11-27-2018, 21:25 | #1 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1019997 Status: Offline Sonork: 1001650519 Thanks Meter: 3 | How to connect a Nokia 6 to detect Ntool |
The Following User Says Thank You to estebanrdj For This Useful Post: |
11-27-2018, 21:42 | #2 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | first check your cable when phone has normal mode device manager detected or not? second install properly USB driver, if you do have enough credit, just run the software go to service tab connect USB cable with normal mode than manually restart your phone optionally hopefully your phone willbe connected, like this http://forum.gsmhosting.com/vbb/13419471-post15.html |
11-27-2018, 22:43 | #3 (permalink) |
Member: 1019997 Status: Offline Sonork: 1001650519 Thanks Meter: 3 | I connect off the phone does not detect it I did the test with infinity best nk2 and it detects it as soon as I connect it but ntool no BEST NK2 Dev Model : PLS HW version : 5.2 HW variant : FIH eMMC HW RF_BAND : G_850_900_1800_1900^W_1_2_4_5_8^L_2_3_4_7_12_17_28 _38 SW version : PLE-560C-0-00WW-B01 SW serialnm : PLEGAR2781003332 SW secured : YES Bootloader type : RETAIL Security Version : 0004 Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
11-28-2018, 01:04 | #4 (permalink) |
Junior Member Join Date: Sep 2012 Location: Peru
Member: 1813747 Status: Offline Thanks Meter: 1 | same problem, i tried with nokia 2 and nokia 6 and no detect the phone , but all is ok cable and driver and normally work with infinity best and MTP, ADB Need more infomation about connecction drivers ETC thanks |
The Following User Says Thank You to Cyberpanther For This Useful Post: |
11-28-2018, 17:44 | #5 (permalink) | |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | Quote:
repair your boot first with ND1_BootFix.zip ( it will work fine for PLE ), then flash phone with NTool | |
11-28-2018, 17:46 | #6 (permalink) | |
delete existing ADB driver ( check "delete driver files" ) in windows device manager install ADB driver from NTool drivers folder. | |
