11-06-2018, 20:59 | #1 (permalink) |
Junior Member Join Date: Dec 2007
Member: 653339 Status: Offline Thanks Meter: 3 | brick nokia 6.1. Stuck at Download mode |
The Following User Says Thank You to chriskleov For This Useful Post: |
11-07-2018, 03:22 | #2 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | it was bad idea to allow OTA on such phone ( TA-1054 with 00CN00WW custom firmware ) now the only possible way to fix is disassemble phone and do repair via EDL and testpoint. |
The Following User Says Thank You to the_laser For This Useful Post: |
11-07-2018, 06:30 | #3 (permalink) |
Member: 653339 Status: Offline Thanks Meter: 3 | it was no warning anywhere here about these.. is it possible to have walkthrough to fix it? and another user have same problem. with edl cable is possible to fix it with no disassemble the phone?thanks |
11-08-2018, 07:51 | #11 (permalink) |
Member: 653339 Status: Offline Thanks Meter: 3 | i manage to open the phone but i destroy the lcd ( i cut the cable) :/ i need help about the reset point. the + pole gone to the pin? and the negative??? i have no respond from the phone i cant have acces to EDL. It need edl usb cable? |
11-08-2018, 09:38 | #12 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | everything clearly written in guide. you need to connect +3.3v source to testpoint ( use battery as source, for example ), then you need to connect phone to USB cable - if all done properly, you will see EDL device. then you need disconnect testpoint and proceed to boot repair. |
