12-24-2018, 05:55 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: World
Member: 792851 Status: Offline Thanks Meter: 136 | S8-701W Write Firmware problem [Answered] Code: Welcome to Octoplus Huawei Software v.1.0.5 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Selected file: D:/Huawei Honor Tablet Firmware(S8-701W, Android 4.3, EMUI 1.6, V100R001C232B003, Spain)/dload/UPDATE.APP 2018-12-24 04:53:06 GMT ------------------------------------------------- Starting Write Firmware Searching connected Fastboot devices... Extracting firmware partitions... partition has been extracted successfully Checking firmware compatibility Warning: oem get-build-number failed Write Firmware done. Performed by 1.0.5 Software version. Last edited by Octopus box; 12-24-2018 at 06:02. |
12-24-2018, 06:02 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What is the problem/state of your device? Why You have decided to write firmware? What is your current device firmware version? Please put the phone fastboot mode and read device info ("Read info" button) and post here full Software log with this info, we will check it. |
12-24-2018, 06:06 | #3 (permalink) | |
Member: 792851 Status: Offline Thanks Meter: 136 | Quote:
when i read info just show this only Code: 2018-12-24 05:05:31 GMT ------------------------------------------------- Starting Read Info (Fastboot Mode) Searching connected Fastboot devices... Warning: oem get-build-number failed Read Info (Fastboot Mode) done. Performed by 1.0.5 Software version. | |
12-24-2018, 07:34 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Have You installed correct driver? What device exactly appear in Windows Device manager when You connect your S8-701W to PC in fastboot mode? |
12-26-2018, 22:33 | #5 (permalink) |
Member: 792851 Status: Offline Thanks Meter: 136 | Hi yes its correct drive i can not flash via sd card mode that why i try octopus but seem i can not flash this tablet via octopus as well may be its hardware dont know. |
