has been written successfully Writing ERECOVERY partition.. ERECOVERY partition has been written successfully Writing SYSTEM partition.. Error: Writing SYSTEM partition failed Write Firmware done. Performed by 1.0.5 Software version. any solution? |
12-13-2018, 16:11 | #37 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: italy
Member: 906542 Status: Offline Sonork: yo Thanks Meter: 16 | Quote:
octopus don't read info because it has new version of firmware installed. Please read the log before talk Huawei Technician | |
12-13-2018, 18:57 | #38 (permalink) | |
Not to see have select Z3X Port? Where are the PCUI and DB HUAWEI port? Also is NEW SECURITY must read Info in FASTBOOT....lol | |
12-14-2018, 09:45 | #39 (permalink) |
Member: 906542 Status: Offline Sonork: yo Thanks Meter: 16 | Is not connected in fastboot What is dcteted on port COM32? Detected HiSilicon Android Device at COM32 Warning: Can't get serial number. Warning: Can't get device model. Warning: Can't get IMEI/MAC info. Removing security protection... Error: Authorize HiSilicon Android Device Device firmware is currently not supported Auto detect failed. Performed by 1.0.5 Software version. |
01-02-2019, 10:43 | #42 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. Yes, we work on this. Do You have some devices for test? |
01-28-2019, 13:13 | #45 (permalink) |
Insane Poster Join Date: Dec 2015
Member: 2497504 Status: Offline Thanks Meter: 6 | i ask this question but remove my post when you want update tools i dont use this tools until now becuase huawei tool is not good . all of phone , i want repair not supported or have error but other tools done it . PLEASE WAKE UP |
