08-27-2018, 11:07 | #1 (permalink) | |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | HUAWEI Mate 9 / MHA-L29 Factory Reset Protection disabled without a hitch Quote:
The Following 5 Users Say Thank You to lyes_albert For This Useful Post: |
12-17-2018, 11:22 | #3 (permalink) |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Hi sir, Can you further describe the issue? Booting to fastboot ain't that hard, Just hold volume down while plugging the USB cable, phone should be totally OFF. Check whether Volume buttons are properly and fully functioning, your USB cable as wel... |
12-17-2018, 11:32 | #4 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: las palmas
Member: 1926663 Status: Offline Thanks Meter: 22 | Quote:
OK the buttons work correctly the cables are correct but I can not get in between to load and do not enter fatboot mode | |
12-17-2018, 11:34 | #5 (permalink) |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Turn the phone off, totally off... Then hold volume down, an hook your cable up to PC.. Keep holding volume down for about 15 secs, Please what happens to the phone when all that is done? To which mode does it go? |
12-17-2018, 12:01 | #7 (permalink) |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | This is a weird case, it should go into Fastboot mode, unless one of the following things ain't properly functioning; Volume buttons, PC usb port, or the cable ..... Did you try to plug it on a different USB port? change the PC, change the Cable please....it should normally work.. Did you see any drivers installing while plugging the phone on normal mode? |
12-17-2018, 12:18 | #9 (permalink) |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | if no drivers pop up to install during normal mode, then I believe, something wrong with your phone's USB socket, Probably, the phone's USB connector has been replaced, and DATA pins haven't been properly soldered, that's why the phone is charging but, drivers are not being installed... Good luck |
12-23-2018, 15:42 | #12 (permalink) |
No Life Poster Join Date: Jan 2014 Location: Here
Member: 2102546 Status: Offline Thanks Meter: 480 | Boot in to recovery by holding vol + and power button together after entering recovery you can go to fastboot from there by selecting reboot to bootloader |
